    MMM-DumpsterDay
    83 Posts 11 Posters 69.3k Views 12 Watching
      mrdenmark @mrdenmark
      @mrdenmark apologies foe formatting above!
        DeanoNoire @mrdenmark
        @mrdenmark if you set the date to 18.11.2019 and the occurance is every 14 days then it’s correct :)
        If the enable value is true - the image is not visible as it’s not a trashcan day.
        If the enable value is false - the part of the module is disabled and is not evaluated at all. Also I recommend to use start dates from the past, not future :)
          BD0G
          Since the Red Can graphic was added to the github repository my MagicMirror update-notification module indicates an update is needed to the MMM-DumpsterDay module. This made me think that it would be good to add the update process to the github repository instructions.
          I just did a
          git fetch and then a
          git pull
          from within the MagicMirror/modules/MMM-DumpsterDay sub directory and that updated the module.
            Doughboy99 @BD0G
            Re: MMM-DumpsterDay
            I am having problems getting the bins to show correctly. I have three different bin collections
            Rubbish(basic) collected fortnightly on thursdays next collection due 21st November
            Recycling(plastic) collected fortnightly on thursdays next collection due 14th November
            Composting(landscape) collected fortnightly on Mondays next collection due 25th November
            The icon for the plastic collection is displayed as expected but the landscaping icon is also showing today(14th) even though it is not due until the 25th. Any ideas what the issue is?
            This is the config file I am using
            {module:“MMM-DumpsterDay”,
            position:“lower_third”,
            			refreshInterval: 18000000, // Default: 18000000 = 5 hours
            			pulse: true, 			   // Default: true - Makes the module pulsating
            		enableBasic: true, 				// Enable basic trashcan
            			basicStartDate: "24.10.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
            			basicDateDiff_1: 14,			// Trashday reoccurance - Default: 14 (every 14 days)
            			basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
            		enablePlastic: true,			// Same values as basic but for Plastic
            			plasticStartDate: "31.10.2019",
            			plasticDateDiff_1: 14,
            			plasticNotifyDayBefore: true,
            		enableLandscape: true,			// Same values as basic but for Landscape
            			landscapeStartDate: "14.10.2019",
            			landscapeDateDiff_1: 14,
            			landscapeNotifyDayBefore: true,
              sdetweil @mrdenmark
              @mrdenmark said in MMM-DumpsterDay:
              fixed…
              the three tildes need to be on a separate line by themselves
                Doughboy99 @Doughboy99
                @Doughboy99
                I think I have found the issue for me.
                in MMM-DumpsterDay.js the if statement
                	if (enableLandscape == true){
                	landscapeTrashDayResult = this.isPlasticTrashDay();
                	Log.info("landscapeTrashDayResult: "+landscapeTrashDayResult);
                	var landscapeDiv = document.createElement("div");
                	landscapeDiv.className = "landscapeDiv";
                	wrapper.appendChild(landscapeDiv);
                		if (landscapeTrashDayResult == 0){
                		landscapeDiv.classList.add("non_today")
                line 83 should read
                landscapeTrashDayResult = this.isLandscapeTrashDay();
                This seems to fix my issue.
                  BD0G @Doughboy99
                  @Doughboy99
                  Good catch. Seems logical that the statement should pertain to Landscape because of what precedes it.
                  I made the change to my MMM-DumpsterDay.js . You can report the issue via github and the author @DeanoNoire can add the changes.
                  Here is the link to report github MMM-DumpsterDay Issues
                    Doughboy99 @BD0G
                    @BD0G Thanks Ive posted an issue. Your link is to another reposirory for a similar module .
                    The correct link is here
                    B D 2 Replies Last reply Reply Quote 1
                      BD0G @Doughboy99
                      @Doughboy99 Corrected the link. Thanks!
                        DeanoNoire @Doughboy99
                        @Doughboy99 Thanks a lot guys, I just corrected it on github.
                        Have a good one!
                          BD0G
                          Thanks @DeanoNoire . Any plans to implement the “Tomorrow is Trash Day” and “Today is Trash Day” text?
                            DeanoNoire @BD0G
                            @BD0G wasn’t really planning to, but I guess I can add it as an option :) will see how much work is wating for me at job this week :D
                              Paddi
                              @DeanoNoire Had no luck to make it work. When adding in the config.js and restarting mirror it messes up things. Black background instead of usual picture. Some modules do not load…
                              Could you help ?
                                BD0G @Paddi
                                @Paddi Try Pressing the CTRL-Shift-i keys together once the Magic Mirror has loaded to bring up the developers window. Then click on the tab labeled console and look for any errors. Usually in Red text. When there is a black screen it “typically” indicates one or more of the modules has crashed.
                                  BD0G
                                  I had this module working great , but for some strange reason it no longer shows the Landscape can. I set the dates to tommorrow which is trash day so the Trash Can and Landscape can should be displayed the day before (which it today) and only the Trash Can is displayed. My date is set correctly on the Magic Mirror so its not that.
                                  Here is my config entry
                                  	module:"MMM-DumpsterDay",
                                  	position:"bottom_bar",
                                  		basicStartDate: "27.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                  		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
                                  		enablePlastic: false,			// Same values as basic but for Plastic
                                  		plasticStartDate: "27.11.2019",
                                  		plasticDateDiff_1: 28,
                                  		landscapeStartDate: "27.11.2019",
                                    DeanoNoire @BD0G
                                    @BD0G Can you try updating the latest version of this module from github? :) there was an issue with Landscape part.
                                      mrdenmark
                                      has anyone managed to get this module to work correctly?i’ve tried allsorts of config options but it behaves quite strangely.
                                      my collection day is monday,the red gets collected every monday and the blue and yellow get alternate and get collected biweekly.
                                      the module did as it should the first week and never since then,it only shows 1 bin,some weeks it shows a bin to be collected on thursday,dissapears on friday and re-appears on sunday!
                                              position:"upper_third",
                                                      pulse: false,
                                                      maxWidth: "75px",                          // Default: true - Makes the module pulsating
                                                      basicStartDate: "11.11.2019",   // The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                                      basicNotifyDayBefore: true,             //Default: true - If you want the notification to appear also t$
                                                      plasticStartDate: "04.11.2019",
                                                      landscapeStartDate: "11.11.2019",
                                        DeanoNoire
                                        Hey guys,
                                        I finally found some time to review and practically remaster whole module. Now it’s finally working correctly and the console logging is improved and more readable.
                                        Please let me know if you still encounter some issues.
                                        Stay safe in these difficult times!
                                          robertybob @DeanoNoire
                                          @DeanoNoire The download link isn’t in the original post anymore?
                                            DeanoNoire @robertybob
                                            @robertybob originaly there was a github card for the repository, but it seems the card is not supported anymore.
                                            And as I’m not able to edit the original post, here is the link:
                                            https://github.com/DeanoNoire/MMM-DumpsterDay
                                            • 3 / 5
