    MMM-DumpsterDay
    83 Posts 11 Posters 70.7k Views 12 Watching
      DeanoNoire @Doughboy99
      @Doughboy99 Thanks a lot guys, I just corrected it on github.
      Have a good one!
        BD0G
        Thanks @DeanoNoire . Any plans to implement the “Tomorrow is Trash Day” and “Today is Trash Day” text?
          DeanoNoire @BD0G
          @BD0G wasn’t really planning to, but I guess I can add it as an option :) will see how much work is wating for me at job this week :D
            Paddi
            @DeanoNoire Had no luck to make it work. When adding in the config.js and restarting mirror it messes up things. Black background instead of usual picture. Some modules do not load…
            Could you help ?
              BD0G @Paddi
              @Paddi Try Pressing the CTRL-Shift-i keys together once the Magic Mirror has loaded to bring up the developers window. Then click on the tab labeled console and look for any errors. Usually in Red text. When there is a black screen it “typically” indicates one or more of the modules has crashed.
                BD0G
                I had this module working great , but for some strange reason it no longer shows the Landscape can. I set the dates to tommorrow which is trash day so the Trash Can and Landscape can should be displayed the day before (which it today) and only the Trash Can is displayed. My date is set correctly on the Magic Mirror so its not that.
                Here is my config entry
                	module:"MMM-DumpsterDay",
                	position:"bottom_bar",
                		refreshInterval: 18000000, // Default: 18000000 = 5 hours
                		pulse: true, 			   // Default: true - Makes the module pulsating
                		enableBasic: true, 				// Enable basic trashcan
                		basicStartDate: "27.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
                		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
                		enablePlastic: false,			// Same values as basic but for Plastic
                		plasticStartDate: "27.11.2019",
                		plasticDateDiff_1: 28,
                		plasticNotifyDayBefore: true,
                		enableLandscape: true,			// Same values as basic but for Landscape
                		landscapeStartDate: "27.11.2019",
                		landscapeDateDiff_1: 14,
                		landscapeNotifyDayBefore: true,
                  DeanoNoire @BD0G
                  @BD0G Can you try updating the latest version of this module from github? :) there was an issue with Landscape part.
                    mrdenmark
                    has anyone managed to get this module to work correctly?i’ve tried allsorts of config options but it behaves quite strangely.
                    my collection day is monday,the red gets collected every monday and the blue and yellow get alternate and get collected biweekly.
                    the module did as it should the first week and never since then,it only shows 1 bin,some weeks it shows a bin to be collected on thursday,dissapears on friday and re-appears on sunday!
                            position:"upper_third",
                                    pulse: false,
                                    maxWidth: "75px",                          // Default: true - Makes the module pulsating
                                    basicStartDate: "11.11.2019",   // The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                    basicNotifyDayBefore: true,             //Default: true - If you want the notification to appear also t$
                                    plasticStartDate: "04.11.2019",
                                    plasticDateDiff_1: 14,
                                    landscapeStartDate: "11.11.2019",
                      DeanoNoire
                      Hey guys,
                      I finally found some time to review and practically remaster whole module. Now it’s finally working correctly and the console logging is improved and more readable.
                      Please let me know if you still encounter some issues.
                      Stay safe in these difficult times!
                        robertybob @DeanoNoire
                        @DeanoNoire The download link isn’t in the original post anymore?
                          DeanoNoire @robertybob
                          @robertybob originaly there was a github card for the repository, but it seems the card is not supported anymore.
                          And as I’m not able to edit the original post, here is the link:
                          https://github.com/DeanoNoire/MMM-DumpsterDay
                            blackeaglece
                            Hello how can i reduce the space between the header and the image? as you can see from the screenshotreduce.jpg Thank you very much
                              DeanoNoire @blackeaglece
                              Hello @blackeaglece ,
                              I do not use the headers, but I presume it’s always on the top of the module wrapper.
                              So first thing I’d try is decreasing the height value of trashcan_wrapper.
                              This is done in MMM-DumpsterDay.css file in the module folder.
                              Please let me know if you managed moving it by these steps.
                              Deano
                                Bob
                                Hi, is there any way to add a option for a 4th icon ? We have 3 different types of recycling (glass, cardboard and plastic), as well as the usual rubbish/trash, and of course, they all come at different times ! :)
                                  DeanoNoire @Bob
                                  Hey @Bob ,
                                  sure thing. Any tips for cardboard and glass bin image and color?
                                  This brings me to an idea of making the colors and images parameterizable.
                                  Deano
                                    Bob
                                    @DeanoNoire Our colours are blue (glass), grey (cardboard), green (plastic) and black (trash/rubbish), but I suspect if you compare local areas, they’ll all have different colour schemes. I’ve even seen places where the bins were all the same, they just had different logos on them for the relevant product.
                                    As you say, either paramatize them, or even just reference the icons by name/type, and let people change the image behind them to their colour of choice ?
                                      Bob
                                      Just when I thought there were a standard set of colours, I find this…
                                      https://en.wikipedia.org/wiki/Recycling_bin
                                      Looks like the most sensible thing is to simply ensure the recycling symbol is on the icon, and then give people the option of different colours.
                                        DeanoNoire
                                        Cool… I will look into it as soon as I dont have that much work :)
                                          blackeaglece
                                          Hi all, I’m having trouble getting the exact icon of the garbage collection to display with the chosen day. Example, today there is no collection but it shows me 3 icons that should not display. Also, from us the collection of organic materials occurs 3 times a week how could I put more dates for the same collection? I attach links for my icons and the code of both MMM-Dumpster and config.js
                                          img garbage
                                          Glass, Paper, Organic, Plastic and Other Garbage
                                          config.js file MM
                                          MMM-Dumpster file
                                          Thank you
                                          B D 2 Replies Last reply Reply Quote 0
                                            blackeaglece @blackeaglece
                                            @blackeaglece does anyone know how to fix date display error in images?
                                            • 4 / 5
