    MMM-DumpsterDay
    83 Posts 11 Posters 69.3k Views 12 Watching
      Paddi
      @DeanoNoire Had no luck to make it work. When adding in the config.js and restarting mirror it messes up things. Black background instead of usual picture. Some modules do not load…
      Could you help ?
        BD0G @Paddi
        @Paddi Try Pressing the CTRL-Shift-i keys together once the Magic Mirror has loaded to bring up the developers window. Then click on the tab labeled console and look for any errors. Usually in Red text. When there is a black screen it “typically” indicates one or more of the modules has crashed.
          BD0G
          I had this module working great , but for some strange reason it no longer shows the Landscape can. I set the dates to tommorrow which is trash day so the Trash Can and Landscape can should be displayed the day before (which it today) and only the Trash Can is displayed. My date is set correctly on the Magic Mirror so its not that.
          Here is my config entry
          	module:"MMM-DumpsterDay",
          	position:"bottom_bar",
          		refreshInterval: 18000000, // Default: 18000000 = 5 hours
          		pulse: true, 			   // Default: true - Makes the module pulsating
          		enableBasic: true, 				// Enable basic trashcan
          		basicStartDate: "27.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
          		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
          		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
          		enablePlastic: false,			// Same values as basic but for Plastic
          		plasticStartDate: "27.11.2019",
          		plasticDateDiff_1: 28,
          		plasticNotifyDayBefore: true,
          		enableLandscape: true,			// Same values as basic but for Landscape
          		landscapeStartDate: "27.11.2019",
          		landscapeDateDiff_1: 14,
          		landscapeNotifyDayBefore: true,
            DeanoNoire @BD0G
            @BD0G Can you try updating the latest version of this module from github? :) there was an issue with Landscape part.
              mrdenmark
              has anyone managed to get this module to work correctly?i’ve tried allsorts of config options but it behaves quite strangely.
              my collection day is monday,the red gets collected every monday and the blue and yellow get alternate and get collected biweekly.
              the module did as it should the first week and never since then,it only shows 1 bin,some weeks it shows a bin to be collected on thursday,dissapears on friday and re-appears on sunday!
                      position:"upper_third",
                              pulse: false,
                              maxWidth: "75px",                          // Default: true - Makes the module pulsating
                              basicStartDate: "11.11.2019",   // The first dumpster day (Always use 2 digit dates (01 instead of 1))
                              basicNotifyDayBefore: true,             //Default: true - If you want the notification to appear also t$
                              plasticStartDate: "04.11.2019",
                              plasticDateDiff_1: 14,
                              landscapeStartDate: "11.11.2019",
                DeanoNoire
                Hey guys,
                I finally found some time to review and practically remaster whole module. Now it’s finally working correctly and the console logging is improved and more readable.
                Please let me know if you still encounter some issues.
                Stay safe in these difficult times!
                  robertybob @DeanoNoire
                  @DeanoNoire The download link isn’t in the original post anymore?
                    DeanoNoire @robertybob
                    @robertybob originaly there was a github card for the repository, but it seems the card is not supported anymore.
                    And as I’m not able to edit the original post, here is the link:
                    https://github.com/DeanoNoire/MMM-DumpsterDay
                      blackeaglece
                      Hello how can i reduce the space between the header and the image? as you can see from the screenshotreduce.jpg Thank you very much
                        DeanoNoire @blackeaglece
                        Hello @blackeaglece ,
                        I do not use the headers, but I presume it’s always on the top of the module wrapper.
                        So first thing I’d try is decreasing the height value of trashcan_wrapper.
                        This is done in MMM-DumpsterDay.css file in the module folder.
                        Please let me know if you managed moving it by these steps.
                        Deano
                          Bob
                          Hi, is there any way to add a option for a 4th icon ? We have 3 different types of recycling (glass, cardboard and plastic), as well as the usual rubbish/trash, and of course, they all come at different times ! :)
                            DeanoNoire @Bob
                            Hey @Bob ,
                            sure thing. Any tips for cardboard and glass bin image and color?
                            This brings me to an idea of making the colors and images parameterizable.
                            Deano
                              Bob
                              @DeanoNoire Our colours are blue (glass), grey (cardboard), green (plastic) and black (trash/rubbish), but I suspect if you compare local areas, they’ll all have different colour schemes. I’ve even seen places where the bins were all the same, they just had different logos on them for the relevant product.
                              As you say, either paramatize them, or even just reference the icons by name/type, and let people change the image behind them to their colour of choice ?
                                Bob
                                Just when I thought there were a standard set of colours, I find this…
                                https://en.wikipedia.org/wiki/Recycling_bin
                                Looks like the most sensible thing is to simply ensure the recycling symbol is on the icon, and then give people the option of different colours.
                                  DeanoNoire
                                  Cool… I will look into it as soon as I dont have that much work :)
                                    blackeaglece
                                    Hi all, I’m having trouble getting the exact icon of the garbage collection to display with the chosen day. Example, today there is no collection but it shows me 3 icons that should not display. Also, from us the collection of organic materials occurs 3 times a week how could I put more dates for the same collection? I attach links for my icons and the code of both MMM-Dumpster and config.js
                                    img garbage
                                    Glass, Paper, Organic, Plastic and Other Garbage
                                    config.js file MM
                                    MMM-Dumpster file
                                    Thank you
                                    B D 2 Replies Last reply Reply Quote 0
                                      blackeaglece @blackeaglece
                                      @blackeaglece does anyone know how to fix date display error in images?
                                        @blackeaglece I’m quite certain you have to create functions and instances for every landscape reccuring date. Act like second and third landscape instances are different kind of trash with the same image.
                                          blackeaglece @DeanoNoire
                                          @deanonoire said in MMM-DumpsterDay:
                                          Hi, but it doesn’t display me landscape but glass or organic. I created a new instance called landscape1 but it still shows me all the images . This is the code of config.js. How can I do?
                                          	position:"top_left",
                                          	header: "Raccola Differenziata",
                                          		pulse: false, 			   // Default: true - Makes the module pulsating
                                          	enableBasic: true, 				// Abilita indifferenziata trashcan
                                          		basicStartDate: "09.04.2021", 		// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                          	enablePaper: true,			// Abilita bidoncino carta bianco
                                          		paperStartDate: "06.04.2021",
                                          		paperDateDiff_1: 7,
                                          		paperNotifyDayBefore: true,
                                          	enablePlastic: true,			// Same values as basic but for Plastic
                                          		plasticStartDate: "13.04.2021",
                                          		plasticDateDiff_1: 7,
                                          	enableVetro: true,			// Same values as basic but for Plastic
                                          		vetroStartDate: "08.04.2021",
                                          		vetroDateDiff_1: 7,
                                          		vetroNotifyDayBefore: true,
                                          	enableLandscape: true,			// Abilita bidoncino umido
                                          		landscapeStartDate: "04.04.2021",
                                          		landscapeDateDiff_1: 7,
                                          	enableLandscape1: true,			// Abilita bidoncino umido
                                          		landscape1StartDate: "06.04.2021",
                                          		landscape1DateDiff_1: 7,
                                          		landscape1NotifyDayBefore: true,
                                          and this is how it is displayed
                                            @blackeaglece I see. What is in the log? There should be evaluations if its trashday or not.
                                            Also can you inspect the elements if .non_today class is present on the divs? If yes, check if the css file is loaded properly, as it should be hiding the images when it’s not dumpster day.
                                            https://github.com/DeanoNoire/MMM-DumpsterDay/blob/master/MMM-DumpsterDay.css
                                            • 4 / 5
