    MMM-DumpsterDay
    83 Posts 11 Posters 68.9k Views 12 Watching
      blackeaglece
      Hi all, I’m having trouble getting the exact icon of the garbage collection to display with the chosen day. Example, today there is no collection but it shows me 3 icons that should not display. Also, from us the collection of organic materials occurs 3 times a week how could I put more dates for the same collection? I attach links for my icons and the code of both MMM-Dumpster and config.js
      img garbage
      Glass, Paper, Organic, Plastic and Other Garbage
      config.js file MM
      MMM-Dumpster file
      Thank you
      B D 2 Replies Last reply Reply Quote 0
        blackeaglece @blackeaglece
        @blackeaglece does anyone know how to fix date display error in images?
          DeanoNoire @blackeaglece
          @blackeaglece I’m quite certain you have to create functions and instances for every landscape reccuring date. Act like second and third landscape instances are different kind of trash with the same image.
            blackeaglece @DeanoNoire
            @deanonoire said in MMM-DumpsterDay:
            Hi, but it doesn’t display me landscape but glass or organic. I created a new instance called landscape1 but it still shows me all the images . This is the code of config.js. How can I do?
            	module:"MMM-DumpsterDay",
            	position:"top_left",
            	header: "Raccola Differenziata",
            		refreshInterval: 18000000, // Default: 18000000 = 5 hours
            		pulse: false, 			   // Default: true - Makes the module pulsating
            	enableBasic: true, 				// Abilita indifferenziata trashcan
            		basicStartDate: "09.04.2021", 		// The first dumpster day (Always use 2 digit dates (01 instead of 1))
            		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
            		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
            	enablePaper: true,			// Abilita bidoncino carta bianco
            		paperStartDate: "06.04.2021",
            		paperDateDiff_1: 7,
            		paperNotifyDayBefore: true,
            	enablePlastic: true,			// Same values as basic but for Plastic
            		plasticStartDate: "13.04.2021",
            		plasticDateDiff_1: 7,
            		plasticNotifyDayBefore: true,
            	enableVetro: true,			// Same values as basic but for Plastic
            		vetroStartDate: "08.04.2021",
            		vetroDateDiff_1: 7,
            		vetroNotifyDayBefore: true,
            	enableLandscape: true,			// Abilita bidoncino umido
            		landscapeStartDate: "04.04.2021",
            		landscapeDateDiff_1: 7,
            		landscapeNotifyDayBefore: true,
            	enableLandscape1: true,			// Abilita bidoncino umido
            		landscape1StartDate: "06.04.2021",
            		landscape1DateDiff_1: 7,
            		landscape1NotifyDayBefore: true,
            and this is how it is displayed
              @blackeaglece I see. What is in the log? There should be evaluations if its trashday or not.
              Also can you inspect the elements if .non_today class is present on the divs? If yes, check if the css file is loaded properly, as it should be hiding the images when it’s not dumpster day.
              https://github.com/DeanoNoire/MMM-DumpsterDay/blob/master/MMM-DumpsterDay.css
                @deanonoire Ok now it’s all ok i was wrong, some lines of css code had disappeared
                Thank you very much
                  @blackeaglece Glad I could help ;) stay safe ;)
                    Thank you :ok_hand:
                      @deanonoire How do I create instances and functions? Also, to make them work, do I have to create different images even if they serve the same thing? e.g. landscape.png landscape-1.png and landscape-2.png, with relative css code?
                      thank you very much
                        Dinschal
                        Hi Deanonoire,
                        is it possible to show the can only the day before collecting? In Germany we put our trash cans outside the day before. So the notification on the collection day is not nessesary?
                        Greetings
                          DeanoNoire @Dinschal
                          @dinschal Hey there, it’s not possible to set it via config right now, but it’s quite easy to modify it in the MMM-DumpsterDay.js file:
                          Find folloing code (about row 167)
                          // Trashday today
                          if (difference%datediff_1 == 0) {
                          result = 1
                          Log.info(“It’s trashday !!”);
                          and change the value of result to 0.
                          So it’s:
                          // Trashday today
                          result = 0
                          Please let me know if this solution worked as desired.
                          Have a good one; Greetings from Czechia.
                            BD0G
                            I have been working on scaling the use of this great module. I thought about what other reoccurring things that I might need notification of. It came to mind that my front loading Washing Machine indicates that I need to clean the pump screen every 30 days! I also like to do a “tub clean” at about the same interval.
                            The washer has a setting that is named “tub clean” where one adds a bit of bleach or other detergent made for cleaning the inside of the stainless tub to make sure that there is not any bacteria and gunk that builds up.
                            In that vein I created a custom icon that can be used for notification. I wanted to share it with the community in case anyone else wanted to be notified as well.
                            Since I dont use the Recycle Can I just substituted this icon for the Recycle Can and set the reoccurring notification to be every 30 days!! Click the link and then Right Click - Save Image As
                              DeanoNoire @BD0G
                              @BD0G awesome mate! So glad the module is used :)
                              • 4 / 5
