    Hi, there is a new Alexa Module
    98 Posts 13 Posters 75.0k Views 15 Watching
    • rubenixR Offline
      rubenix
      Hey man!! many thanks will try it asap and tell you how it goes.
      I found another solution to show my google calendar using an iframe (had to make it public tho and do not want this)
      So pretty good news if I make it to work.
      Many thanks!!!
      • rubenixR Offline
        rubenix
        Yehaaaa. Got it working with no issues at all.
        I think I tried before as per your link instructions but I think I put it without the notifications of page increment and page decrement. I made a fatal mix indeed…and thats why mirror was doing weird things…
        Thanks so much, I’ve been in touch with MMM-Page developer but yours it has been the best indication indeed.
        I’ve been playing with MMM-Notification-Trigger as I needed for interact with a groove sensor to fire QUERY_PAGE_NUMBER and got it working too. Very productive weekened indeed :face_savouring_delicious_food:
        So now pages rotates by itself ; I can change them by AlexaControl and with a gesture too!!! Lovely
        Thats what I wanted; reverting back calendar as private!!!
        Thanks so much @JoChef2 I owe you a beer:clinking_beer_mugs:
        • rubenixR Offline
          rubenix
          Hello again! I’ve another question…
          I want to power off USB power at the same time I power off monitor from alexa module.
          I’ve seen on line 199 of node_helper.js the following:
           exec("vcgencmd display_power 0", opts, (error, stdout, stderr) =>
          Tried to add the command: echo ‘1-1’ |sudo tee /sys/bus/usb/drivers/usb/unbind (cut power from usb ports)
          like that:
           exec("vcgencmd display_power 0 && echo '1-1' |sudo tee /sys/bus/usb/drivers/usb/unbind", opts, (error, stdout, stderr) =>
          Command does not work (I think theres a syntax error) monitor powers off but usb power still on.
          Command works from commandline.
          Also tried to put it on a separate exec function without succeed.
          Can you give me a hand with this @JoChef2
          Thanks!
          • rubenixR Offline
            rubenix
            Also created a couple of scripts (monitor_on.sh & monitor_off.sh) --> with 2 commands I mentioned before on them.
            Both works from bash but cannot execute them from node_helper.js
            any thoughts? sorry about asking but am not a coder & cannot find an answer anywere…
            Thanks!
            S J 2 Replies Last reply Reply Quote 0
              sdetweil @rubenix
              @rubenix what do the scripts look like? if u replaced the vcgencmd strin with the scripts, they should work…
              where are the scripts? they MUST be on the path, or have the full path specified in the command too
                JoChef2 Module Developer @rubenix
                @rubenix Hi, I don’t really know why it doesn’t work. The syntax seems to be right. That’s the hole edit part around line 199. Maybe it helps. I tested this and it works great.
                 device.handler = function(action) {
                    if(action === 1){
                        exec("vcgencmd display_power 1 && echo '1-1' |sudo tee /sys/bus/usb/drivers/usb/bind", opts, (error, stdout, stderr) => {
                            _this.checkForExecError(error, stdout, stderr);
                    }if(action === 0){
                        exec("vcgencmd display_power 0 && echo '1-1' |sudo tee /sys/bus/usb/drivers/usb/unbind", opts, (error, stdout, stderr) => {
                  sdetweil @JoChef2
                  @JoChef2 its because the exec() is launching A program… but the program is NOT a shell (sh., bash etc), and only THEY understand the | and && syntax… vcgencmd does not… it executes what it knows ‘display_power 1’ ,and ignores the rest
                  now, you CAN execute a script directly as long as it contains the processor name at the front
                  #!/bin/sh or #!/bin/bash
                  exec(“/home/pi/MagicMirror/modules/MMM-AlexaControl/scriptname”)
                  or the script has to be in the path environment varible.
                  (unlike windows, the ‘current directory’ is NOT included in the path (for security reasons))
                  if the script does NOT contain the processor path&name
                  then you have to launch the shell
                  exec(“/bin/bash -c "command string with pipe and logic chars"”)
                  • rubenixR Offline
                    rubenix
                    got it working thanks!
                    if(action === 1){
                                exec('/home/pi/monitor_on.sh');
                                }if(action === 0){
                                exec('/home/pi/monitor_off.sh');
                    forgot to put the path :confounded_face:
                    Thanks buds!
                      minomit
                      Hi, mmm-alexacontrol is ok, i’m change pages,etc.
                      Can I ask alexa for something and alexa replies in the compliments module?
                      thanks
                        JoChef2 Module Developer @minomit
                        @minomit Hi, no that’s not directly possible with my module because it emulates only smart home devices and haven’t anything to do with the speech of Alexa. It’s possible that you add to the compliments module notification support and then you can create devices with my module that sends notifications to the compliments module. You can complete this with routines in the Alexa app. So then you have a few sentences. But I think that’s not the thing you asked for. If you want to see all the answers of Alexa you should use MMM-awesome-alexa. I’m not sure if my module works with it but that’s the only way I see to realize that. Maybe someone else have a better idea.
                          sgarg15 @JoChef2
                          @JoChef2 Will this module work with a google home mini?
                            JoChef2 Module Developer @sgarg15
                            @sgarg15 Hi, I don’t know if it works with a google home mini because I don’t have one. But I think the wemos devices I emulate should work with a google home. So test it. You could use the default config and test the preconfigured devices. Let me know if it works.
                              sgarg15 @JoChef2
                              @JoChef2 I dont think it works, i downloaded it and did npm install, and my config is like this
                                    module: 'MMM-AlexaControl',
                                    position: 'middle_center',
                                    config:{
                                      image: false,
                                      pm2ProcessName: "MagicMirror",
                                      vcgencmd: "vcgencmd",
                              and my google home mini is unable to detect the magic mirror
                                sdetweil @sgarg15
                                @sgarg15 how do u discover devices w a mini?
                                  sgarg15
                                  @sdetweil you usually go into the app and then click set up new device and it searches for a device and for me when it searches it cant find any device
                                    sdetweil @sgarg15
                                    @sgarg15 is it looking for a particular device type? These look like wemo, now Belkin plugs
                                      Stevent
                                      Hello, sorry for my bad english, all work perfectly, but i can not change the pages with alexa, the app only find: -restart -refresh -stop -display off
                                      that work fine, but i can not find page change, please help me, here is my configuration:
                                                  image: false,
                                                  pm2ProcessName: "mm",
                                                  monitorToggle: true,
                                                  deviceName: "Spiegel",
                                      	    pages: '2'
                                              module: 'MMM-pages',
                                                      modules:
                                                          [[ "MMM-OpenmapWeather","weatherforecast","newsfeed","calendar", "compliments"],
                                                           [ "MMM-OpenmapWeather","calendar", "compliments" ]],
                                                      fixed: ["clock", "currentweather", "MMM-AlexaControl", "MMM-page-indicator"],
                                              module: 'MMM-page-indicator',
                                              position: 'bottom_bar',
                                                  pages: 2,
                                        JoChef2 Module Developer @Stevent
                                        @Stevent Hi, you made one mistake in your config. The apostrophes for the option pages are wrong. You have to write only a number there.
                                        pages: 2
                                        • 5 / 5
