    MMM-MyCommute - installation error
    3 Posts 2 Posters 1.1k Views 2 Watching
      davidkmcw
      Any idea what is going on with the installation here…?
      pi@magicmirror:~/home/pi/MagicMirror/modules/MMM-MyCommute $ npm install
      > pre-commit@1.2.2 install /home/pi/MagicMirror/modules/MMM-MyCommute/node_modules/pre-commit
      > node install.js
      > spawn-sync@1.0.15 postinstall /home/pi/MagicMirror/modules/MMM-MyCommute/node_modules/spawn-sync
      > node postinstall
      npm WARN grunt-stylelint@0.12.0 requires a peer of stylelint@^11.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN stylelint-config-standard@19.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
      npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
      added 576 packages from 394 contributors and audited 2959 packages in 154.144s
        sdetweil @davidkmcw
        @davidkmcw no errors… all warnings… u can ignore them…
        they added checking for issues if people from outside are using your system…
          davidkmcw @sdetweil
          @sdetweil Thanks
