    Compliments - Multi Line not working?
    13 Posts 4 Posters 5.8k Views 3 Watching
    • N Offline
      noisedoctor
      Platform: Raspberry Pi 3
      MagicMirror Version [ V1 / V2-Beta ]: 2.9.0
      I have the following in my .json file for the compliments module:
      “anytime” : [
      “line 1\nline 2”
      on the screen I see:
      line 1 line 2
      not what I expect:
      line 1
      line 2
      I wanted to see if this is known issue. I don’t see any issue raised in github. The documentation (https://github.com/MichMich/MagicMirror/tree/master/modules/default/compliments) says the \n syntax should work for multi-line compliements.
      This is external json file if that matters.
        broberg Project Sponsor
        It works as intended on my setup, so I don’t think it’s a issue for everyone.
        Can you check so you are not missing
        .pre-line {
          white-space: pre-line;
        in your main.css file (or if you have overwritten it in your custom.css file)
        • N Offline
          noisedoctor
          I do have that in the CSS. I haven’t made any CSS customizations. I installed everything two days ago, so I expect I have the latest code installed.
            broberg Project Sponsor @noisedoctor
            @noisedoctor Okey, so thats not the issue.
            Is the json-file saved in utf8 (and not in ascii)?
            Are you running on the mirrors electron browser or are you viewing it on a different browser?
            • N Offline
              noisedoctor @broberg
              @broberg – sorry for the lag… I did save a file as utf8 (it was ANSI before). I am simply viewing the MM on the display connected to my Raspberry Pi. Any other guess what I could be doing wrong?
                sdetweil
                new line has no meaning in a textElement
                replace the getDom function in compliments.js with this
                	// Override dom generator.
                	getDom: function() {
                		wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright pre-line";
                		// get the compliment text
                		var complimentText = this.randomCompliment();
                		// split it into parts on newline text
                		var parts= complimentText.split('\n')
                		// create a span to hold it all
                		var compliment=document.createElement('span')
                                // process all the parts of the compliment text
                		for (part of parts){
                			// create a text element for each part
                			compliment.appendChild(document.createTextNode(part))
                			// add a break `
                			compliment.appendChild(document.createElement('BR'))
                		// remove the last break
                		compliment.lastElementChild.remove();
                		wrapper.appendChild(compliment);
                		return wrapper;
                then u can use ‘\n’ in the text to split a line like this
                		compliments: {
                			anytime: [
                				"Hey there\n sexy!"
                			morning: [
                				"Good morning, handsome!",
                				"Enjoy your day!",
                				"How was your sleep?"
                			afternoon: [
                				"Hello, \nbeauty!",
                				"You look sexy!",
                				"Looking good today!"
                			evening: [
                				"Wow, you \nlook hot!",
                				"You look nice!",
                				"Hi,\nsexy!"
                • N Offline
                  noisedoctor
                  so, is the documentation wrong?
                  Multi-line compliments:
                  Use \n to split compliment text into multiple lines, e.g. First line.\nSecond line. will be shown as:
                  First line.
                  Second line.
                  I’m happy making a code change, but the docs state that this should already be working. is it a factor of being an external file?
                    sdetweil @noisedoctor
                    @noisedoctor I do not know. I don’t see how it ever worked. The field used does not interpolate the text. Just presents it as is.
                    I opened an issue, and logged the correction as a regression somewhere along the way
                    N B 2 Replies Last reply Reply Quote 0
                    • N Offline
                      noisedoctor @sdetweil
                      @sdetweil – thanks so much. I wanted to confirm before reporting as a defect, but I guess you did that for me :)
                        broberg Project Sponsor @sdetweil
                        @sdetweil said in Compliments - Multi Line not working?:
                        The \n gets converted to a whitespace in the textNode. And then the css pre -code converts every whitespace to a row break. It works on my setup, and probably more. Why it doesn’t on OPs setup is however beyond me.
                          sdetweil @broberg
                          @broberg said in Compliments - Multi Line not working?:
                          I see a \n presented on the screen. whenever there is a \n in the compliment string.
                          as in “Hey there\n sexy!”
                          using the backtics, are supposed to allow line continuation across muiltiple lines AND encode a hex 10 (nl) char. but what a pain.
                          var msg=Hey there sexy
                          (note that this doesn’t show here on the forum either.)
                          it MAY be that the actual newline has to be encoded , NOT the text representation of the newline
                           ('\n')
                          the default compliment text strings contains whitespace, where are NOT converted to breaks. so I don’t understand
                          I don’t see any improvement in using the file approach, as its content rules are javascript source rules. not message by line or anything else.
                          to test, I did nothing except install MM and edit the built in messages to add \n (two characters) in various places
                          i see the pre-line class, and read the description, but still haven’t figured out which nl they are discussing.
                          kayakbabeK 1 Reply Last reply Reply Quote 0
                          • kayakbabeK Offline
                            kayakbabe @sdetweil
                            @sdetweil I figured out that your suggestions of encoding the new line worked for me.
                            So, instead of using
                            \n
                            which textNode was treating literally, I tried encoding it and using this
                            \u000A
                            so when I tried the following it looked just like I put it into my morecompliments.json
                            "roses are red\nviolets are blue\nand I need a line\nto start here anew "
                            then I tried
                            "roses are red\u000Aviolets are blue\u000Aand I need a line\u000Ato start here anew "
                            and it displayed like I wanted it to like so…
                            roses are red
                            violets are blue
                            and I need a line
                            to start here anew
                            perhaps this will help others.
                              sdetweil @kayakbabe
                              @kayakbabe crazy. my code splits the line with
                              "\n"
                              the problem was this forum changing the quote from
                              '\n'
                              to
                              ‘\n’
                              notice the curly quotes, those are bad
