    MMM-Assistantmk2 & MMM-Webradio
    help
    4 Posts 2 Posters 1.8k Views 2 Watching
    • L
      Lasmazze
      Good evening,
      I’m new, and I do not know if I’m in the right place. And I do not know anything about codes. :grinning_face_with_smiling_eyes:
      I would like to activate the webradio module via assistantmk2.
      Do I have to create a new recipe in the recipes folder? and how to code it? And do I have to write a command in the config.js file?
      Thank you very much for your help, I hope you understood me and sorry for my english. :winking_face:
      ? 1 Reply Last reply
        A Former User @Lasmazze
        @Lasmazze
        I don’t know about MMM-Webradio. Is that this? https://github.com/MunichStef/MMM_Webradio
        Hmmm. here is some similar code about MMM-Spotify. You can modify this for your purpose.
          transcriptionHook: {
            "START_SPOTIFY" : {
              pattern : "play music",
              command: "START_SPOTIFY"
            "STOP_SPOTIFY" : {
              pattern : "stop music",
              command: "STOP_SPOTIFY"
          command: {
            "START_SPOTIFY": {
              notificationExec: {
                notification: "SPOTIFY_PLAY",
            "STOP_SPOTIFY": {
              notificationExec: {
                notification: "SPOTIFY_PAUSE"
        I believe you can change above codes to things for MMM-Webradio
        For more details; read the docs of modules.
        L 1 Reply Last reply
        • L
          Lasmazze
          Hello,
          Thank you very much for your answer, I will try tonight, I’ll give you news.
          • L
            Lasmazze @Guest
            Spoiler Text
            @Sean
            Yes I use this module well: https://github.com/MunichStef/MMM_Webradio
            I made my code in the config.js as below. The assistantmk2 detects my sentence, it pauses, but nothing happens.
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "fr",
            	timeFormat: 24,
            	units: "metric",
            			module: "compliments",
            			position: "lower_third",
            			   compliments: {
            				  anytime: [
            					 "Bonjour",
            					 "comment vas-tu?"
            				  morning: [
            					 "Bien dormi?",
            					 "Bonne journée!",
            					 "Bonjour!"
            				  evening: [
            					 "Bonne soirée!",
            					 "Repose toi bien!",
            					 "Bonne nuit..."
              module: "MMM_Webradio",
              header: "Webradio",
              position: "bottom_right",
                startindex: 1,
                initialVolume: 50,
                streams: [
                    text: "radio NRJ",
                    url: "http://185.52.127.163/fr/30001/mp3_128.mp3?origine=fluxradios"
            			module: "clock",
            			position: "top_left",	// This can be any of the regions.
            				displayType: "analog",
            				secondsColor: "#ff0000"// The config property is optional.
                        module: "MMM-LocalTemperature",
                        position: "top_right", // Only add a position if you want this module to display the data
                        header: "temperature de la piece",
            				sensorPin: 16,
            				sendTemperature: "true",
            				sendHumidity: "true",
            				showTemperature: "true",
            				showHumidity: "true",
            				iconView: "true",
            				updateInterval: 0.5,
            			module: 'MMM-Screencast',
            			position: 'bottom_right', // This position is for a hidden <div /> and not the screencast window
            				position: 'bottomRight',
            				height: 300,
            				width: 500,
            			module: "MMM-DarkSkyForecast",
            			header: "Weather",
            			classes: "default everyone",
            			disabled: false,
            			  apikey: ",
            			  latitude: "",
            			  longitude: ",
            			  iconset: "4c",
            			  concise: false,
            			  language: "fr",
            			label_timeFormat: "k[h]",
            			label_days: ["Dim", "Lun", "Mar", "Mer", "Jeu", "Ven", "Sam"],
            			  forecastLayout: "table"
              module: "MMM-Hotword",
                chimeOnFinish: null,
                mic: {
                  recordProgram: "arecord",
                  device: "plughw:1"
                models: [
              hotwords: "computer",
              file: "computer.umdl",
              sensitivity: "0.5",
                commands: {
                  "computer": {
                    notificationExec: {
                      notification: "ASSISTANT_ACTIVATE",
                      payload: (detected, afterRecord) => {
                        return {profile:"default"}
                    restart:false,
                    afterRecordLimit:0
            		module: "MMM-AssistantMk2",
            			deviceLocation: {
            				coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
            				latitude:
            				longitude:
            			record: {
            				recordProgram : "arecord",
            				device        : "plughw:1",
            				"START_RADIO" : {
            					pattern : "play radio",
            					command: "RADIO_ONOFF"
            				  "STOP_RADIO" : {
            					pattern : "stop radio",
            				command: {
            				  "START_RADIO": {
            					notificationExec: {
            					  notification: "WEBRADIO_ONOFF",
            				  "STOP_RADIO": {
            					notificationExec: {
              "SHOW_ALL_MODULES": {
                pattern: "show all",
                command: "SHOWMODULES"
              "SCREEN_ON": {
                pattern: "allume l'écran",
                command: "SCREENON"
              "SCREEN_OFF": {
                pattern: "éteins l'écran",
                command: "SCREENOFF"
              "REBOOT": {
                pattern: "redémarre",
                command: "REBOOT"
              "SHUTDOWN": {
                pattern: "éteins le miroir",
                command: "SHUTDOWN"
            			notifications: {
            				ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
            				ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
            				SAY_TEXT: "ASSISTANT_SAY",
            				DEFAULT_HOOK_NOTIFICATION: "ASSISTANT_HOOK",
            				WEBRADIO_ONOFF: "WEBRADIO_ONOFF",
            			screenDuration: 3000,
            			pauseOnYoutube: false,
            			youtubePlayQuality: "small",
            			useWelcomeMessage: "",
            			profiles: {
            				"default" : {
            					lang: "fr-FR"
            Do I have to create a recipe.js in the folder
            MMM-AssistantMk2 / recipes?
