    MMM-SoccerLiveScore
    Scheduled Pinned Locked Moved Sport
    187 Posts 37 Posters 322.3k Views 35 Watching
    • 0m4r0 Offline
      0m4r Module Developer @Egnos
      @Egnos this is now done.
      Please add “scrollVertical: false” into your config for the module.
      (of course, updated it first!)
      Let me know if it works!
      https://github.com/0m4r
      • E Offline
        Egnos @0m4r
        Thanks @0m4r, seems works!
        Sorry for the late reply!
        • E Offline
          Egnos
          Hi all,
          i have these errors refer to the “MMM-SoccerLiveScore” module in “MagicMirror-error.log” file:
          [27.09.2023 18:40.07.575] [ERROR] MMM-SoccerLiveScore doPost URL {
            href: 'https://toralarm.com/api/api/competitions/23/matches/30580909/details',
            origin: 'https://toralarm.com',
            protocol: 'https:',
            username: '',
            password: '',
            host: 'toralarm.com',
            hostname: 'toralarm.com',
            port: '',
            pathname: '/api/api/competitions/23/matches/30580909/details',
            search: '',
            searchParams: URLSearchParams {},
            hash: ''
            method: 'POST',
            gzip: true,
            headers: {
              Host: 'toralarm.com',
              'accept-language': 'en-US,en;q=0.9,it;q=0.8,de-DE;q=0.7,de;q=0.6',
              'content-type': 'application/json;charset=UTF-8'
            body: '{"lng":"it"}'
          } Response {
            timeout: 0,
            [Symbol(Body internals)]: {
              body: Gunzip {
                _writeState: [Uint32Array],
                _readableState: [ReadableState],
                _events: [Object: null prototype],
                _eventsCount: 5,
                _maxListeners: undefined,
                _writableState: [WritableState],
                allowHalfOpen: true,
                bytesWritten: 0,
                _handle: [Zlib],
                _outBuffer: <Buffer 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ... 16334 more bytes>,
                _outOffset: 0,
                _chunkSize: 16384,
                _defaultFlushFlag: 2,
                _finishFlushFlag: 2,
                _defaultFullFlushFlag: 3,
                _info: undefined,
                _maxOutputLength: 1073741823,
                _level: -1,
                _strategy: 0,
                [Symbol(kCapture)]: false,
                [Symbol(kCallback)]: null,
                [Symbol(kError)]: null
              disturbed: false,
              error: null
            [Symbol(Response internals)]: {
              url: 'https://toralarm.com/api/api/competitions/23/matches/30580909/details',
              status: 500,
              statusText: 'Internal Server Error',
              headers: Headers { [Symbol(map)]: [Object: null prototype] },
              counter: 0
          [27.09.2023 18:40.07.577] [ERROR] MMM-SoccerLiveScore getDetails 23 https://toralarm.com/api/api/competitions/23/matches/30580909/details null
          [27.09.2023 18:40.07.592] [ERROR] (node:12212) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading 'filter')
              at forLoop (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:237:54)
              at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
          (Use `electron --trace-warnings ...` to show where the warning was created)
          This is my sw configuration:
          S.O.: Buster
          MM: v2.23.0
          RPI4 4gb
          Is it possible to solve it?
          Thanks.
          0m4r0 1 Reply Last reply Reply Quote 0
          • 0m4r0 Offline
            Hi @Egnos, I am not able to replicate it.
            I can see from the logs it is a server error (500, Internal Server Error).
            This has something to do with the server that provides the data to display.
            Anyway, can show me your config for the module?
            And, have you tried to pull the latest version?
            Thanks - Omar
            • E Offline
              Egnos @0m4r
              Hi @0m4r, this is my RPI configuration:
              • S.O.: Buster
              • MM: v2.23.0 (the 2.24.0 version it gives me some problems…)
              • RPI4 4gb
              Below my module’s configuration:
              		  module: 'MMM-SoccerLiveScore',
              		  position: 'top_right',
              		  //header: 'Live-Scores',
              			leagues: [23],
              			showNames: true,
              			showLogos: true,
              			displayTime: 60 * 1000,
              			showStandings: true,
              			showTables: false,
              			showDetails: true,
              			showScorers: false,
              			scrollVertical: false,
              			language: 'it', // supported values are en, de, it
              Thanks for your help!
              • 0m4r0 Offline
                IMPORTANT UPDATE:
                Following the unavailability of the API used by this module, a new version is under development and available for beta testing.
                If you are interested in trying it out, please follow the steps (they assume you are in the MMM-SoccerLiveScore folder):
                > git checkout beta
                > git pull -r
                > npm ci
                update the configuration as follows:
                  token: "TOKEN",
                  leagues: [LEAGUE_ID_1, LEAGUE_ID_2],
                  displayTime: 1 * 60 * 1000, // 1 minute
                  requestInterval: 10 * 60 * 1000, // 10 minutes
                  showNames: true,
                  showLogos: true,
                  showTables: true,
                  showScorers: true,
                You must obtain the TOKEN from https://www.football-data.org/pricing (there is a free plan too!).
                The list of available leagues you can add to the configuration depends on your subscription plan, the full list of leagues is available here: https://docs.football-data.org/general/v4/lookup_tables.html#_league_codes (you need the competitionId)
                • 0m4r0 0m4r referenced this topic on
                • 0m4r0 Offline
                  The module has been released with its newly delivered version 4.0:
                  https://github.com/0m4r/MMM-SoccerLiveScore
                  Please note that you need to obtain an API key from https://www.football-data.org/pricing (a free plan is also available)
                  • 6
                  • 7
                  • 8
                  • 9
                  • 10
                  • 10 / 10
