    Webcam for MM build?
    27 Posts 5 Posters 13.8k Views 5 Watching
      sdetweil @bumrocks
      @bumrocks the motion log is on /var/log/motion/motion.log
      so u can see what it is doing
      B 1 Reply Last reply
      • B
        bumrocks @sdetweil
        @sdetweil , well my issue of the moment is it will not let me save the changes made to the motion.conf file, arg! I tried to change the files attributes to “anyone” and I get…
        Error setting permissions: Operation not permitted
          sdetweil @bumrocks
          @bumrocks yes, the file is in the etc tree, so u need sudo
          • B
            bumrocks @sdetweil
            @sdetweil , :) Thank you! It appears I have made the necessary changes and will test here shortly! :crossed_fingers_light_skin_tone:
            Ug! I have apparently edited my config file improperly…Message I get after checking it…
            pi@mm2:~/MagicMirror $ npm run config:check
            > magicmirror@2.12.0 config:check /home/pi/MagicMirror
            > node js/check_config.js
            [2020-09-06 01:16:00.192] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
            [2020-09-06 01:16:00.266] [LOG]    Line 101 col 16 Parsing error: Unexpected token below
            /home/pi/MagicMirror/js/check_config.js:66
            			throw new Error("Wrong syntax in config file!");
            Error: Wrong syntax in config file!
                at /home/pi/MagicMirror/js/check_config.js:66:10
                at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.12.0 config:check script.
            npm ERR!     /home/pi/.npm/_logs/2020-09-06T07_16_00_294Z-debug.log
            Here are the lines in question…
                module: 'MMM-SleepWake',
                delay:  15,               // default
                source: 'external',
                mode:  see below,
                 // detectionDir: folder containing externally generated file when motion starts
                 //               will be created if needed
                 // detectionFile:  filename generated for motion start. default = 'detected'
            “mode: see below,” is line 101 as referenced in file check above…
              sdetweil @bumrocks
              @bumrocks you are missing
              config:{
              after the module:
              line
              • B
                bumrocks @sdetweil
                @sdetweil , my apologies for not thanking you sooner! I have too many "projects in the works at any given moment and I caved to my frustration with the mirror and took a break. Intended to be a present to my wife, I am now hoping that I can get this the way I want before her birthday comes around again facepalm
                Anyways, I am back to being committed and frustration slaps me in the face immediately…I added the line that was missing (not sure how I did that when I copy and pasted it to begin with) and now I get this error…
                [2020-10-01 23:26:22.548] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                [2020-10-01 23:26:24.211] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                npm ERR! errno 1
                npm ERR!
                npm ERR!     /home/pi/.npm/_logs/2020-10-02T05_26_24_231Z-debug.log
                Here is my config file from top to bottom as it is now…
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	ipWhitelist: [], // Set [] to allow all IP addresses
                	language: "en",
                	timeFormat: 24,
                	units: "imperial",
                			     // false, default for all  NON-armv6l devices
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check",
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                			module: "currentweather",
                				locationID: "5417598", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				appid: "cf2de0d28398c756b6bad589d8e33c2a"
                			module: "weatherforecast",
                			header: "Weather Forecast",
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "BBC Top News Stories",
                						url: "http://feeds.bbci.co.uk/news/rss.xml"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                    config:{
                       mode:  Hide
                Lastly, did I understand that if I am using an energy star lcd tv with floating “no signal” message when Pi is off that I should use "mode: Hide " ?
                  sdetweil @bumrocks
                  @bumrocks general rules
                  the thing on the left of : does not need quotes
                  if the thing to the right of : is a number or true/false, also does not need quotes
                  if the thing to the right of : has letters in it, then it needs quotes, either kind are ok, but must be the same
                  yes, if the monitor/tv has the ugly no signal/connection, then u want to use hide
