    Webcam for MM build?
    27 Posts 5 Posters 13.8k Views 5 Watching
    • TeaT
      Tea
      • G
        guongthongminh @sdetweil
        @sdetweil tôi phát hiện rằng camera của tôi không được mở.
        Tôi nghĩ module tự ngắt kết nối màn hình sau 1 khoảng thời gian và không tự kết nối màn hình lại được. (Tôi đã thêm các lệnh theo README.md)
          sdetweil @guongthongminh
          @guongthongminh see the readme of the module
          https://github.com/sdetweil/MMM-SleepWake/blob/master/README.md#usage
          It tells u how to configure the motion detector to wake up the mirror
          G 2 Replies Last reply
          • G
            I did like this in motion.conf
            alt text
            • G
              I found this further so you can help me!
              alt text
              S 2 Replies Last reply
                @guongthongminh sorry, hang on… they started enforcing specific api call formats…
                  @guongthongminh do this to update the module
                  cd ~/MagicMirror/modules/MMM-SleepWake
                  git pull
                  the restart the mirror
                  G 1 Reply Last reply
                  • G
                    I tried it but the result is still the same. Hope you help!
                    alt text
                      @guongthongminh said in Webcam for MM build?:
                      that is not an error, just a message to tell you where motion events will go
                        bumrocks @sdetweil
                        @sdetweil , I am unclear where or how to turn off recording images and video and where the “start/stop” commands are noted within the module instructions…
                        I want to use my logitech usb camera for mic control and the camera for detection as well. I have already installed your sleepwake module as well…Just need it all configured at this point and struggling on my own, apparently…
                        Also note, in my /usr/share/doc/motion/ it does not contain a motion_guide.html
                        Here is my config file…
                        Edited to reflect that I believe I made the changes you mention on your SleepWake page to the motion file…
                        # Rename this distribution example file to motion.conf
                        # This config file was generated by motion 4.1.1
                        # Documentation:  /usr/share/doc/motion/motion_guide.html
                        # Daemon
                        # Start in daemon (background) mode and release terminal (default: off)
                        daemon off
                        # File to store the process ID, also called pid file. (default: not defined)
                        process_id_file /var/run/motion/motion.pid
                        # Basic Setup Mode
                        # Start in Setup-Mode, daemon disabled. (default: off)
                        setup_mode off
                        # Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
                        logfile /var/log/motion/motion.log
                        # Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
                        log_level 6
                        # Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
                        log_type all
                        # Capture device options
                        # Videodevice to be used for capturing  (default /dev/video0)
                        # for FreeBSD default is /dev/bktr0
                        videodevice /dev/video0
                        # v4l2_palette allows one to choose preferable palette to be use by motion
                        # See motion_guide.html for the valid options and values.  (default: 17)
                        v4l2_palette 17
                        # Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
                        # This is ONLY used for FreeBSD. Leave it commented out for Linux
                        ; tunerdevice /dev/tuner0
                        # The video input to be used (default: -1)
                        # Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
                        # Set to 0 for uvideo(4) on OpenBSD
                        input -1
                        # The video norm to use (only for video capture and TV tuner cards)
                        # Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
                        norm 0
                        # The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
                        frequency 0
                        # Override the power line frequency for the webcam. (normally not necessary)
                        # Values:
                        # -1 : Do not modify device setting
                        # 0  : Power line frequency Disabled
                        # 1  : 50hz
                        # 2  : 60hz
                        # 3  : Auto
                        power_line_frequency -1
                        # Rotate image this number of degrees. The rotation affects all saved images as
                        # well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
                        rotate 0
                        # Flip image over a given axis (vertical or horizontal), vertical means from left to right
                        # horizontal means top to bottom. Valid values: none, v and h.
                        flip_axis none
                        # Image width (pixels). Valid range: Camera dependent, default: 320
                        width 320
                        # Image height (pixels). Valid range: Camera dependent, default: 240
                        height 240
                        # Maximum number of frames to be captured per second.
                        # Valid range: 2-100. Default: 100 (almost no limit).
                        framerate 2
                        # Minimum time in seconds between capturing picture frames from the camera.
                        # Default: 0 = disabled - the capture rate is given by the camera framerate.
                        # This option is used when you want to capture images at a rate lower than 2 per second.
                        minimum_frame_time 0
                        # Full Network Camera URL.  Valid Services: http:// ftp:// mjpg:// rtsp:// mjpeg:// file:// rtmp://
                        ; netcam_url value
                        # Username and password for network camera if required. Syntax is user:password
                        ; netcam_userpass value
                        # The setting for keep-alive of network socket, should improve performance on compatible net cameras.
                        # off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
                        # force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
                        # on:    Use HTTP/1.1 requests that support keep alive as default.
                        # Default: off
                        netcam_keepalive off
                        # URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
                        # If a port number other than 80 is needed, use "http://myproxy:1234".
                        # Default: not defined
                        ; netcam_proxy value
                        # Set less strict jpeg checks for network cameras with a poor/buggy firmware.
                        # Default: off
                        netcam_tolerant_check off
                        # RTSP connection uses TCP to communicate to the camera. Can prevent image corruption.
                        # Default: on
                        rtsp_uses_tcp on
                        # Name of camera to use if you are using a camera accessed through OpenMax/MMAL
                        # Default: Not defined
                        ; mmalcam_name vc.ril.camera
                        # Camera control parameters (see raspivid/raspistill tool documentation)
                        ; mmalcam_control_params -hf
                        # Let motion regulate the brightness of a video device (default: off).
                        # The auto_brightness feature uses the brightness option as its target value.
                        # If brightness is zero auto_brightness will adjust to average brightness value 128.
                        # Only recommended for cameras without auto brightness
                        auto_brightness off
                        # Set the initial brightness of a video device.
                        # If auto_brightness is enabled, this value defines the average brightness level
                        # which Motion will try and adjust to.
                        # Valid range 0-255, default 0 = disabled
                        brightness 0
                        # Set the contrast of a video device.
                        contrast 0
                        # Set the saturation of a video device.
                        saturation 0
                        # Set the hue of a video device (NTSC feature).
                        hue 0
                        # Round Robin (multiple inputs on same video device name)
                        # Number of frames to capture in each roundrobin step (default: 1)
                        roundrobin_frames 1
                        # Number of frames to skip before each roundrobin step (default: 1)
                        roundrobin_skip 1
                        # Try to filter out noise generated by roundrobin (default: off)
                        switchfilter off
                        # Motion Detection Settings:
                        # Threshold for number of changed pixels in an image that
                        # triggers motion detection (default: 1500)
                        threshold 1500
                        # Automatically tune the threshold down if possible (default: off)
                        threshold_tune off
                        # Noise threshold for the motion detection (default: 32)
                        noise_level 32
                        # Automatically tune the noise threshold (default: on)
                        noise_tune on
                        # Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
                        # Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
                        # (l)abeling must only be used once and the 'l' must be the last letter.
                        # Comment out to disable
                        despeckle_filter EedDl
                        # Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
                        # A script (on_area_detected) is started immediately when motion is         4 5 6
                        # detected in one of the given areas, but only once during an event.        7 8 9
                        # One or more areas can be specified with this option. Take care: This option
                        # does NOT restrict detection to these areas! (Default: not defined)
                        ; area_detect value
                        # PGM file to use as a sensitivity mask.
                        # Full path name to. (Default: not defined)
                        ; mask_file value
                        # PGM file to completely mask out a area of image.
                        # mask_privacy value
                        # Dynamically create a mask file during operation (default: 0)
                        # Adjust speed of mask changes from 0 (off) to 10 (fast)
                        smart_mask_speed 0
                        # Ignore sudden massive light intensity changes given as a percentage of the picture
                        # area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
                        lightswitch 0
                        # Picture frames must contain motion at least the specified number of frames
                        # in a row before they are detected as true motion. At the default of 1, all
                        # motion is detected. Valid range: 1 to thousands, recommended 1-5
                        minimum_motion_frames 1
                        # Specifies the number of pre-captured (buffered) pictures from before motion
                        # was detected that will be output at motion detection.
                        # Recommended range: 0 to 5 (default: 0)
                        # Do not use large values! Large values will cause Motion to skip video frames and
                        # cause unsmooth movies. To smooth movies use larger values of post_capture instead.
                        pre_capture 0
                        # Number of frames to capture after motion is no longer detected (default: 0)
                        post_capture 0
                        # Event Gap is the seconds of no motion detection that triggers the end of an event.
                        # An event is defined as a series of motion images taken within a short timeframe.
                        # Recommended value is 60 seconds (Default). The value -1 is allowed and disables
                        # events causing all Motion to be written to one single movie file and no pre_capture.
                        # If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
                        # event ends right after no more motion is detected and post_capture is over.
                        event_gap 60
                        # Maximum length in seconds of a movie
                        # When value is exceeded a new movie file is created. (Default: 0 = infinite)
                        max_movie_time 0
                        # Always save images even if there was no motion (default: off)
                        emulate_motion off
                        # Image File Output
                        # Output 'normal' pictures when motion is detected (default: off)
                        # Valid values: on, off, first, best, center
                        # When set to 'first', only the first picture of an event is saved.
                        # Picture with most motion of an event is saved when set to 'best'.
                        # Picture with motion nearest center of picture is saved when set to 'center'.
                        # Can be used as preview shot for the corresponding movie.
                        output_pictures off
                        # Output pictures with only the pixels moving object (ghost images) (default: off)
                        output_debug_pictures off
                        # The quality (in percent) to be used by the jpeg and webp compression (default: 75)
                        quality 75
                        # Type of output images
                        # Valid values: jpeg, ppm or webp (default: jpeg)
                        picture_type jpeg
                        # Use ffmpeg to encode videos of motion (default: off)
                        ffmpeg_output_movies on
                        # Use ffmpeg to make videos showing the moving pixels (ghost images) (default: off)
                        ffmpeg_output_debug_movies off
                        # Bitrate to be used by the ffmpeg encoder (default: 400000)
                        # This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
                        ffmpeg_bps 400000
                        # Enables and defines variable bitrate for the ffmpeg encoder.
                        # ffmpeg_bps is ignored if variable bitrate is enabled.
                        # Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
                        # or the range 1 - 100 where 1 means worst quality and 100 is best.
                        ffmpeg_variable_bitrate 0
                        # Container/Codec output videos
                        # Valid values: mpeg4, msmpeg4, swf,flv, ffv1, mov, mp4, mkv, hevc
                        ffmpeg_video_codec mkv
                        # When creating videos, should frames be duplicated in order
                        # to keep up with the requested frames per second
                        # (default: true)
                        ffmpeg_duplicate_frames true
                        # Interval in seconds between timelapse captures.  Default: 0 = off
                        timelapse_interval 0
                        # Timelapse file rollover mode. See motion_guide.html for options and uses.
                        timelapse_mode daily
                        # Frame rate for timelapse playback
                        timelapse_fps 30
                        # Container/Codec for timelapse video. Valid values: mpg or mpeg4
                        timelapse_codec mpg
                        # External pipe to video encoder
                        # Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
                        # The options movie_filename and timelapse_filename are also used
                        # by the ffmpeg feature
                        # Bool to enable or disable extpipe (default: off)
                        use_extpipe off
                        # External program (full path and opts) to pipe raw video to
                        # Generally, use '-' for STDIN...
                        ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
                        ;extpipe x264 - --input-res %wx%h --fps %fps --bitrate 2000 --preset ultrafast --quiet -o %f.mp4
                        ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:fps=%fps -ovc x264 -x264encopts preset=ultrafast -of lavf -o %f.mp4 - -fps %fps
                        ;extpipe ffmpeg -y -f rawvideo -pix_fmt yuv420p -video_size %wx%h -framerate %fps -i pipe:0 -vcodec libx264 -preset ultrafast -f mp4 %f.mp4
                        # Snapshots (Traditional Periodic Webcam File Output)
                        # Make automated snapshot every N seconds (default: 0 = disabled)
                        snapshot_interval 0
                        # Text Display
                        # %Y = year, %m = month, %d = date,
                        # %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
                        # %v = event, %q = frame number, %t = camera id number,
                        # %D = changed pixels, %N = noise level, \n = new line,
                        # %i and %J = width and height of motion area,
                        # %K and %L = X and Y coordinates of motion center
                        # %C = value defined by text_event - do not use with text_event!
                        # You can put quotation marks around the text to allow
                        # leading spaces
                        # Locate and draw a box around the moving object.
                        # Valid values: on, off, preview (default: off)
                        # Set to 'preview' will only draw a box in preview_shot pictures.
                        locate_motion_mode off
                        # Set the look and style of the locate box if enabled.
                        # Valid values: box, redbox, cross, redcross (default: box)
                        # Set to 'box' will draw the traditional box.
                        # Set to 'redbox' will draw a red box.
                        # Set to 'cross' will draw a little cross to mark center.
                        # Set to 'redcross' will draw a little red cross to mark center.
                        locate_motion_style box
                        # Draws the timestamp using same options as C function strftime(3)
                        # Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
                        # Text is placed in lower right corner
                        text_right %Y-%m-%d\n%T-%q
                        # Draw a user defined text on the images using same options as C function strftime(3)
                        # Default: Not defined = no text
                        # Text is placed in lower left corner
                        ; text_left CAMERA %t
                        # Draw the number of changed pixed on the images (default: off)
                        # Will normally be set to off except when you setup and adjust the motion settings
                        # Text is placed in upper right corner
                        text_changes off
                        # This option defines the value of the special event conversion specifier %C
                        # You can use any conversion specifier in this option except %C. Date and time
                        # values are from the timestamp of the first image in the current event.
                        # Default: %Y%m%d%H%M%S
                        # The idea is that %C can be used filenames and text_left/right for creating
                        # a unique identifier for each event.
                        text_event %Y%m%d%H%M%S
                        # Draw characters at twice normal size on images. (default: off)
                        text_double off
                        # Text to include in a JPEG EXIF comment
                        # May be any text, including conversion specifiers.
                        # The EXIF timestamp is included independent of this text.
                        ;exif_text %i%J/%K%L
                        # Target Directories and filenames For Images And Films
                        # For the options snapshot_, picture_, movie_ and timelapse_filename
                        # you can use conversion specifiers
                        # Quotation marks round string are allowed.
                        # Target base directory for pictures and films
                        # Recommended to use absolute path. (Default: current working directory)
                        target_dir /var/lib/motion
                        # File path for snapshots (jpeg, ppm or webp) relative to target_dir
                        # Default: %v-%Y%m%d%H%M%S-snapshot
                        # Default value is equivalent to legacy oldlayout option
                        # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
                        # File extension .jpg, .ppm or .webp is automatically added so do not include this.
                        # Note: A symbolic link called lastsnap.jpg created in the target_dir will always
                        # point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
                        snapshot_filename %v-%Y%m%d%H%M%S-snapshot
                        # File path for motion triggered images (jpeg, ppm or .webp) relative to target_dir
                        # Default: %v-%Y%m%d%H%M%S-%q
                        # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
                        # Set to 'preview' together with best-preview feature enables special naming
                        # convention for preview shots. See motion guide for details
                        picture_filename %v-%Y%m%d%H%M%S-%q
                        # File path for motion triggered ffmpeg films (movies) relative to target_dir
                        # File extensions(.mpg .avi) are automatically added so do not include them
                        movie_filename %v-%Y%m%d%H%M%S
                        # File path for timelapse movies relative to target_dir
                        # Default: %Y%m%d-timelapse
                        timelapse_filename %Y%m%d-timelapse
                        # Global Network Options
                        # Enable IPv6 (default: off)
                        ipv6_enabled off
                        # Live Stream Server
                        # The mini-http server listens to this port for requests (default: 0 = disabled)
                        stream_port 8081
                        # 50% scaled down substream (default: 0 = disabled)
                        # substream_port 8082
                        # Quality of the jpeg (in percent) images produced (default: 50)
                        stream_quality 50
                        # Output frames at 1 fps when no motion is detected and increase to the
                        # rate given by stream_maxrate when motion is detected (default: off)
                        stream_motion off
                        # Maximum framerate for stream streams (default: 1)
                        stream_maxrate 1
                        # Restrict stream connections to localhost only (default: on)
                        stream_localhost on
                        # Limits the number of images per connection (default: 0 = unlimited)
                        # Number can be defined by multiplying actual stream rate by desired number of seconds
                        # Actual stream rate is the smallest of the numbers framerate and stream_maxrate
                        stream_limit 0
                        # Set the authentication method (default: 0)
                        # 0 = disabled
                        # 1 = Basic authentication
                        # 2 = MD5 digest (the safer authentication)
                        stream_auth_method 0
                        # Authentication for the stream. Syntax username:password
                        # Default: not defined (Disabled)
                        ; stream_authentication username:password
                        # Percentage to scale the stream image for preview
                        # This is scaled on the browser side, motion will keep sending full frames
                        # Default: 25
                        ; stream_preview_scale 25
                        # Have stream preview image start on a new line
                        # Default: no
                        ; stream_preview_newline no
                        # HTTP Based Control
                        # TCP/IP port for the http server to listen on (default: 0 = disabled)
                        webcontrol_port 8080
                        # Restrict control connections to localhost only (default: on)
                        webcontrol_localhost on
                        # Output for http server, select off to choose raw text plain (default: on)
                        webcontrol_html_output on
                        # Authentication for the http based control. Syntax username:password
                        ; webcontrol_authentication username:password
                        # Parameters to include on webcontrol.  0=none, 1=limited, 2=advanced, 3=restricted
                        # Default: 0 (none)
                        webcontrol_parms 0
                        # Tracking (Pan/Tilt)
                        # Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
                        # The generic type enables the definition of motion center and motion size to
                        # be used with the conversion specifiers for options like on_motion_detected
                        track_type 0
                        # Enable auto tracking (default: off)
                        track_auto off
                        # Serial port of motor (default: none)
                        ;track_port /dev/ttyS0
                        # Motor number for x-axis (default: 0)
                        ;track_motorx 0
                        # Set motorx reverse (default: 0)
                        ;track_motorx_reverse 0
                        # Motor number for y-axis (default: 0)
                        ;track_motory 1
                        # Set motory reverse (default: 0)
                        ;track_motory_reverse 0
                        # Maximum value on x-axis (default: 0)
                        ;track_maxx 200
                        # Minimum value on x-axis (default: 0)
                        ;track_minx 50
                        # Maximum value on y-axis (default: 0)
                        ;track_maxy 200
                        # Minimum value on y-axis (default: 0)
                        ;track_miny 50
                        # Center value on x-axis (default: 0)
                        ;track_homex 128
                        # Center value on y-axis (default: 0)
                        ;track_homey 128
                        # ID of an iomojo camera if used (default: 0)
                        track_iomojo_id 0
                        # Angle in degrees the camera moves per step on the X-axis
                        # with auto-track (default: 10)
                        # Currently only used with pwc type cameras
                        track_step_angle_x 10
                        # Angle in degrees the camera moves per step on the Y-axis
                        track_step_angle_y 10
                        # Delay to wait for after tracking movement as number
                        # of picture frames (default: 10)
                        track_move_wait 10
                        # Speed to set the motor to (stepper motor option) (default: 255)
                        track_speed 255
                        # Number of steps to make (stepper motor option) (default: 40)
                        track_stepsize 40
                        # External Commands, Warnings and Logging:
                        # You can use conversion specifiers for the on_xxxx commands
                        # %f = filename with full path
                        # %n = number indicating filetype
                        # Both %f and %n are only defined for on_picture_save,
                        # on_movie_start and on_movie_end
                        # Do not sound beeps when detecting motion (default: on)
                        # Note: Motion never beeps when running in daemon mode.
                        quiet on
                        # Command to be executed when an event starts. (default: none)
                        # An event starts at first motion detected after a period of no motion defined by event_gap
                        ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                        # Command to be executed when an event ends after a period of no motion
                        # (default: none). The period of no motion is defined by option event_gap.
                        ; on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                        # Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
                        # To give the filename as an argument to a command append it with %f
                        ; on_picture_save value
                        # Command to be executed when a motion frame is detected (default: none)
                        ; on_motion_detected value
                        # Command to be executed when motion in a predefined area is detected
                        # Check option 'area_detect'.   (default: none)
                        ; on_area_detected value
                        # Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
                        ; on_movie_start value
                        # Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
                        ; on_movie_end value
                        # Command to be executed when a camera can't be opened or if it is lost
                        # NOTE: There is situations when motion don't detect a lost camera!
                        # It depends on the driver, some drivers dosn't detect a lost camera at all
                        # Some hangs the motion thread. Some even hangs the PC! (default: none)
                        ; on_camera_lost value
                        # Command to be executed when a camera that was lost has been found (default: none)
                        # NOTE: If motion doesn't properly detect a lost camera, it also won't know it found one.
                        ; on_camera_found value
                        # Common Options for database features.
                        # Options require database options to be active also.
                        # Log to the database when creating motion triggered picture file  (default: on)
                        ; sql_log_picture on
                        # Log to the database when creating a snapshot image file (default: on)
                        ; sql_log_snapshot on
                        # Log to the database when creating motion triggered movie file (default: off)
                        ; sql_log_movie off
                        # Log to the database when creating timelapse movies file (default: off)
                        ; sql_log_timelapse off
                        # SQL query string that is sent to the database
                        # Use same conversion specifiers has for text features
                        # Additional special conversion specifiers are
                        # %n = the number representing the file_type
                        # Default value:
                        # Create tables :
                        # Mysql
                        # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
                        # Postgresql
                        # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
                        # insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
                        ; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
                        # Database Options
                        # database type : mysql, postgresql, sqlite3 (default : not defined)
                        ; database_type value
                        # database to log to (default: not defined)
                        # for sqlite3, the full path and name for the database.
                        ; database_dbname value
                        # The host on which the database is located (default: localhost)
                        ; database_host value
                        # User account name for database (default: not defined)
                        ; database_user value
                        # User password for database (default: not defined)
                        ; database_password value
                        # Port on which the database is located
                        #  mysql 3306 , postgresql 5432 (default: not defined)
                        ; database_port value
                        # Database wait time in milliseconds for locked database to
                        # be unlocked before returning database locked error (default 0)
                        ; database_busy_timeout 0
                        # Video Loopback Device (vloopback project)
                        # Output images to a video4linux loopback device
                        # Specify the device associated with the loopback device
                        # For example /dev/video1 (default: not defined)
                        ; video_pipe value
                        # Output motion images to a video4linux loopback device
                        ; motion_video_pipe value
                        # camera config files - One for each camera.
                        # Except if only one camera - You only need this config file.
                        # If you have more than one camera you MUST define one camera
                        # config file for each camera in addition to this config file.
                        # Remember: If you have more than one camera you must have one
                        # camera file for each camera. E.g. 2 cameras requires 3 files:
                        # This motion.conf file AND camera1.conf and camera2.conf.
                        # Only put the options that are unique to each camera in the
                        # camera config files.
                        ; camera /etc/motion/camera1.conf
                        ; camera /etc/motion/camera2.conf
                        ; camera /etc/motion/camera3.conf
                        ; camera /etc/motion/camera4.conf
                        # Camera config directory
                        # Any files ending in '.conf' in this directory will be read
                        # as a camera config file.
                        ; camera_dir /etc/motion/conf.d
                          sdetweil @bumrocks
                          @bumrocks the start/ stop events are coded in the module doc here
                          https://raw.githubusercontent.com/sdetweil/MMM-SleepWake/master/README.md
                          like this (motion.conf lines)
                          u need to remove the ; to uncomment them in the motion.conf
                          u have to put the right path there, {user} is just a placeholder
                          movies
                          ffmpeg off
                          images I think are off by default
                          you may also want to change the event gap ( time between motion start and reporting motion stop) I have mine set to 15 seconds. defaults to 60 ( 1 minute)
                          also lightflash in case you turn on the room lights. is this motion by itself? I have that turned off
                          and also motion_frames, how many consecutives frames at 60/second should have motion before reporting… I have mine set to 2.
                            sdetweil @bumrocks
                            @bumrocks the motion log is on /var/log/motion/motion.log
                            so u can see what it is doing
                            B 1 Reply Last reply
                              bumrocks @sdetweil
                              @sdetweil , well my issue of the moment is it will not let me save the changes made to the motion.conf file, arg! I tried to change the files attributes to “anyone” and I get…
                              Error setting permissions: Operation not permitted
                                sdetweil @bumrocks
                                @bumrocks yes, the file is in the etc tree, so u need sudo
                                  bumrocks @sdetweil
                                  @sdetweil , :) Thank you! It appears I have made the necessary changes and will test here shortly! :crossed_fingers_light_skin_tone:
                                  Ug! I have apparently edited my config file improperly…Message I get after checking it…
                                  pi@mm2:~/MagicMirror $ npm run config:check
                                  > magicmirror@2.12.0 config:check /home/pi/MagicMirror
                                  > node js/check_config.js
                                  [2020-09-06 01:16:00.192] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                                  [2020-09-06 01:16:00.266] [LOG]    Line 101 col 16 Parsing error: Unexpected token below
                                  /home/pi/MagicMirror/js/check_config.js:66
                                  			throw new Error("Wrong syntax in config file!");
                                  Error: Wrong syntax in config file!
                                      at /home/pi/MagicMirror/js/check_config.js:66:10
                                      at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 1
                                  npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                                  npm ERR!     /home/pi/.npm/_logs/2020-09-06T07_16_00_294Z-debug.log
                                  Here are the lines in question…
                                      module: 'MMM-SleepWake',
                                      delay:  15,               // default
                                      source: 'external',
                                      mode:  see below,
                                       // detectionDir: folder containing externally generated file when motion starts
                                       //               will be created if needed
                                       // detectionFile:  filename generated for motion start. default = 'detected'
                                  “mode: see below,” is line 101 as referenced in file check above…
                                    sdetweil @bumrocks
                                    @bumrocks you are missing
                                    config:{
                                    after the module:
                                    line
                                      bumrocks @sdetweil
                                      @sdetweil , my apologies for not thanking you sooner! I have too many "projects in the works at any given moment and I caved to my frustration with the mirror and took a break. Intended to be a present to my wife, I am now hoping that I can get this the way I want before her birthday comes around again facepalm
                                      Anyways, I am back to being committed and frustration slaps me in the face immediately…I added the line that was missing (not sure how I did that when I copy and pasted it to begin with) and now I get this error…
                                      [2020-10-01 23:26:22.548] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                                      [2020-10-01 23:26:24.211] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                                      npm ERR! errno 1
                                      npm ERR!
                                      npm ERR!     /home/pi/.npm/_logs/2020-10-02T05_26_24_231Z-debug.log
                                      Here is my config file from top to bottom as it is now…
                                      /* Magic Mirror Config Sample
                                       * MIT Licensed.
                                      var config = {
                                      	port: 8080,
                                      	ipWhitelist: [], // Set [] to allow all IP addresses
                                      	language: "en",
                                      	timeFormat: 24,
                                      	units: "imperial",
                                      			     // false, default for all  NON-armv6l devices
                                      			module: "alert",
                                      			module: "updatenotification",
                                      			position: "top_bar"
                                      			module: "clock",
                                      			position: "top_left"
                                      			header: "US Holidays",
                                      						symbol: "calendar-check",
                                      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                      			module: "currentweather",
                                      				locationID: "5417598", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                      				appid: "cf2de0d28398c756b6bad589d8e33c2a"
                                      			module: "weatherforecast",
                                      			header: "Weather Forecast",
                                      			module: "newsfeed",
                                      			position: "bottom_bar",
                                      				feeds: [
                                      						title: "BBC Top News Stories",
                                      						url: "http://feeds.bbci.co.uk/news/rss.xml"
                                      				showSourceTitle: true,
                                      				showPublishDate: true,
                                      				broadcastNewsFeeds: true,
                                      				broadcastNewsUpdates: true
                                          config:{
                                             mode:  Hide
                                      Lastly, did I understand that if I am using an energy star lcd tv with floating “no signal” message when Pi is off that I should use "mode: Hide " ?
                                        sdetweil @bumrocks
                                        @bumrocks general rules
                                        the thing on the left of : does not need quotes
                                        if the thing to the right of : is a number or true/false, also does not need quotes
                                        if the thing to the right of : has letters in it, then it needs quotes, either kind are ok, but must be the same
                                        yes, if the monitor/tv has the ugly no signal/connection, then u want to use hide
