    Webcam for MM build?
    27 Posts 5 Posters 13.7k Views 5 Watching
    • G
      guongthongminh @sdetweil
      I tried it but the result is still the same. Hope you help!
      alt text
        sdetweil @guongthongminh
        @guongthongminh said in Webcam for MM build?:
        that is not an error, just a message to tell you where motion events will go
          bumrocks @sdetweil
          @sdetweil , I am unclear where or how to turn off recording images and video and where the “start/stop” commands are noted within the module instructions…
          I want to use my logitech usb camera for mic control and the camera for detection as well. I have already installed your sleepwake module as well…Just need it all configured at this point and struggling on my own, apparently…
          Also note, in my /usr/share/doc/motion/ it does not contain a motion_guide.html
          Here is my config file…
          Edited to reflect that I believe I made the changes you mention on your SleepWake page to the motion file…
          # Rename this distribution example file to motion.conf
          # This config file was generated by motion 4.1.1
          # Documentation:  /usr/share/doc/motion/motion_guide.html
          # Daemon
          # Start in daemon (background) mode and release terminal (default: off)
          daemon off
          # File to store the process ID, also called pid file. (default: not defined)
          process_id_file /var/run/motion/motion.pid
          # Basic Setup Mode
          # Start in Setup-Mode, daemon disabled. (default: off)
          setup_mode off
          # Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
          logfile /var/log/motion/motion.log
          # Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
          log_level 6
          # Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
          log_type all
          # Capture device options
          # Videodevice to be used for capturing  (default /dev/video0)
          # for FreeBSD default is /dev/bktr0
          videodevice /dev/video0
          # v4l2_palette allows one to choose preferable palette to be use by motion
          # See motion_guide.html for the valid options and values.  (default: 17)
          v4l2_palette 17
          # Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
          # This is ONLY used for FreeBSD. Leave it commented out for Linux
          ; tunerdevice /dev/tuner0
          # The video input to be used (default: -1)
          # Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
          # Set to 0 for uvideo(4) on OpenBSD
          input -1
          # The video norm to use (only for video capture and TV tuner cards)
          # Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
          norm 0
          # The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
          frequency 0
          # Override the power line frequency for the webcam. (normally not necessary)
          # Values:
          # -1 : Do not modify device setting
          # 0  : Power line frequency Disabled
          # 1  : 50hz
          # 2  : 60hz
          # 3  : Auto
          power_line_frequency -1
          # Rotate image this number of degrees. The rotation affects all saved images as
          # well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
          rotate 0
          # Flip image over a given axis (vertical or horizontal), vertical means from left to right
          # horizontal means top to bottom. Valid values: none, v and h.
          flip_axis none
          # Image width (pixels). Valid range: Camera dependent, default: 320
          width 320
          # Image height (pixels). Valid range: Camera dependent, default: 240
          height 240
          # Maximum number of frames to be captured per second.
          # Valid range: 2-100. Default: 100 (almost no limit).
          framerate 2
          # Minimum time in seconds between capturing picture frames from the camera.
          # Default: 0 = disabled - the capture rate is given by the camera framerate.
          # This option is used when you want to capture images at a rate lower than 2 per second.
          minimum_frame_time 0
          # Full Network Camera URL.  Valid Services: http:// ftp:// mjpg:// rtsp:// mjpeg:// file:// rtmp://
          ; netcam_url value
          # Username and password for network camera if required. Syntax is user:password
          ; netcam_userpass value
          # The setting for keep-alive of network socket, should improve performance on compatible net cameras.
          # off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
          # force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
          # on:    Use HTTP/1.1 requests that support keep alive as default.
          # Default: off
          netcam_keepalive off
          # URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
          # If a port number other than 80 is needed, use "http://myproxy:1234".
          # Default: not defined
          ; netcam_proxy value
          # Set less strict jpeg checks for network cameras with a poor/buggy firmware.
          # Default: off
          netcam_tolerant_check off
          # RTSP connection uses TCP to communicate to the camera. Can prevent image corruption.
          # Default: on
          rtsp_uses_tcp on
          # Name of camera to use if you are using a camera accessed through OpenMax/MMAL
          # Default: Not defined
          ; mmalcam_name vc.ril.camera
          # Camera control parameters (see raspivid/raspistill tool documentation)
          ; mmalcam_control_params -hf
          # Let motion regulate the brightness of a video device (default: off).
          # The auto_brightness feature uses the brightness option as its target value.
          # If brightness is zero auto_brightness will adjust to average brightness value 128.
          # Only recommended for cameras without auto brightness
          auto_brightness off
          # Set the initial brightness of a video device.
          # If auto_brightness is enabled, this value defines the average brightness level
          # which Motion will try and adjust to.
          # Valid range 0-255, default 0 = disabled
          brightness 0
          # Set the contrast of a video device.
          contrast 0
          # Set the saturation of a video device.
          saturation 0
          # Set the hue of a video device (NTSC feature).
          hue 0
          # Round Robin (multiple inputs on same video device name)
          # Number of frames to capture in each roundrobin step (default: 1)
          roundrobin_frames 1
          # Number of frames to skip before each roundrobin step (default: 1)
          roundrobin_skip 1
          # Try to filter out noise generated by roundrobin (default: off)
          switchfilter off
          # Motion Detection Settings:
          # Threshold for number of changed pixels in an image that
          # triggers motion detection (default: 1500)
          threshold 1500
          # Automatically tune the threshold down if possible (default: off)
          threshold_tune off
          # Noise threshold for the motion detection (default: 32)
          noise_level 32
          # Automatically tune the noise threshold (default: on)
          noise_tune on
          # Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
          # Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
          # (l)abeling must only be used once and the 'l' must be the last letter.
          # Comment out to disable
          despeckle_filter EedDl
          # Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
          # A script (on_area_detected) is started immediately when motion is         4 5 6
          # detected in one of the given areas, but only once during an event.        7 8 9
          # One or more areas can be specified with this option. Take care: This option
          # does NOT restrict detection to these areas! (Default: not defined)
          ; area_detect value
          # PGM file to use as a sensitivity mask.
          # Full path name to. (Default: not defined)
          ; mask_file value
          # PGM file to completely mask out a area of image.
          # mask_privacy value
          # Dynamically create a mask file during operation (default: 0)
          # Adjust speed of mask changes from 0 (off) to 10 (fast)
          smart_mask_speed 0
          # Ignore sudden massive light intensity changes given as a percentage of the picture
          # area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
          lightswitch 0
          # Picture frames must contain motion at least the specified number of frames
          # in a row before they are detected as true motion. At the default of 1, all
          # motion is detected. Valid range: 1 to thousands, recommended 1-5
          minimum_motion_frames 1
          # Specifies the number of pre-captured (buffered) pictures from before motion
          # was detected that will be output at motion detection.
          # Recommended range: 0 to 5 (default: 0)
          # Do not use large values! Large values will cause Motion to skip video frames and
          # cause unsmooth movies. To smooth movies use larger values of post_capture instead.
          pre_capture 0
          # Number of frames to capture after motion is no longer detected (default: 0)
          post_capture 0
          # Event Gap is the seconds of no motion detection that triggers the end of an event.
          # An event is defined as a series of motion images taken within a short timeframe.
          # Recommended value is 60 seconds (Default). The value -1 is allowed and disables
          # events causing all Motion to be written to one single movie file and no pre_capture.
          # If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
          # event ends right after no more motion is detected and post_capture is over.
          event_gap 60
          # Maximum length in seconds of a movie
          # When value is exceeded a new movie file is created. (Default: 0 = infinite)
          max_movie_time 0
          # Always save images even if there was no motion (default: off)
          emulate_motion off
          # Image File Output
          # Output 'normal' pictures when motion is detected (default: off)
          # Valid values: on, off, first, best, center
          # When set to 'first', only the first picture of an event is saved.
          # Picture with most motion of an event is saved when set to 'best'.
          # Picture with motion nearest center of picture is saved when set to 'center'.
          # Can be used as preview shot for the corresponding movie.
          output_pictures off
          # Output pictures with only the pixels moving object (ghost images) (default: off)
          output_debug_pictures off
          # The quality (in percent) to be used by the jpeg and webp compression (default: 75)
          quality 75
          # Type of output images
          # Valid values: jpeg, ppm or webp (default: jpeg)
          picture_type jpeg
          # Use ffmpeg to encode videos of motion (default: off)
          ffmpeg_output_movies on
          # Use ffmpeg to make videos showing the moving pixels (ghost images) (default: off)
          ffmpeg_output_debug_movies off
          # Bitrate to be used by the ffmpeg encoder (default: 400000)
          # This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
          ffmpeg_bps 400000
          # Enables and defines variable bitrate for the ffmpeg encoder.
          # ffmpeg_bps is ignored if variable bitrate is enabled.
          # Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
          # or the range 1 - 100 where 1 means worst quality and 100 is best.
          ffmpeg_variable_bitrate 0
          # Container/Codec output videos
          # Valid values: mpeg4, msmpeg4, swf,flv, ffv1, mov, mp4, mkv, hevc
          ffmpeg_video_codec mkv
          # When creating videos, should frames be duplicated in order
          # to keep up with the requested frames per second
          # (default: true)
          ffmpeg_duplicate_frames true
          # Interval in seconds between timelapse captures.  Default: 0 = off
          timelapse_interval 0
          # Timelapse file rollover mode. See motion_guide.html for options and uses.
          timelapse_mode daily
          # Frame rate for timelapse playback
          timelapse_fps 30
          # Container/Codec for timelapse video. Valid values: mpg or mpeg4
          timelapse_codec mpg
          # External pipe to video encoder
          # Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
          # The options movie_filename and timelapse_filename are also used
          # by the ffmpeg feature
          # Bool to enable or disable extpipe (default: off)
          use_extpipe off
          # External program (full path and opts) to pipe raw video to
          # Generally, use '-' for STDIN...
          ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
          ;extpipe x264 - --input-res %wx%h --fps %fps --bitrate 2000 --preset ultrafast --quiet -o %f.mp4
          ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:fps=%fps -ovc x264 -x264encopts preset=ultrafast -of lavf -o %f.mp4 - -fps %fps
          ;extpipe ffmpeg -y -f rawvideo -pix_fmt yuv420p -video_size %wx%h -framerate %fps -i pipe:0 -vcodec libx264 -preset ultrafast -f mp4 %f.mp4
          # Snapshots (Traditional Periodic Webcam File Output)
          # Make automated snapshot every N seconds (default: 0 = disabled)
          snapshot_interval 0
          # Text Display
          # %Y = year, %m = month, %d = date,
          # %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
          # %v = event, %q = frame number, %t = camera id number,
          # %D = changed pixels, %N = noise level, \n = new line,
          # %i and %J = width and height of motion area,
          # %K and %L = X and Y coordinates of motion center
          # %C = value defined by text_event - do not use with text_event!
          # You can put quotation marks around the text to allow
          # leading spaces
          # Locate and draw a box around the moving object.
          # Valid values: on, off, preview (default: off)
          # Set to 'preview' will only draw a box in preview_shot pictures.
          locate_motion_mode off
          # Set the look and style of the locate box if enabled.
          # Valid values: box, redbox, cross, redcross (default: box)
          # Set to 'box' will draw the traditional box.
          # Set to 'redbox' will draw a red box.
          # Set to 'cross' will draw a little cross to mark center.
          # Set to 'redcross' will draw a little red cross to mark center.
          locate_motion_style box
          # Draws the timestamp using same options as C function strftime(3)
          # Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
          # Text is placed in lower right corner
          text_right %Y-%m-%d\n%T-%q
          # Draw a user defined text on the images using same options as C function strftime(3)
          # Default: Not defined = no text
          # Text is placed in lower left corner
          ; text_left CAMERA %t
          # Draw the number of changed pixed on the images (default: off)
          # Will normally be set to off except when you setup and adjust the motion settings
          # Text is placed in upper right corner
          text_changes off
          # This option defines the value of the special event conversion specifier %C
          # You can use any conversion specifier in this option except %C. Date and time
          # values are from the timestamp of the first image in the current event.
          # Default: %Y%m%d%H%M%S
          # The idea is that %C can be used filenames and text_left/right for creating
          # a unique identifier for each event.
          text_event %Y%m%d%H%M%S
          # Draw characters at twice normal size on images. (default: off)
          text_double off
          # Text to include in a JPEG EXIF comment
          # May be any text, including conversion specifiers.
          # The EXIF timestamp is included independent of this text.
          ;exif_text %i%J/%K%L
          # Target Directories and filenames For Images And Films
          # For the options snapshot_, picture_, movie_ and timelapse_filename
          # you can use conversion specifiers
          # Quotation marks round string are allowed.
          # Target base directory for pictures and films
          # Recommended to use absolute path. (Default: current working directory)
          target_dir /var/lib/motion
          # File path for snapshots (jpeg, ppm or webp) relative to target_dir
          # Default: %v-%Y%m%d%H%M%S-snapshot
          # Default value is equivalent to legacy oldlayout option
          # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
          # File extension .jpg, .ppm or .webp is automatically added so do not include this.
          # Note: A symbolic link called lastsnap.jpg created in the target_dir will always
          # point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
          snapshot_filename %v-%Y%m%d%H%M%S-snapshot
          # File path for motion triggered images (jpeg, ppm or .webp) relative to target_dir
          # Default: %v-%Y%m%d%H%M%S-%q
          # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
          # Set to 'preview' together with best-preview feature enables special naming
          # convention for preview shots. See motion guide for details
          picture_filename %v-%Y%m%d%H%M%S-%q
          # File path for motion triggered ffmpeg films (movies) relative to target_dir
          # File extensions(.mpg .avi) are automatically added so do not include them
          movie_filename %v-%Y%m%d%H%M%S
          # File path for timelapse movies relative to target_dir
          # Default: %Y%m%d-timelapse
          timelapse_filename %Y%m%d-timelapse
          # Global Network Options
          # Enable IPv6 (default: off)
          ipv6_enabled off
          # Live Stream Server
          # The mini-http server listens to this port for requests (default: 0 = disabled)
          stream_port 8081
          # 50% scaled down substream (default: 0 = disabled)
          # substream_port 8082
          # Quality of the jpeg (in percent) images produced (default: 50)
          stream_quality 50
          # Output frames at 1 fps when no motion is detected and increase to the
          # rate given by stream_maxrate when motion is detected (default: off)
          stream_motion off
          # Maximum framerate for stream streams (default: 1)
          stream_maxrate 1
          # Restrict stream connections to localhost only (default: on)
          stream_localhost on
          # Limits the number of images per connection (default: 0 = unlimited)
          # Number can be defined by multiplying actual stream rate by desired number of seconds
          # Actual stream rate is the smallest of the numbers framerate and stream_maxrate
          stream_limit 0
          # Set the authentication method (default: 0)
          # 0 = disabled
          # 1 = Basic authentication
          # 2 = MD5 digest (the safer authentication)
          stream_auth_method 0
          # Authentication for the stream. Syntax username:password
          # Default: not defined (Disabled)
          ; stream_authentication username:password
          # Percentage to scale the stream image for preview
          # This is scaled on the browser side, motion will keep sending full frames
          # Default: 25
          ; stream_preview_scale 25
          # Have stream preview image start on a new line
          # Default: no
          ; stream_preview_newline no
          # HTTP Based Control
          # TCP/IP port for the http server to listen on (default: 0 = disabled)
          webcontrol_port 8080
          # Restrict control connections to localhost only (default: on)
          webcontrol_localhost on
          # Output for http server, select off to choose raw text plain (default: on)
          webcontrol_html_output on
          # Authentication for the http based control. Syntax username:password
          ; webcontrol_authentication username:password
          # Parameters to include on webcontrol.  0=none, 1=limited, 2=advanced, 3=restricted
          # Default: 0 (none)
          webcontrol_parms 0
          # Tracking (Pan/Tilt)
          # Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
          # The generic type enables the definition of motion center and motion size to
          # be used with the conversion specifiers for options like on_motion_detected
          track_type 0
          # Enable auto tracking (default: off)
          track_auto off
          # Serial port of motor (default: none)
          ;track_port /dev/ttyS0
          # Motor number for x-axis (default: 0)
          ;track_motorx 0
          # Set motorx reverse (default: 0)
          ;track_motorx_reverse 0
          # Motor number for y-axis (default: 0)
          ;track_motory 1
          # Set motory reverse (default: 0)
          ;track_motory_reverse 0
          # Maximum value on x-axis (default: 0)
          ;track_maxx 200
          # Minimum value on x-axis (default: 0)
          ;track_minx 50
          # Maximum value on y-axis (default: 0)
          ;track_maxy 200
          # Minimum value on y-axis (default: 0)
          ;track_miny 50
          # Center value on x-axis (default: 0)
          ;track_homex 128
          # Center value on y-axis (default: 0)
          ;track_homey 128
          # ID of an iomojo camera if used (default: 0)
          track_iomojo_id 0
          # Angle in degrees the camera moves per step on the X-axis
          # with auto-track (default: 10)
          # Currently only used with pwc type cameras
          track_step_angle_x 10
          # Angle in degrees the camera moves per step on the Y-axis
          track_step_angle_y 10
          # Delay to wait for after tracking movement as number
          # of picture frames (default: 10)
          track_move_wait 10
          # Speed to set the motor to (stepper motor option) (default: 255)
          track_speed 255
          # Number of steps to make (stepper motor option) (default: 40)
          track_stepsize 40
          # External Commands, Warnings and Logging:
          # You can use conversion specifiers for the on_xxxx commands
          # %f = filename with full path
          # %n = number indicating filetype
          # Both %f and %n are only defined for on_picture_save,
          # on_movie_start and on_movie_end
          # Do not sound beeps when detecting motion (default: on)
          # Note: Motion never beeps when running in daemon mode.
          quiet on
          # Command to be executed when an event starts. (default: none)
          # An event starts at first motion detected after a period of no motion defined by event_gap
          ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
          # Command to be executed when an event ends after a period of no motion
          # (default: none). The period of no motion is defined by option event_gap.
          ; on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
          # Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
          # To give the filename as an argument to a command append it with %f
          ; on_picture_save value
          # Command to be executed when a motion frame is detected (default: none)
          ; on_motion_detected value
          # Command to be executed when motion in a predefined area is detected
          # Check option 'area_detect'.   (default: none)
          ; on_area_detected value
          # Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
          ; on_movie_start value
          # Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
          ; on_movie_end value
          # Command to be executed when a camera can't be opened or if it is lost
          # NOTE: There is situations when motion don't detect a lost camera!
          # It depends on the driver, some drivers dosn't detect a lost camera at all
          # Some hangs the motion thread. Some even hangs the PC! (default: none)
          ; on_camera_lost value
          # Command to be executed when a camera that was lost has been found (default: none)
          # NOTE: If motion doesn't properly detect a lost camera, it also won't know it found one.
          ; on_camera_found value
          # Common Options for database features.
          # Options require database options to be active also.
          # Log to the database when creating motion triggered picture file  (default: on)
          ; sql_log_picture on
          # Log to the database when creating a snapshot image file (default: on)
          ; sql_log_snapshot on
          # Log to the database when creating motion triggered movie file (default: off)
          ; sql_log_movie off
          # Log to the database when creating timelapse movies file (default: off)
          ; sql_log_timelapse off
          # SQL query string that is sent to the database
          # Use same conversion specifiers has for text features
          # Additional special conversion specifiers are
          # %n = the number representing the file_type
          # Default value:
          # Create tables :
          # Mysql
          # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
          # Postgresql
          # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
          # insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
          ; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
          # Database Options
          # database type : mysql, postgresql, sqlite3 (default : not defined)
          ; database_type value
          # database to log to (default: not defined)
          # for sqlite3, the full path and name for the database.
          ; database_dbname value
          # The host on which the database is located (default: localhost)
          ; database_host value
          # User account name for database (default: not defined)
          ; database_user value
          # User password for database (default: not defined)
          ; database_password value
          # Port on which the database is located
          #  mysql 3306 , postgresql 5432 (default: not defined)
          ; database_port value
          # Database wait time in milliseconds for locked database to
          # be unlocked before returning database locked error (default 0)
          ; database_busy_timeout 0
          # Video Loopback Device (vloopback project)
          # Output images to a video4linux loopback device
          # Specify the device associated with the loopback device
          # For example /dev/video1 (default: not defined)
          ; video_pipe value
          # Output motion images to a video4linux loopback device
          ; motion_video_pipe value
          # camera config files - One for each camera.
          # Except if only one camera - You only need this config file.
          # If you have more than one camera you MUST define one camera
          # config file for each camera in addition to this config file.
          # Remember: If you have more than one camera you must have one
          # camera file for each camera. E.g. 2 cameras requires 3 files:
          # This motion.conf file AND camera1.conf and camera2.conf.
          # Only put the options that are unique to each camera in the
          # camera config files.
          ; camera /etc/motion/camera1.conf
          ; camera /etc/motion/camera2.conf
          ; camera /etc/motion/camera3.conf
          ; camera /etc/motion/camera4.conf
          # Camera config directory
          # Any files ending in '.conf' in this directory will be read
          # as a camera config file.
          ; camera_dir /etc/motion/conf.d
          S 2 Replies Last reply
            sdetweil @bumrocks
            @bumrocks the start/ stop events are coded in the module doc here
            https://raw.githubusercontent.com/sdetweil/MMM-SleepWake/master/README.md
            like this (motion.conf lines)
            u need to remove the ; to uncomment them in the motion.conf
            u have to put the right path there, {user} is just a placeholder
            movies
            ffmpeg off
            images I think are off by default
            you may also want to change the event gap ( time between motion start and reporting motion stop) I have mine set to 15 seconds. defaults to 60 ( 1 minute)
            also lightflash in case you turn on the room lights. is this motion by itself? I have that turned off
            and also motion_frames, how many consecutives frames at 60/second should have motion before reporting… I have mine set to 2.
              sdetweil @bumrocks
              @bumrocks the motion log is on /var/log/motion/motion.log
              so u can see what it is doing
              B 1 Reply Last reply
                bumrocks @sdetweil
                @sdetweil , well my issue of the moment is it will not let me save the changes made to the motion.conf file, arg! I tried to change the files attributes to “anyone” and I get…
                Error setting permissions: Operation not permitted
                  sdetweil @bumrocks
                  @bumrocks yes, the file is in the etc tree, so u need sudo
                    bumrocks @sdetweil
                    @sdetweil , :) Thank you! It appears I have made the necessary changes and will test here shortly! :crossed_fingers_light_skin_tone:
                    Ug! I have apparently edited my config file improperly…Message I get after checking it…
                    pi@mm2:~/MagicMirror $ npm run config:check
                    > magicmirror@2.12.0 config:check /home/pi/MagicMirror
                    > node js/check_config.js
                    [2020-09-06 01:16:00.192] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                    [2020-09-06 01:16:00.266] [LOG]    Line 101 col 16 Parsing error: Unexpected token below
                    /home/pi/MagicMirror/js/check_config.js:66
                    			throw new Error("Wrong syntax in config file!");
                    Error: Wrong syntax in config file!
                        at /home/pi/MagicMirror/js/check_config.js:66:10
                        at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                    npm ERR!     /home/pi/.npm/_logs/2020-09-06T07_16_00_294Z-debug.log
                    Here are the lines in question…
                        module: 'MMM-SleepWake',
                        delay:  15,               // default
                        source: 'external',
                        mode:  see below,
                         // detectionDir: folder containing externally generated file when motion starts
                         //               will be created if needed
                         // detectionFile:  filename generated for motion start. default = 'detected'
                    “mode: see below,” is line 101 as referenced in file check above…
                      sdetweil @bumrocks
                      @bumrocks you are missing
                      config:{
                      after the module:
                      line
                        bumrocks @sdetweil
                        @sdetweil , my apologies for not thanking you sooner! I have too many "projects in the works at any given moment and I caved to my frustration with the mirror and took a break. Intended to be a present to my wife, I am now hoping that I can get this the way I want before her birthday comes around again facepalm
                        Anyways, I am back to being committed and frustration slaps me in the face immediately…I added the line that was missing (not sure how I did that when I copy and pasted it to begin with) and now I get this error…
                        [2020-10-01 23:26:22.548] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                        [2020-10-01 23:26:24.211] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                        npm ERR! errno 1
                        npm ERR!
                        npm ERR!     /home/pi/.npm/_logs/2020-10-02T05_26_24_231Z-debug.log
                        Here is my config file from top to bottom as it is now…
                        /* Magic Mirror Config Sample
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	ipWhitelist: [], // Set [] to allow all IP addresses
                        	language: "en",
                        	timeFormat: 24,
                        	units: "imperial",
                        			     // false, default for all  NON-armv6l devices
                        			module: "alert",
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: "clock",
                        			position: "top_left"
                        			header: "US Holidays",
                        						symbol: "calendar-check",
                        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                        			module: "currentweather",
                        				locationID: "5417598", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                        				appid: "cf2de0d28398c756b6bad589d8e33c2a"
                        			module: "weatherforecast",
                        			header: "Weather Forecast",
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title: "BBC Top News Stories",
                        						url: "http://feeds.bbci.co.uk/news/rss.xml"
                        				showSourceTitle: true,
                        				showPublishDate: true,
                        				broadcastNewsFeeds: true,
                        				broadcastNewsUpdates: true
                            config:{
                               mode:  Hide
                        Lastly, did I understand that if I am using an energy star lcd tv with floating “no signal” message when Pi is off that I should use "mode: Hide " ?
                          sdetweil @bumrocks
                          @bumrocks general rules
                          the thing on the left of : does not need quotes
                          if the thing to the right of : is a number or true/false, also does not need quotes
                          if the thing to the right of : has letters in it, then it needs quotes, either kind are ok, but must be the same
                          yes, if the monitor/tv has the ugly no signal/connection, then u want to use hide
