    Webcam for MM build?
    27 Posts 5 Posters 13.6k Views 5 Watching
      sdetweil @guongthongminh
      @guongthongminh see the readme of the module
      https://github.com/sdetweil/MMM-SleepWake/blob/master/README.md#usage
      It tells u how to configure the motion detector to wake up the mirror
      G 2 Replies Last reply Reply Quote 0
      • G
        guongthongminh @sdetweil
        I did like this in motion.conf
        alt text
        • G
          I found this further so you can help me!
          alt text
            @guongthongminh sorry, hang on… they started enforcing specific api call formats…
              @guongthongminh do this to update the module
              cd ~/MagicMirror/modules/MMM-SleepWake
              git pull
              the restart the mirror
              • G
                I tried it but the result is still the same. Hope you help!
                alt text
                  @guongthongminh said in Webcam for MM build?:
                  that is not an error, just a message to tell you where motion events will go
                    bumrocks @sdetweil
                    @sdetweil , I am unclear where or how to turn off recording images and video and where the “start/stop” commands are noted within the module instructions…
                    I want to use my logitech usb camera for mic control and the camera for detection as well. I have already installed your sleepwake module as well…Just need it all configured at this point and struggling on my own, apparently…
                    Also note, in my /usr/share/doc/motion/ it does not contain a motion_guide.html
                    Here is my config file…
                    Edited to reflect that I believe I made the changes you mention on your SleepWake page to the motion file…
                    # Rename this distribution example file to motion.conf
                    # This config file was generated by motion 4.1.1
                    # Documentation:  /usr/share/doc/motion/motion_guide.html
                    # Daemon
                    # Start in daemon (background) mode and release terminal (default: off)
                    daemon off
                    # File to store the process ID, also called pid file. (default: not defined)
                    process_id_file /var/run/motion/motion.pid
                    # Basic Setup Mode
                    # Start in Setup-Mode, daemon disabled. (default: off)
                    setup_mode off
                    # Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
                    logfile /var/log/motion/motion.log
                    # Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
                    log_level 6
                    # Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
                    log_type all
                    # Capture device options
                    # Videodevice to be used for capturing  (default /dev/video0)
                    # for FreeBSD default is /dev/bktr0
                    videodevice /dev/video0
                    # v4l2_palette allows one to choose preferable palette to be use by motion
                    # See motion_guide.html for the valid options and values.  (default: 17)
                    v4l2_palette 17
                    # Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
                    # This is ONLY used for FreeBSD. Leave it commented out for Linux
                    ; tunerdevice /dev/tuner0
                    # The video input to be used (default: -1)
                    # Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
                    # Set to 0 for uvideo(4) on OpenBSD
                    input -1
                    # The video norm to use (only for video capture and TV tuner cards)
                    # Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
                    norm 0
                    # The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
                    frequency 0
                    # Override the power line frequency for the webcam. (normally not necessary)
                    # Values:
                    # -1 : Do not modify device setting
                    # 0  : Power line frequency Disabled
                    # 1  : 50hz
                    # 2  : 60hz
                    # 3  : Auto
                    power_line_frequency -1
                    # Rotate image this number of degrees. The rotation affects all saved images as
                    # well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
                    rotate 0
                    # Flip image over a given axis (vertical or horizontal), vertical means from left to right
                    # horizontal means top to bottom. Valid values: none, v and h.
                    flip_axis none
                    # Image width (pixels). Valid range: Camera dependent, default: 320
                    width 320
                    # Image height (pixels). Valid range: Camera dependent, default: 240
                    height 240
                    # Maximum number of frames to be captured per second.
                    # Valid range: 2-100. Default: 100 (almost no limit).
                    framerate 2
                    # Minimum time in seconds between capturing picture frames from the camera.
                    # Default: 0 = disabled - the capture rate is given by the camera framerate.
                    # This option is used when you want to capture images at a rate lower than 2 per second.
                    minimum_frame_time 0
                    # Full Network Camera URL.  Valid Services: http:// ftp:// mjpg:// rtsp:// mjpeg:// file:// rtmp://
                    ; netcam_url value
                    # Username and password for network camera if required. Syntax is user:password
                    ; netcam_userpass value
                    # The setting for keep-alive of network socket, should improve performance on compatible net cameras.
                    # off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
                    # force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
                    # on:    Use HTTP/1.1 requests that support keep alive as default.
                    # Default: off
                    netcam_keepalive off
                    # URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
                    # If a port number other than 80 is needed, use "http://myproxy:1234".
                    # Default: not defined
                    ; netcam_proxy value
                    # Set less strict jpeg checks for network cameras with a poor/buggy firmware.
                    # Default: off
                    netcam_tolerant_check off
                    # RTSP connection uses TCP to communicate to the camera. Can prevent image corruption.
                    # Default: on
                    rtsp_uses_tcp on
                    # Name of camera to use if you are using a camera accessed through OpenMax/MMAL
                    # Default: Not defined
                    ; mmalcam_name vc.ril.camera
                    # Camera control parameters (see raspivid/raspistill tool documentation)
                    ; mmalcam_control_params -hf
                    # Let motion regulate the brightness of a video device (default: off).
                    # The auto_brightness feature uses the brightness option as its target value.
                    # If brightness is zero auto_brightness will adjust to average brightness value 128.
                    # Only recommended for cameras without auto brightness
                    auto_brightness off
                    # Set the initial brightness of a video device.
                    # If auto_brightness is enabled, this value defines the average brightness level
                    # which Motion will try and adjust to.
                    # Valid range 0-255, default 0 = disabled
                    brightness 0
                    # Set the contrast of a video device.
                    contrast 0
                    # Set the saturation of a video device.
                    saturation 0
                    # Set the hue of a video device (NTSC feature).
                    hue 0
                    # Round Robin (multiple inputs on same video device name)
                    # Number of frames to capture in each roundrobin step (default: 1)
                    roundrobin_frames 1
                    # Number of frames to skip before each roundrobin step (default: 1)
                    roundrobin_skip 1
                    # Try to filter out noise generated by roundrobin (default: off)
                    switchfilter off
                    # Motion Detection Settings:
                    # Threshold for number of changed pixels in an image that
                    # triggers motion detection (default: 1500)
                    threshold 1500
                    # Automatically tune the threshold down if possible (default: off)
                    threshold_tune off
                    # Noise threshold for the motion detection (default: 32)
                    noise_level 32
                    # Automatically tune the noise threshold (default: on)
                    noise_tune on
                    # Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
                    # Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
                    # (l)abeling must only be used once and the 'l' must be the last letter.
                    # Comment out to disable
                    despeckle_filter EedDl
                    # Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
                    # A script (on_area_detected) is started immediately when motion is         4 5 6
                    # detected in one of the given areas, but only once during an event.        7 8 9
                    # One or more areas can be specified with this option. Take care: This option
                    # does NOT restrict detection to these areas! (Default: not defined)
                    ; area_detect value
                    # PGM file to use as a sensitivity mask.
                    # Full path name to. (Default: not defined)
                    ; mask_file value
                    # PGM file to completely mask out a area of image.
                    # mask_privacy value
                    # Dynamically create a mask file during operation (default: 0)
                    # Adjust speed of mask changes from 0 (off) to 10 (fast)
                    smart_mask_speed 0
                    # Ignore sudden massive light intensity changes given as a percentage of the picture
                    # area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
                    lightswitch 0
                    # Picture frames must contain motion at least the specified number of frames
                    # in a row before they are detected as true motion. At the default of 1, all
                    # motion is detected. Valid range: 1 to thousands, recommended 1-5
                    minimum_motion_frames 1
                    # Specifies the number of pre-captured (buffered) pictures from before motion
                    # was detected that will be output at motion detection.
                    # Recommended range: 0 to 5 (default: 0)
                    # Do not use large values! Large values will cause Motion to skip video frames and
                    # cause unsmooth movies. To smooth movies use larger values of post_capture instead.
                    pre_capture 0
                    # Number of frames to capture after motion is no longer detected (default: 0)
                    post_capture 0
                    # Event Gap is the seconds of no motion detection that triggers the end of an event.
                    # An event is defined as a series of motion images taken within a short timeframe.
                    # Recommended value is 60 seconds (Default). The value -1 is allowed and disables
                    # events causing all Motion to be written to one single movie file and no pre_capture.
                    # If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
                    # event ends right after no more motion is detected and post_capture is over.
                    event_gap 60
                    # Maximum length in seconds of a movie
                    # When value is exceeded a new movie file is created. (Default: 0 = infinite)
                    max_movie_time 0
                    # Always save images even if there was no motion (default: off)
                    emulate_motion off
                    # Image File Output
                    # Output 'normal' pictures when motion is detected (default: off)
                    # Valid values: on, off, first, best, center
                    # When set to 'first', only the first picture of an event is saved.
                    # Picture with most motion of an event is saved when set to 'best'.
                    # Picture with motion nearest center of picture is saved when set to 'center'.
                    # Can be used as preview shot for the corresponding movie.
                    output_pictures off
                    # Output pictures with only the pixels moving object (ghost images) (default: off)
                    output_debug_pictures off
                    # The quality (in percent) to be used by the jpeg and webp compression (default: 75)
                    quality 75
                    # Type of output images
                    # Valid values: jpeg, ppm or webp (default: jpeg)
                    picture_type jpeg
                    # Use ffmpeg to encode videos of motion (default: off)
                    ffmpeg_output_movies on
                    # Use ffmpeg to make videos showing the moving pixels (ghost images) (default: off)
                    ffmpeg_output_debug_movies off
                    # Bitrate to be used by the ffmpeg encoder (default: 400000)
                    # This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
                    ffmpeg_bps 400000
                    # Enables and defines variable bitrate for the ffmpeg encoder.
                    # ffmpeg_bps is ignored if variable bitrate is enabled.
                    # Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
                    # or the range 1 - 100 where 1 means worst quality and 100 is best.
                    ffmpeg_variable_bitrate 0
                    # Container/Codec output videos
                    # Valid values: mpeg4, msmpeg4, swf,flv, ffv1, mov, mp4, mkv, hevc
                    ffmpeg_video_codec mkv
                    # When creating videos, should frames be duplicated in order
                    # to keep up with the requested frames per second
                    # (default: true)
                    ffmpeg_duplicate_frames true
                    # Interval in seconds between timelapse captures.  Default: 0 = off
                    timelapse_interval 0
                    # Timelapse file rollover mode. See motion_guide.html for options and uses.
                    timelapse_mode daily
                    # Frame rate for timelapse playback
                    timelapse_fps 30
                    # Container/Codec for timelapse video. Valid values: mpg or mpeg4
                    timelapse_codec mpg
                    # External pipe to video encoder
                    # Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
                    # The options movie_filename and timelapse_filename are also used
                    # by the ffmpeg feature
                    # Bool to enable or disable extpipe (default: off)
                    use_extpipe off
                    # External program (full path and opts) to pipe raw video to
                    # Generally, use '-' for STDIN...
                    ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
                    ;extpipe x264 - --input-res %wx%h --fps %fps --bitrate 2000 --preset ultrafast --quiet -o %f.mp4
                    ;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:fps=%fps -ovc x264 -x264encopts preset=ultrafast -of lavf -o %f.mp4 - -fps %fps
                    ;extpipe ffmpeg -y -f rawvideo -pix_fmt yuv420p -video_size %wx%h -framerate %fps -i pipe:0 -vcodec libx264 -preset ultrafast -f mp4 %f.mp4
                    # Snapshots (Traditional Periodic Webcam File Output)
                    # Make automated snapshot every N seconds (default: 0 = disabled)
                    snapshot_interval 0
                    # Text Display
                    # %Y = year, %m = month, %d = date,
                    # %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
                    # %v = event, %q = frame number, %t = camera id number,
                    # %D = changed pixels, %N = noise level, \n = new line,
                    # %i and %J = width and height of motion area,
                    # %K and %L = X and Y coordinates of motion center
                    # %C = value defined by text_event - do not use with text_event!
                    # You can put quotation marks around the text to allow
                    # leading spaces
                    # Locate and draw a box around the moving object.
                    # Valid values: on, off, preview (default: off)
                    # Set to 'preview' will only draw a box in preview_shot pictures.
                    locate_motion_mode off
                    # Set the look and style of the locate box if enabled.
                    # Valid values: box, redbox, cross, redcross (default: box)
                    # Set to 'box' will draw the traditional box.
                    # Set to 'redbox' will draw a red box.
                    # Set to 'cross' will draw a little cross to mark center.
                    # Set to 'redcross' will draw a little red cross to mark center.
                    locate_motion_style box
                    # Draws the timestamp using same options as C function strftime(3)
                    # Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
                    # Text is placed in lower right corner
                    text_right %Y-%m-%d\n%T-%q
                    # Draw a user defined text on the images using same options as C function strftime(3)
                    # Default: Not defined = no text
                    # Text is placed in lower left corner
                    ; text_left CAMERA %t
                    # Draw the number of changed pixed on the images (default: off)
                    # Will normally be set to off except when you setup and adjust the motion settings
                    # Text is placed in upper right corner
                    text_changes off
                    # This option defines the value of the special event conversion specifier %C
                    # You can use any conversion specifier in this option except %C. Date and time
                    # values are from the timestamp of the first image in the current event.
                    # Default: %Y%m%d%H%M%S
                    # The idea is that %C can be used filenames and text_left/right for creating
                    # a unique identifier for each event.
                    text_event %Y%m%d%H%M%S
                    # Draw characters at twice normal size on images. (default: off)
                    text_double off
                    # Text to include in a JPEG EXIF comment
                    # May be any text, including conversion specifiers.
                    # The EXIF timestamp is included independent of this text.
                    ;exif_text %i%J/%K%L
                    # Target Directories and filenames For Images And Films
                    # For the options snapshot_, picture_, movie_ and timelapse_filename
                    # you can use conversion specifiers
                    # Quotation marks round string are allowed.
                    # Target base directory for pictures and films
                    # Recommended to use absolute path. (Default: current working directory)
                    target_dir /var/lib/motion
                    # File path for snapshots (jpeg, ppm or webp) relative to target_dir
                    # Default: %v-%Y%m%d%H%M%S-snapshot
                    # Default value is equivalent to legacy oldlayout option
                    # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
                    # File extension .jpg, .ppm or .webp is automatically added so do not include this.
                    # Note: A symbolic link called lastsnap.jpg created in the target_dir will always
                    # point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
                    snapshot_filename %v-%Y%m%d%H%M%S-snapshot
                    # File path for motion triggered images (jpeg, ppm or .webp) relative to target_dir
                    # Default: %v-%Y%m%d%H%M%S-%q
                    # For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
                    # Set to 'preview' together with best-preview feature enables special naming
                    # convention for preview shots. See motion guide for details
                    picture_filename %v-%Y%m%d%H%M%S-%q
                    # File path for motion triggered ffmpeg films (movies) relative to target_dir
                    # File extensions(.mpg .avi) are automatically added so do not include them
                    movie_filename %v-%Y%m%d%H%M%S
                    # File path for timelapse movies relative to target_dir
                    # Default: %Y%m%d-timelapse
                    timelapse_filename %Y%m%d-timelapse
                    # Global Network Options
                    # Enable IPv6 (default: off)
                    ipv6_enabled off
                    # Live Stream Server
                    # The mini-http server listens to this port for requests (default: 0 = disabled)
                    stream_port 8081
                    # 50% scaled down substream (default: 0 = disabled)
                    # substream_port 8082
                    # Quality of the jpeg (in percent) images produced (default: 50)
                    stream_quality 50
                    # Output frames at 1 fps when no motion is detected and increase to the
                    # rate given by stream_maxrate when motion is detected (default: off)
                    stream_motion off
                    # Maximum framerate for stream streams (default: 1)
                    stream_maxrate 1
                    # Restrict stream connections to localhost only (default: on)
                    stream_localhost on
                    # Limits the number of images per connection (default: 0 = unlimited)
                    # Number can be defined by multiplying actual stream rate by desired number of seconds
                    # Actual stream rate is the smallest of the numbers framerate and stream_maxrate
                    stream_limit 0
                    # Set the authentication method (default: 0)
                    # 0 = disabled
                    # 1 = Basic authentication
                    # 2 = MD5 digest (the safer authentication)
                    stream_auth_method 0
                    # Authentication for the stream. Syntax username:password
                    # Default: not defined (Disabled)
                    ; stream_authentication username:password
                    # Percentage to scale the stream image for preview
                    # This is scaled on the browser side, motion will keep sending full frames
                    # Default: 25
                    ; stream_preview_scale 25
                    # Have stream preview image start on a new line
                    # Default: no
                    ; stream_preview_newline no
                    # HTTP Based Control
                    # TCP/IP port for the http server to listen on (default: 0 = disabled)
                    webcontrol_port 8080
                    # Restrict control connections to localhost only (default: on)
                    webcontrol_localhost on
                    # Output for http server, select off to choose raw text plain (default: on)
                    webcontrol_html_output on
                    # Authentication for the http based control. Syntax username:password
                    ; webcontrol_authentication username:password
                    # Parameters to include on webcontrol.  0=none, 1=limited, 2=advanced, 3=restricted
                    # Default: 0 (none)
                    webcontrol_parms 0
                    # Tracking (Pan/Tilt)
                    # Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
                    # The generic type enables the definition of motion center and motion size to
                    # be used with the conversion specifiers for options like on_motion_detected
                    track_type 0
                    # Enable auto tracking (default: off)
                    track_auto off
                    # Serial port of motor (default: none)
                    ;track_port /dev/ttyS0
                    # Motor number for x-axis (default: 0)
                    ;track_motorx 0
                    # Set motorx reverse (default: 0)
                    ;track_motorx_reverse 0
                    # Motor number for y-axis (default: 0)
                    ;track_motory 1
                    # Set motory reverse (default: 0)
                    ;track_motory_reverse 0
                    # Maximum value on x-axis (default: 0)
                    ;track_maxx 200
                    # Minimum value on x-axis (default: 0)
                    ;track_minx 50
                    # Maximum value on y-axis (default: 0)
                    ;track_maxy 200
                    # Minimum value on y-axis (default: 0)
                    ;track_miny 50
                    # Center value on x-axis (default: 0)
                    ;track_homex 128
                    # Center value on y-axis (default: 0)
                    ;track_homey 128
                    # ID of an iomojo camera if used (default: 0)
                    track_iomojo_id 0
                    # Angle in degrees the camera moves per step on the X-axis
                    # with auto-track (default: 10)
                    # Currently only used with pwc type cameras
                    track_step_angle_x 10
                    # Angle in degrees the camera moves per step on the Y-axis
                    track_step_angle_y 10
                    # Delay to wait for after tracking movement as number
                    # of picture frames (default: 10)
                    track_move_wait 10
                    # Speed to set the motor to (stepper motor option) (default: 255)
                    track_speed 255
                    # Number of steps to make (stepper motor option) (default: 40)
                    track_stepsize 40
                    # External Commands, Warnings and Logging:
                    # You can use conversion specifiers for the on_xxxx commands
                    # %f = filename with full path
                    # %n = number indicating filetype
                    # Both %f and %n are only defined for on_picture_save,
                    # on_movie_start and on_movie_end
                    # Do not sound beeps when detecting motion (default: on)
                    # Note: Motion never beeps when running in daemon mode.
                    quiet on
                    # Command to be executed when an event starts. (default: none)
                    # An event starts at first motion detected after a period of no motion defined by event_gap
                    ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                    # Command to be executed when an event ends after a period of no motion
                    # (default: none). The period of no motion is defined by option event_gap.
                    ; on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                    # Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
                    # To give the filename as an argument to a command append it with %f
                    ; on_picture_save value
                    # Command to be executed when a motion frame is detected (default: none)
                    ; on_motion_detected value
                    # Command to be executed when motion in a predefined area is detected
                    # Check option 'area_detect'.   (default: none)
                    ; on_area_detected value
                    # Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
                    ; on_movie_start value
                    # Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
                    ; on_movie_end value
                    # Command to be executed when a camera can't be opened or if it is lost
                    # NOTE: There is situations when motion don't detect a lost camera!
                    # It depends on the driver, some drivers dosn't detect a lost camera at all
                    # Some hangs the motion thread. Some even hangs the PC! (default: none)
                    ; on_camera_lost value
                    # Command to be executed when a camera that was lost has been found (default: none)
                    # NOTE: If motion doesn't properly detect a lost camera, it also won't know it found one.
                    ; on_camera_found value
                    # Common Options for database features.
                    # Options require database options to be active also.
                    # Log to the database when creating motion triggered picture file  (default: on)
                    ; sql_log_picture on
                    # Log to the database when creating a snapshot image file (default: on)
                    ; sql_log_snapshot on
                    # Log to the database when creating motion triggered movie file (default: off)
                    ; sql_log_movie off
                    # Log to the database when creating timelapse movies file (default: off)
                    ; sql_log_timelapse off
                    # SQL query string that is sent to the database
                    # Use same conversion specifiers has for text features
                    # Additional special conversion specifiers are
                    # %n = the number representing the file_type
                    # Default value:
                    # Create tables :
                    # Mysql
                    # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
                    # Postgresql
                    # CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
                    # insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
                    ; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
                    # Database Options
                    # database type : mysql, postgresql, sqlite3 (default : not defined)
                    ; database_type value
                    # database to log to (default: not defined)
                    # for sqlite3, the full path and name for the database.
                    ; database_dbname value
                    # The host on which the database is located (default: localhost)
                    ; database_host value
                    # User account name for database (default: not defined)
                    ; database_user value
                    # User password for database (default: not defined)
                    ; database_password value
                    # Port on which the database is located
                    #  mysql 3306 , postgresql 5432 (default: not defined)
                    ; database_port value
                    # Database wait time in milliseconds for locked database to
                    # be unlocked before returning database locked error (default 0)
                    ; database_busy_timeout 0
                    # Video Loopback Device (vloopback project)
                    # Output images to a video4linux loopback device
                    # Specify the device associated with the loopback device
                    # For example /dev/video1 (default: not defined)
                    ; video_pipe value
                    # Output motion images to a video4linux loopback device
                    ; motion_video_pipe value
                    # camera config files - One for each camera.
                    # Except if only one camera - You only need this config file.
                    # If you have more than one camera you MUST define one camera
                    # config file for each camera in addition to this config file.
                    # Remember: If you have more than one camera you must have one
                    # camera file for each camera. E.g. 2 cameras requires 3 files:
                    # This motion.conf file AND camera1.conf and camera2.conf.
                    # Only put the options that are unique to each camera in the
                    # camera config files.
                    ; camera /etc/motion/camera1.conf
                    ; camera /etc/motion/camera2.conf
                    ; camera /etc/motion/camera3.conf
                    ; camera /etc/motion/camera4.conf
                    # Camera config directory
                    # Any files ending in '.conf' in this directory will be read
                    # as a camera config file.
                    ; camera_dir /etc/motion/conf.d
                      sdetweil @bumrocks
                      @bumrocks the start/ stop events are coded in the module doc here
                      https://raw.githubusercontent.com/sdetweil/MMM-SleepWake/master/README.md
                      like this (motion.conf lines)
                      u need to remove the ; to uncomment them in the motion.conf
                      u have to put the right path there, {user} is just a placeholder
                      movies
                      ffmpeg off
                      images I think are off by default
                      you may also want to change the event gap ( time between motion start and reporting motion stop) I have mine set to 15 seconds. defaults to 60 ( 1 minute)
                      also lightflash in case you turn on the room lights. is this motion by itself? I have that turned off
                      and also motion_frames, how many consecutives frames at 60/second should have motion before reporting… I have mine set to 2.
                        sdetweil @bumrocks
                        @bumrocks the motion log is on /var/log/motion/motion.log
                        so u can see what it is doing
                          bumrocks @sdetweil
                          @sdetweil , well my issue of the moment is it will not let me save the changes made to the motion.conf file, arg! I tried to change the files attributes to “anyone” and I get…
                          Error setting permissions: Operation not permitted
                            sdetweil @bumrocks
                            @bumrocks yes, the file is in the etc tree, so u need sudo
                              bumrocks @sdetweil
                              @sdetweil , :) Thank you! It appears I have made the necessary changes and will test here shortly! :crossed_fingers_light_skin_tone:
                              Ug! I have apparently edited my config file improperly…Message I get after checking it…
                              pi@mm2:~/MagicMirror $ npm run config:check
                              > magicmirror@2.12.0 config:check /home/pi/MagicMirror
                              > node js/check_config.js
                              [2020-09-06 01:16:00.192] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                              [2020-09-06 01:16:00.266] [LOG]    Line 101 col 16 Parsing error: Unexpected token below
                              /home/pi/MagicMirror/js/check_config.js:66
                              			throw new Error("Wrong syntax in config file!");
                              Error: Wrong syntax in config file!
                                  at /home/pi/MagicMirror/js/check_config.js:66:10
                                  at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                              npm ERR!     /home/pi/.npm/_logs/2020-09-06T07_16_00_294Z-debug.log
                              Here are the lines in question…
                                  module: 'MMM-SleepWake',
                                  delay:  15,               // default
                                  source: 'external',
                                  mode:  see below,
                                   // detectionDir: folder containing externally generated file when motion starts
                                   //               will be created if needed
                                   // detectionFile:  filename generated for motion start. default = 'detected'
                              “mode: see below,” is line 101 as referenced in file check above…
                                sdetweil @bumrocks
                                @bumrocks you are missing
                                config:{
                                after the module:
                                line
                                  bumrocks @sdetweil
                                  @sdetweil , my apologies for not thanking you sooner! I have too many "projects in the works at any given moment and I caved to my frustration with the mirror and took a break. Intended to be a present to my wife, I am now hoping that I can get this the way I want before her birthday comes around again facepalm
                                  Anyways, I am back to being committed and frustration slaps me in the face immediately…I added the line that was missing (not sure how I did that when I copy and pasted it to begin with) and now I get this error…
                                  [2020-10-01 23:26:22.548] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                                  [2020-10-01 23:26:24.211] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                                  npm ERR! errno 1
                                  npm ERR!
                                  npm ERR!     /home/pi/.npm/_logs/2020-10-02T05_26_24_231Z-debug.log
                                  Here is my config file from top to bottom as it is now…
                                  /* Magic Mirror Config Sample
                                   * MIT Licensed.
                                  var config = {
                                  	port: 8080,
                                  	ipWhitelist: [], // Set [] to allow all IP addresses
                                  	language: "en",
                                  	timeFormat: 24,
                                  	units: "imperial",
                                  			     // false, default for all  NON-armv6l devices
                                  			module: "alert",
                                  			module: "updatenotification",
                                  			position: "top_bar"
                                  			module: "clock",
                                  			position: "top_left"
                                  			header: "US Holidays",
                                  						symbol: "calendar-check",
                                  						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                  			module: "currentweather",
                                  				locationID: "5417598", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                  				appid: "cf2de0d28398c756b6bad589d8e33c2a"
                                  			module: "weatherforecast",
                                  			header: "Weather Forecast",
                                  			module: "newsfeed",
                                  			position: "bottom_bar",
                                  				feeds: [
                                  						title: "BBC Top News Stories",
                                  						url: "http://feeds.bbci.co.uk/news/rss.xml"
                                  				showSourceTitle: true,
                                  				showPublishDate: true,
                                  				broadcastNewsFeeds: true,
                                  				broadcastNewsUpdates: true
                                      config:{
                                         mode:  Hide
                                  Lastly, did I understand that if I am using an energy star lcd tv with floating “no signal” message when Pi is off that I should use "mode: Hide " ?
                                    sdetweil @bumrocks
                                    @bumrocks general rules
                                    the thing on the left of : does not need quotes
                                    if the thing to the right of : is a number or true/false, also does not need quotes
                                    if the thing to the right of : has letters in it, then it needs quotes, either kind are ok, but must be the same
                                    yes, if the monitor/tv has the ugly no signal/connection, then u want to use hide
