    MMM-Jeedom
    20 Posts 4 Posters 6.9k Views 4 Watching
      sdetweil @ELMAGO
      @ELMAGO i can read some french, I will use an online conversion tool to translate long text and sometimes my responses
      je peux lire du français, j’utiliserai un outil de conversion en ligne pour traduire des textes longs et parfois mes réponses
      • E Offline
        ELMAGO @sdetweil
        okay so i would make the effort, no problem, can answer my previous question?
        • E Offline
          ELMAGO @ELMAGO
          @ELMAGO said in MMM-Jeedom:
          Exemple :
          				idx: "77",
          				customTitle: "Batterie Etage : ",
          				unit : "%",
          if the result is greater than 50 then I would like it to be in green
            sdetweil @ELMAGO
            @ELMAGO see my prior response
            le module ne fournit aucun nom de classe spécial que vous pouvez remplacer dans custom.css.
            c’est la seule section du module qui fait des noms de classe
            crée une ligne (tr)
            • E Offline
              ELMAGO @sdetweil
              I’m sorry, I understood correctly for the css part, but not for the module itself.
              Could you give me this concrete example?
                sdetweil @ELMAGO
                @ELMAGO i’m not sure I understand the comment, but i’ll try…
                when the module generates content for the screen, each little piece can have different classes assigned.
                those classes can be used in the custom.css to manipulate the presentation of that segment.
                the cod in this modules does
                create tablerow (tr)
                assign class = ‘normal’ to everything in the row
                then it looks at the sensor data
                			if(sensor.boolean && sensor.status==1) symbolClass = sensor.symbolon;
                		        ----> if(typeof sensor.boolean== 'undefined') symbolClass = sensor.symbol;
                			symbol.className = symbolClass;
                and assigns a value to the (symbol is the icon )
                symbol.className
                and that is all
                so u have a class for the symbol
                and a class for the row.
                I think u want a class for the VALUE on the row but that was not supplied
                • E Offline
                  ELMAGO @sdetweil
                  ok but how can i know it?
                    sdetweil @ELMAGO
                    @ELMAGO someone would have to change the code to add a class that you could then manipulate
                    • C Offline
                      chassain 0
                      Hello ,
                      I have tried this module (after an intallation of jeedom on rasp4) and i have no results on mirror… my config is certainly false because the result on terminal is good like this
                      curl -H “Content-Type: application/json” -X POST -d ‘{“jsonrpc”: “2.0”, “id”: “1000”, “method”: “cmd::execCmd”, “params”: {“apikey”: “my key”, “id”: 1}}’ http://192.168.1.28/core/api/jeeApi.php | python -m json.tool
                      % Total % Received % Xferd Average Speed Time Time Time Current
                      Dload Upload Total Spent Left Speed
                      100 248 100 123 100 125 1556 1582 --:–:-- --:–:-- --:–:-- 3179
                      “id”: “1000”,
                      “jsonrpc”: “2.0”,
                      “result”: {
                      “collectDate”: “2019-12-28 10:00:35”,
                      “value”: “A570; A57; Quai Marcel Pagnol Toulon”
                      my config is like
                      			module: 'MMM-Jeedom',
                      			header: 'Jeedom Maison',
                      			position: "center",
                      				updateInterval: 3000,
                      			      	jeedomAPIKey: "my key",
                      				jeedomURL: "192.168.1.28",
                      				jeedomPORT: 443,
                      				jeedomHTTPS: false,
                      				jeedomAPIPath: "/core/api/jeeApi.php",
                      				sensors: [
                      					idx: "1",
                      					customTitle: "Itinéraire1",
                      if you have an idea…thanks
                        sdetweil @chassain 0
                        @chassain-0 said in MMM-Jeedom:
                        	jeedomPORT: 443,    // < ---- should be 80 I think, because the url above uses port 80
                        	jeedomHTTPS: false,
