    Keyboard
    Scheduled Pinned Locked Moved Upcoming Features
    13 Posts 6 Posters 6.4k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @pana507
      @pana507 @sdetweil So, yay I got it working!
      Guess I’ll need to write some kind of tutorial, not too easy but here a few first steps:
      • Install “simple-keyboard” in your module via npm
      • Bind it into the JS
          getStyles: function () {
              return [
                  this.file('node_modules/simple-keyboard/build/css/index.css')
          getScripts: function () {
              return [
                  this.file('node_modules/simple-keyboard/build/index.js')
      • Create a div in your DOM building function. Something like that:
                const kb = document.createElement("div");
                kb.className = "simple-keyboard";
                container.appendChild(kb);
      The class is important!
      Then, AFTER the DOM element is created, you can create the keyboard class. I did this as soon as a text field was clicked on. With this method I can make sure that the DOM is created already:
                input.addEventListener("focus", event => {
                    if (!this.keyboard) {
                        var Keyboard = window.SimpleKeyboard.default;
                        this.keyboard = new Keyboard({
                            onChange: input => this.onChange(input),
                            onKeyPress: button => this.onKeyPress(button)
                    this.keyboard.keyboardDOM.classList.add("show-keyboard");
      I guess this can be shortened but I keep the running system for now.
      You can see there are a lot of other functions (this.onChange, this.onKeyPress…)
      Basically they are designed to hide the keyboard if I klick anywhere else and show it if I click on the input field. I have the concept from here:
      https://franciscohodge.com/projects/simple-keyboard/demos/show-hide-demo/
      Simple-keyboard is well documented for npm including lots of sample code, so with a bit of knowledge you’ll find your way around eventually.
      Still need to test it on the raspi itself and for all it’s function.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • L Offline
        lally james @sdetweil
        @sdetweil said in Keyboard:
        @pana507 you can also add the npm for virtual keyboard and add it to your module
        https://www.npmjs.com/package/virtual-[keyboard](https://spacebarcounter.info/click-counter/)
        there are others
        do google search
        node js virtual keyboard
        thanks for sharing man i was also planning to add the npm for the keyboard
          sdetweil @lavolp3
          @lavolp3 said in Keyboard:
          I know it’s 2 years later, but that is what the MM notification DOM-OBJECTS-CREATED means… .
