    Keyboard
    Scheduled Pinned Locked Moved Upcoming Features
    13 Posts 6 Posters 11.6k Views 5 Watching
      broberg Project Sponsor
      There is multiple virtual/on-screen keyboards for linux,
      Maybe :
      https://www.youtube.com/watch?v=bmLh92UNMX4
        pana507
        Thanks for the help, but I need to know how I integrate it into a module so that I can select it as an option within my magic mirror
          sdetweil @pana507
          @pana507 you can also add the npm for virtual keyboard and add it to your module
          https://www.npmjs.com/package/virtual-keyboard
          there are others
          do google search
          node js virtual keyboard
            pana507
            @sdetweil said in Keyboard:
            there are others
            do google search
            Thank you, I will do the tests and tell you how it went
            Cheers
              pana507
              Hi
              I tried to install the virtual keyboard, but when I started the keyboard the whole MagicMirror was interrupted.
              Could you give me lights on this or recommend a virtual keyboard already tested in MM
              S lavolp3L 3 Replies Last reply Reply Quote 0
                sdetweil @pana507
                @pana507 i have not seen any implementations with a vk
                  sdetweil @pana507
                  @pana507 when u started the keyboard??? how did u do that?
                  I installed, and so far nothing is different
                  • lavolp3L
                    @sdetweil What a great coincidence that I’m currently working on a module for which I need a virtual keyboard as well.
                    What have you installed?
                    I have again stranded with the problem of not being able to properly include an npm module into the main .js file.
                    Is this only possible via the getScripts function?
                    I have installed the module “simple-keyboard” using npm and included it like this:
                        getStyles: function () {
                            return [
                                this.file('node_modules/simple-keyboard/build/css/index.css')
                    Then called the keyboard class as instructed by the authors like this:
                        start: function () {
                            this.keyboard = new Keyboard({
                                onChange: input => this.onChange(input),
                                onKeyPress: button => this.onKeyPress(button)
                    Didn’t work. “Keyboard is not defined”
                    @pana507 what have you done to install a keyboard.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                      sdetweil @lavolp3
                      @lavolp3 u need getScripts to load the Keyboard js
                      • lavolp3L
                        lavolp3 Module Developer @pana507
                        @pana507 @sdetweil So, yay I got it working!
                        Guess I’ll need to write some kind of tutorial, not too easy but here a few first steps:
                        • Install “simple-keyboard” in your module via npm
                        • Bind it into the JS
                                return [
                            getScripts: function () {
                                return [
                                    this.file('node_modules/simple-keyboard/build/index.js')
                        • Create a div in your DOM building function. Something like that:
                                  const kb = document.createElement("div");
                                  kb.className = "simple-keyboard";
                                  container.appendChild(kb);
                        The class is important!
                        Then, AFTER the DOM element is created, you can create the keyboard class. I did this as soon as a text field was clicked on. With this method I can make sure that the DOM is created already:
                                  input.addEventListener("focus", event => {
                                      if (!this.keyboard) {
                                          var Keyboard = window.SimpleKeyboard.default;
                                      this.keyboard.keyboardDOM.classList.add("show-keyboard");
                        I guess this can be shortened but I keep the running system for now.
                        You can see there are a lot of other functions (this.onChange, this.onKeyPress…)
                        Basically they are designed to hide the keyboard if I klick anywhere else and show it if I click on the input field. I have the concept from here:
                        https://franciscohodge.com/projects/simple-keyboard/demos/show-hide-demo/
                        Simple-keyboard is well documented for npm including lots of sample code, so with a bit of knowledge you’ll find your way around eventually.
                        Still need to test it on the raspi itself and for all it’s function.
                        • L
                          lally james @sdetweil
                          https://www.npmjs.com/package/virtual-[keyboard](https://spacebarcounter.info/click-counter/)
                          there are others
                          do google search
                          thanks for sharing man i was also planning to add the npm for the keyboard
                            sdetweil @lavolp3
                            @lavolp3 said in Keyboard:
                            I know it’s 2 years later, but that is what the MM notification DOM-OBJECTS-CREATED means… .
