    Keyboard
    Scheduled Pinned Locked Moved Upcoming Features
    13 Posts 6 Posters 6.4k Views 5 Watching
      pana507
      Thanks for the help, but I need to know how I integrate it into a module so that I can select it as an option within my magic mirror
        sdetweil @pana507
        @pana507 you can also add the npm for virtual keyboard and add it to your module
        https://www.npmjs.com/package/virtual-keyboard
        there are others
        do google search
        node js virtual keyboard
          pana507
          @sdetweil said in Keyboard:
          there are others
          do google search
          Thank you, I will do the tests and tell you how it went
          Cheers
            pana507
            Hi
            I tried to install the virtual keyboard, but when I started the keyboard the whole MagicMirror was interrupted.
            Could you give me lights on this or recommend a virtual keyboard already tested in MM
            S lavolp3L 3 Replies Last reply Reply Quote 0
              sdetweil @pana507
              @pana507 i have not seen any implementations with a vk
                sdetweil @pana507
                @pana507 when u started the keyboard??? how did u do that?
                I installed, and so far nothing is different
                • lavolp3L Offline
                  @sdetweil What a great coincidence that I’m currently working on a module for which I need a virtual keyboard as well.
                  What have you installed?
                  I have again stranded with the problem of not being able to properly include an npm module into the main .js file.
                  Is this only possible via the getScripts function?
                  I have installed the module “simple-keyboard” using npm and included it like this:
                      getStyles: function () {
                          return [
                              this.file('node_modules/simple-keyboard/build/css/index.css')
                  Then called the keyboard class as instructed by the authors like this:
                      start: function () {
                          this.keyboard = new Keyboard({
                              onChange: input => this.onChange(input),
                              onKeyPress: button => this.onKeyPress(button)
                  Didn’t work. “Keyboard is not defined”
                  @pana507 what have you done to install a keyboard.
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                    sdetweil @lavolp3
                    @lavolp3 u need getScripts to load the Keyboard js
                    • lavolp3L Offline
                      lavolp3 Module Developer @pana507
                      @pana507 @sdetweil So, yay I got it working!
                      Guess I’ll need to write some kind of tutorial, not too easy but here a few first steps:
                      • Install “simple-keyboard” in your module via npm
                      • Bind it into the JS
                              return [
                          getScripts: function () {
                              return [
                                  this.file('node_modules/simple-keyboard/build/index.js')
                      • Create a div in your DOM building function. Something like that:
                                const kb = document.createElement("div");
                                kb.className = "simple-keyboard";
                                container.appendChild(kb);
                      The class is important!
                      Then, AFTER the DOM element is created, you can create the keyboard class. I did this as soon as a text field was clicked on. With this method I can make sure that the DOM is created already:
                                input.addEventListener("focus", event => {
                                    if (!this.keyboard) {
                                        var Keyboard = window.SimpleKeyboard.default;
                                    this.keyboard.keyboardDOM.classList.add("show-keyboard");
                      I guess this can be shortened but I keep the running system for now.
                      You can see there are a lot of other functions (this.onChange, this.onKeyPress…)
                      Basically they are designed to hide the keyboard if I klick anywhere else and show it if I click on the input field. I have the concept from here:
                      https://franciscohodge.com/projects/simple-keyboard/demos/show-hide-demo/
                      Simple-keyboard is well documented for npm including lots of sample code, so with a bit of knowledge you’ll find your way around eventually.
                      Still need to test it on the raspi itself and for all it’s function.
                      • L Offline
                        lally james @sdetweil
                        https://www.npmjs.com/package/virtual-[keyboard](https://spacebarcounter.info/click-counter/)
                        there are others
                        do google search
                        thanks for sharing man i was also planning to add the npm for the keyboard
