    Keyboard
    Scheduled Pinned Locked Moved Upcoming Features
    13 Posts 6 Posters 6.3k Views 5 Watching
      pana507
      Did anyone find a way to insert a virtual keyboard?
      • brobergB Offline
        broberg Project Sponsor
        There is multiple virtual/on-screen keyboards for linux,
        Maybe :
        https://www.youtube.com/watch?v=bmLh92UNMX4
          pana507
          Thanks for the help, but I need to know how I integrate it into a module so that I can select it as an option within my magic mirror
            sdetweil @pana507
            @pana507 you can also add the npm for virtual keyboard and add it to your module
            https://www.npmjs.com/package/virtual-keyboard
            there are others
            do google search
            node js virtual keyboard
              pana507
              @sdetweil said in Keyboard:
              there are others
              do google search
              Thank you, I will do the tests and tell you how it went
              Cheers
                pana507
                Hi
                I tried to install the virtual keyboard, but when I started the keyboard the whole MagicMirror was interrupted.
                Could you give me lights on this or recommend a virtual keyboard already tested in MM
                S lavolp3L 3 Replies Last reply Reply Quote 0
                  sdetweil @pana507
                  @pana507 i have not seen any implementations with a vk
                    sdetweil @pana507
                    @pana507 when u started the keyboard??? how did u do that?
                    I installed, and so far nothing is different
                    • lavolp3L Offline
                      @sdetweil What a great coincidence that I’m currently working on a module for which I need a virtual keyboard as well.
                      What have you installed?
                      I have again stranded with the problem of not being able to properly include an npm module into the main .js file.
                      Is this only possible via the getScripts function?
                      I have installed the module “simple-keyboard” using npm and included it like this:
                          getStyles: function () {
                              return [
                                  this.file('node_modules/simple-keyboard/build/css/index.css')
                      Then called the keyboard class as instructed by the authors like this:
                          start: function () {
                              this.keyboard = new Keyboard({
                                  onChange: input => this.onChange(input),
                                  onKeyPress: button => this.onKeyPress(button)
                      Didn’t work. “Keyboard is not defined”
                      @pana507 what have you done to install a keyboard.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                        sdetweil @lavolp3
                        @lavolp3 u need getScripts to load the Keyboard js
