    jumping of modules
    23 Posts 3 Posters 17.0k Views 3 Watching
    • K Offline
      kclemen
      When using the hide/show function the new function jumps from the bottom to the top.
      Rather difficult to explain, but I made a movie about it. Sorry for the moving around…
      Youtube, jumping of modules.
      What would be a solution to immediately show the new module on the top?
      • T Offline
        tidus5 @kclemen
        @kclemen not sure im right
        but are you using the hide() show() ?
        from your own module ?
        • K Offline
          kclemen
          The code I’m using is in my “skywriter” module:
          Module.register("MMM-skywriter",{
          	// Default module config.
          	defaults: {
          		gesture_up: 0,
          		gesture_right: 0,
          	// Override socket notification handler.
          		if (notification === "gesture_observed"){
          			console.log ("socketnotificationreceived.");
          			//self.sendNotification(notification, payload);
          			if (payload === "up"){
          				if (this.config.gesture_up == 0) {
          						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
          							module.hide(1000, function() {
          								Log.log(module.name + ' is hidden.');
          						MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
          							module.show(1000, function() {
          								Log.log(module.name + ' is shown.');
          						this.config.gesture_up = this.config.gesture_up+1;
          						console.log (this.config.gesture_up);
          						console.log("gesture_up is nu 1");
          				else if (this.config.gesture_up == 1) {
          						console.log("gesture_up is nu 2");
          			else if (payload === "left"){
          				console.log("test - left");
          			else if (payload === "down") {
          				console.log("test - down");
          				if (this.config.gesture_up == 1){
          					this.config.gesture_up = this.config.gesture_up-1;
          							Log.log(module.name + ' is hidden by gesture.');
          				else if (this.config.gesture_up == 2){
          					console.log("gesture up is terug 1");
          	notificationReceived: function(notification, payload, sender) {
          		if (notification === 'DOM_OBJECTS_CREATED') {
          			MM.getModules().exceptWithClass("default").enumerate(function(module) {
          					Log.log('Module is hidden.');
          	start: function() {
          		this.current_user = null;
          		this.sendSocketNotification('CONFIG', this.config);
          		Log.info('Starting module: ' + this.name);
          • T Offline
            tidus5
            @kclemen
            what’s the position of your module in the config?
            2 différents zone ?
            • K Offline
              kclemen @tidus5
              @tidus5, No they have the same zone: position: ‘top_right’,
              • T Offline
                tidus5 @kclemen
                @kclemen so if i understand correctly the problem is because the second module move when you hide the first one ?
                as far as i understand the module - if you have 2 module in the same zone and you hide one the other take the free space
                maybe if you change the second one from “top_right” to an other zone ?
                • T Offline
                  tidus5 @tidus5
                  @kclemen or is it the small latency when your module is hide ?
                  • K Offline
                    kclemen
                    The problem is that the second module comes in the screen before the first one is completely hided I geuss? Or what do you mean with the latency of the module?
                    T 2 Replies Last reply Reply Quote 0
                    • T Offline
                      tidus5 @kclemen
                      @kclemen ok ok i understand now
                      • T Offline
                        tidus5 @kclemen
                        @kclemen
                        if you try
                        module.hide(500, instead of 1000?
                        • K Offline
                          kclemen
                          Needed to change it to the following:
                          hide: 100
                          show: 7000
                          This works for the first gesture “up”. If I repeat the same for going back to the first “page” the module flips for a second back to the lower position, before it fades away. Because the time is set to 7000 the fade becomes slow.
                          Should I put a wait between hide and show? How?
                          • T Offline
                            tidus5 @kclemen
                            @kclemen
                            http://api.jquery.com/delay/
                            delay()?
                            • K Offline
                              kclemen
                              I thought that version 2 of the mirror did not use jquery anymore?
                              • T Offline
                                tidus5 @kclemen
                                @kclemen i didnt know -_-
                                with css ?
                                • K Offline
                                  kclemen @tidus5
                                  @tidus5, how do you mean with css?
                                  • T Offline
                                    tidus5
                                    i know you can play with CSS and hide/show but not a pro :s
                                    http://www.w3schools.com/js/js_timing.asp ?
                                    • K Offline
                                      kclemen @tidus5
                                      @tidus5 Will check it tomorrow. Thanks for all of your input so far!
                                      • T Offline
                                        tidus5 @kclemen
                                        @kclemen you are welcome :-)
                                        let me know if that works
                                        • K Offline
                                          kclemen
                                          @MichMich, Could it be that this is a “fault” in the system?
                                          • K Offline
                                            kclemen
                                            Adding setTimeout works for the gesture up, so hiding the defaultclass. But it does not work to show the defaultclass again with gesture down. Then the screen stays black. Removal of the 2nd setTimeout results back in showing the fefaultclass again. Is it possible that it is not possible to use 2 times setTimeout in the same file or so???
                                            	defaults: {
                                            		gesture_up: 0,
                                            		gesture_right: 0,
                                            						setTimeout(function() {
                                            						}, 1000);
                                            				//	setTimeout(function() {
                                            				//	}, 1000);
                                            	start: function() {
