    jumping of modules
    23 Posts 3 Posters 15.0k Views 3 Watching
    • K Offline
      kclemen
      When using the hide/show function the new function jumps from the bottom to the top.
      Rather difficult to explain, but I made a movie about it. Sorry for the moving around…
      Youtube, jumping of modules.
      What would be a solution to immediately show the new module on the top?
      tidus5T 1 Reply Last reply Reply Quote 0
      • tidus5T Offline
        tidus5 @kclemen
        @kclemen not sure im right
        but are you using the hide() show() ?
        from your own module ?
        • K Offline
          kclemen
          The code I’m using is in my “skywriter” module:
          Module.register("MMM-skywriter",{
          	// Default module config.
          	defaults: {
          		gesture_up: 0,
          		gesture_right: 0,
          	// Override socket notification handler.
          		if (notification === "gesture_observed"){
          			console.log ("socketnotificationreceived.");
          			//self.sendNotification(notification, payload);
          			if (payload === "up"){
          				if (this.config.gesture_up == 0) {
          						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
          							module.hide(1000, function() {
          								Log.log(module.name + ' is hidden.');
          						MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
          							module.show(1000, function() {
          								Log.log(module.name + ' is shown.');
          						this.config.gesture_up = this.config.gesture_up+1;
          						console.log (this.config.gesture_up);
          						console.log("gesture_up is nu 1");
          				else if (this.config.gesture_up == 1) {
          						console.log("gesture_up is nu 2");
          			else if (payload === "left"){
          				console.log("test - left");
          			else if (payload === "down") {
          				console.log("test - down");
          				if (this.config.gesture_up == 1){
          					this.config.gesture_up = this.config.gesture_up-1;
          							Log.log(module.name + ' is hidden by gesture.');
          				else if (this.config.gesture_up == 2){
          					console.log("gesture up is terug 1");
          		if (notification === 'DOM_OBJECTS_CREATED') {
          			MM.getModules().exceptWithClass("default").enumerate(function(module) {
          					Log.log('Module is hidden.');
          	start: function() {
          		this.current_user = null;
          		this.sendSocketNotification('CONFIG', this.config);
          		Log.info('Starting module: ' + this.name);
          • tidus5T Offline
            tidus5
            @kclemen
            what’s the position of your module in the config?
            2 différents zone ?
            • K Offline
              kclemen @tidus5
              @tidus5, No they have the same zone: position: ‘top_right’,
              • tidus5T Offline
                tidus5 @kclemen
                @kclemen so if i understand correctly the problem is because the second module move when you hide the first one ?
                as far as i understand the module - if you have 2 module in the same zone and you hide one the other take the free space
                maybe if you change the second one from “top_right” to an other zone ?
                • tidus5T Offline
                  tidus5 @tidus5
                  @kclemen or is it the small latency when your module is hide ?
                  • K Offline
                    kclemen
                    The problem is that the second module comes in the screen before the first one is completely hided I geuss? Or what do you mean with the latency of the module?
                    tidus5T 2 Replies Last reply Reply Quote 0
                    • tidus5T Offline
                      tidus5 @kclemen
                      @kclemen ok ok i understand now
                      • tidus5T Offline
                        tidus5 @kclemen
                        @kclemen
                        if you try
                        module.hide(500, instead of 1000?
