    jumping of modules
    23 Posts 3 Posters 16.0k Views 3 Watching
    • tidus5T Offline
      tidus5 @kclemen
      @kclemen not sure im right
      but are you using the hide() show() ?
      from your own module ?
      • K Offline
        kclemen
        The code I’m using is in my “skywriter” module:
        Module.register("MMM-skywriter",{
        	// Default module config.
        	defaults: {
        		gesture_up: 0,
        		gesture_right: 0,
        	// Override socket notification handler.
        		if (notification === "gesture_observed"){
        			console.log ("socketnotificationreceived.");
        			//self.sendNotification(notification, payload);
        			if (payload === "up"){
        				if (this.config.gesture_up == 0) {
        						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
        							module.hide(1000, function() {
        								Log.log(module.name + ' is hidden.');
        						MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
        							module.show(1000, function() {
        								Log.log(module.name + ' is shown.');
        						this.config.gesture_up = this.config.gesture_up+1;
        						console.log (this.config.gesture_up);
        						console.log("gesture_up is nu 1");
        				else if (this.config.gesture_up == 1) {
        						console.log("gesture_up is nu 2");
        			else if (payload === "left"){
        				console.log("test - left");
        			else if (payload === "down") {
        				console.log("test - down");
        				if (this.config.gesture_up == 1){
        					this.config.gesture_up = this.config.gesture_up-1;
        							Log.log(module.name + ' is hidden by gesture.');
        				else if (this.config.gesture_up == 2){
        					console.log("gesture up is terug 1");
        		if (notification === 'DOM_OBJECTS_CREATED') {
        			MM.getModules().exceptWithClass("default").enumerate(function(module) {
        					Log.log('Module is hidden.');
        	start: function() {
        		this.current_user = null;
        		this.sendSocketNotification('CONFIG', this.config);
        		Log.info('Starting module: ' + this.name);
        • tidus5T Offline
          tidus5
          @kclemen
          what’s the position of your module in the config?
          2 différents zone ?
          • K Offline
            kclemen @tidus5
            @tidus5, No they have the same zone: position: ‘top_right’,
            tidus5T 1 Reply Last reply Reply Quote 0
            • tidus5T Offline
              tidus5 @kclemen
              @kclemen so if i understand correctly the problem is because the second module move when you hide the first one ?
              as far as i understand the module - if you have 2 module in the same zone and you hide one the other take the free space
              maybe if you change the second one from “top_right” to an other zone ?
              • tidus5T Offline
                tidus5 @tidus5
                @kclemen or is it the small latency when your module is hide ?
                • K Offline
                  kclemen
                  The problem is that the second module comes in the screen before the first one is completely hided I geuss? Or what do you mean with the latency of the module?
                  tidus5T 2 Replies Last reply Reply Quote 0
                  • tidus5T Offline
                    tidus5 @kclemen
                    @kclemen ok ok i understand now
                    • tidus5T Offline
                      tidus5 @kclemen
                      @kclemen
                      if you try
                      module.hide(500, instead of 1000?
                      • K Offline
                        kclemen
                        Needed to change it to the following:
                        hide: 100
                        show: 7000
                        This works for the first gesture “up”. If I repeat the same for going back to the first “page” the module flips for a second back to the lower position, before it fades away. Because the time is set to 7000 the fade becomes slow.
                        Should I put a wait between hide and show? How?
