    jumping of modules
    23 Posts 3 Posters 16.3k Views 3 Watching
    • tidus5T Offline
      tidus5 @kclemen
      @kclemen ok ok i understand now
      • tidus5T Offline
        tidus5 @kclemen
        @kclemen
        if you try
        module.hide(500, instead of 1000?
        • K Offline
          kclemen
          Needed to change it to the following:
          hide: 100
          show: 7000
          This works for the first gesture “up”. If I repeat the same for going back to the first “page” the module flips for a second back to the lower position, before it fades away. Because the time is set to 7000 the fade becomes slow.
          Should I put a wait between hide and show? How?
          tidus5T 1 Reply Last reply Reply Quote 0
          • tidus5T Offline
            tidus5 @kclemen
            @kclemen
            http://api.jquery.com/delay/
            delay()?
            • K Offline
              kclemen
              I thought that version 2 of the mirror did not use jquery anymore?
              • tidus5T Offline
                tidus5 @kclemen
                @kclemen i didnt know -_-
                with css ?
                • K Offline
                  kclemen @tidus5
                  @tidus5, how do you mean with css?
                  • tidus5T Offline
                    tidus5
                    i know you can play with CSS and hide/show but not a pro :s
                    http://www.w3schools.com/js/js_timing.asp ?
                    • K Offline
                      kclemen @tidus5
                      @tidus5 Will check it tomorrow. Thanks for all of your input so far!
                      • tidus5T Offline
                        tidus5 @kclemen
                        @kclemen you are welcome :-)
                        let me know if that works
                        • K Offline
                          kclemen
                          @MichMich, Could it be that this is a “fault” in the system?
                          • K Offline
                            kclemen
                            Adding setTimeout works for the gesture up, so hiding the defaultclass. But it does not work to show the defaultclass again with gesture down. Then the screen stays black. Removal of the 2nd setTimeout results back in showing the fefaultclass again. Is it possible that it is not possible to use 2 times setTimeout in the same file or so???
                            Module.register("MMM-skywriter",{
                            	// Default module config.
                            	defaults: {
                            		gesture_up: 0,
                            		gesture_right: 0,
                            	// Override socket notification handler.
                            		if (notification === "gesture_observed"){
                            			console.log ("socketnotificationreceived.");
                            			//self.sendNotification(notification, payload);
                            			if (payload === "up"){
                            				if (this.config.gesture_up == 0) {
                            						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
                            							module.hide(1000, function() {
                            								Log.log(module.name + ' is hidden.');
                            						setTimeout(function() {
                            								MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
                            									module.show(1000, function() {
                            										Log.log(module.name + ' is shown.');
                            						}, 1000);
                            								this.config.gesture_up = this.config.gesture_up+1;
                            								console.log("gesture_up is nu 1");
                            				else if (this.config.gesture_up == 1) {
                            						console.log (this.config.gesture_up)
                            			else if (payload === "left"){
                            				console.log("test - left");
                            			else if (payload === "down") {
                            				if (this.config.gesture_up == 1){
                            							Log.log(module.name + ' is hidden by gesture.');
                            				//	setTimeout(function() {
                            				//	}, 1000);
                            					this.config.gesture_up = this.config.gesture_up-1;
                            					console.log("test - down");
                            				else if (this.config.gesture_up == 2){
                            					console.log("gesture up is terug 1");
                            		if (notification === 'DOM_OBJECTS_CREATED') {
                            			MM.getModules().exceptWithClass("default").enumerate(function(module) {
                            					Log.log('Module is hidden.');
                            	start: function() {
                            		this.current_user = null;
                            		this.sendSocketNotification('CONFIG', this.config);
                            		Log.info('Starting module: ' + this.name);
                            • K Offline
                              kclemen
                              I found why it was not working:
                              this.config.defaultClass does not work within the setTimeout. When I change it to "default" which is what is configured in the config.js, then it works perfectly.
                              However, I need to use the this.config.defaultClass. So, what would be a solution for this?
                              • K Offline
                                kclemen
                                Anyone??
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @kclemen
                                  @kclemen
                                  to keep your scope you need to use a fat arrow (es6) function
                                  setTimeout(() => {
                                  }, 1000);
