    jumping of modules
    23 Posts 3 Posters 17.2k Views 3 Watching
    • T Offline
      tidus5 @kclemen
      @kclemen
      if you try
      module.hide(500, instead of 1000?
      • K Offline
        kclemen
        Needed to change it to the following:
        hide: 100
        show: 7000
        This works for the first gesture “up”. If I repeat the same for going back to the first “page” the module flips for a second back to the lower position, before it fades away. Because the time is set to 7000 the fade becomes slow.
        Should I put a wait between hide and show? How?
        • T Offline
          tidus5 @kclemen
          @kclemen
          http://api.jquery.com/delay/
          delay()?
          • K Offline
            kclemen
            I thought that version 2 of the mirror did not use jquery anymore?
            • T Offline
              tidus5 @kclemen
              @kclemen i didnt know -_-
              with css ?
              • K Offline
                kclemen @tidus5
                @tidus5, how do you mean with css?
                • T Offline
                  tidus5
                  i know you can play with CSS and hide/show but not a pro :s
                  http://www.w3schools.com/js/js_timing.asp ?
                  • K Offline
                    kclemen @tidus5
                    @tidus5 Will check it tomorrow. Thanks for all of your input so far!
                    • T Offline
                      tidus5 @kclemen
                      @kclemen you are welcome :-)
                      let me know if that works
                      • K Offline
                        kclemen
                        @MichMich, Could it be that this is a “fault” in the system?
                        • K Offline
                          kclemen
                          Adding setTimeout works for the gesture up, so hiding the defaultclass. But it does not work to show the defaultclass again with gesture down. Then the screen stays black. Removal of the 2nd setTimeout results back in showing the fefaultclass again. Is it possible that it is not possible to use 2 times setTimeout in the same file or so???
                          Module.register("MMM-skywriter",{
                          	// Default module config.
                          	defaults: {
                          		gesture_up: 0,
                          		gesture_right: 0,
                          	// Override socket notification handler.
                          		if (notification === "gesture_observed"){
                          			console.log ("socketnotificationreceived.");
                          			//self.sendNotification(notification, payload);
                          			if (payload === "up"){
                          				if (this.config.gesture_up == 0) {
                          						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
                          							module.hide(1000, function() {
                          								Log.log(module.name + ' is hidden.');
                          						setTimeout(function() {
                          								MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
                          									module.show(1000, function() {
                          										Log.log(module.name + ' is shown.');
                          						}, 1000);
                          								this.config.gesture_up = this.config.gesture_up+1;
                          								console.log("gesture_up is nu 1");
                          				else if (this.config.gesture_up == 1) {
                          						console.log (this.config.gesture_up)
                          			else if (payload === "left"){
                          				console.log("test - left");
                          			else if (payload === "down") {
                          				if (this.config.gesture_up == 1){
                          							Log.log(module.name + ' is hidden by gesture.');
                          				//	setTimeout(function() {
                          				//	}, 1000);
                          					this.config.gesture_up = this.config.gesture_up-1;
                          					console.log("test - down");
                          				else if (this.config.gesture_up == 2){
                          					console.log("gesture up is terug 1");
                          		if (notification === 'DOM_OBJECTS_CREATED') {
                          			MM.getModules().exceptWithClass("default").enumerate(function(module) {
                          					Log.log('Module is hidden.');
                          	start: function() {
                          		this.current_user = null;
                          		this.sendSocketNotification('CONFIG', this.config);
                          		Log.info('Starting module: ' + this.name);
                          • K Offline
                            kclemen
                            I found why it was not working:
                            this.config.defaultClass does not work within the setTimeout. When I change it to "default" which is what is configured in the config.js, then it works perfectly.
                            However, I need to use the this.config.defaultClass. So, what would be a solution for this?
                            • K Offline
                              kclemen
                              Anyone??
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @kclemen
                                @kclemen
                                to keep your scope you need to use a fat arrow (es6) function
                                setTimeout(() => {
                                }, 1000);
