    jumping of modules
    23 Posts 3 Posters 18.5k Views 3 Watching
    • T
      tidus5 @kclemen
      @kclemen so if i understand correctly the problem is because the second module move when you hide the first one ?
      as far as i understand the module - if you have 2 module in the same zone and you hide one the other take the free space
      maybe if you change the second one from “top_right” to an other zone ?
      T 1 Reply Last reply
      • T
        tidus5 @tidus5
        @kclemen or is it the small latency when your module is hide ?
        • K
          kclemen
          The problem is that the second module comes in the screen before the first one is completely hided I geuss? Or what do you mean with the latency of the module?
          T 2 Replies Last reply
          • T
            tidus5 @kclemen
            @kclemen ok ok i understand now
            • T
              tidus5 @kclemen
              @kclemen
              if you try
              module.hide(500, instead of 1000?
              • K
                kclemen
                Needed to change it to the following:
                hide: 100
                show: 7000
                This works for the first gesture “up”. If I repeat the same for going back to the first “page” the module flips for a second back to the lower position, before it fades away. Because the time is set to 7000 the fade becomes slow.
                Should I put a wait between hide and show? How?
                • T
                  tidus5 @kclemen
                  @kclemen
                  http://api.jquery.com/delay/
                  delay()?
                  • K
                    kclemen
                    I thought that version 2 of the mirror did not use jquery anymore?
                    • T
                      tidus5 @kclemen
                      @kclemen i didnt know -_-
                      with css ?
                      K 1 Reply Last reply
                      • K
                        kclemen @tidus5
                        @tidus5, how do you mean with css?
                        • T
                          tidus5
                          i know you can play with CSS and hide/show but not a pro :s
                          http://www.w3schools.com/js/js_timing.asp ?
                          • K
                            kclemen @tidus5
                            @tidus5 Will check it tomorrow. Thanks for all of your input so far!
                            • T
                              tidus5 @kclemen
                              @kclemen you are welcome :-)
                              let me know if that works
                              • K
                                kclemen
                                @MichMich, Could it be that this is a “fault” in the system?
                                • K
                                  kclemen
                                  Adding setTimeout works for the gesture up, so hiding the defaultclass. But it does not work to show the defaultclass again with gesture down. Then the screen stays black. Removal of the 2nd setTimeout results back in showing the fefaultclass again. Is it possible that it is not possible to use 2 times setTimeout in the same file or so???
                                  Module.register("MMM-skywriter",{
                                  	// Default module config.
                                  	defaults: {
                                  		gesture_up: 0,
                                  		gesture_right: 0,
                                  	// Override socket notification handler.
                                  		if (notification === "gesture_observed"){
                                  			console.log ("socketnotificationreceived.");
                                  			//self.sendNotification(notification, payload);
                                  			if (payload === "up"){
                                  				if (this.config.gesture_up == 0) {
                                  						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
                                  							module.hide(1000, function() {
                                  								Log.log(module.name + ' is hidden.');
                                  						setTimeout(function() {
                                  								MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
                                  									module.show(1000, function() {
                                  										Log.log(module.name + ' is shown.');
                                  						}, 1000);
                                  								this.config.gesture_up = this.config.gesture_up+1;
                                  								console.log("gesture_up is nu 1");
                                  				else if (this.config.gesture_up == 1) {
                                  						console.log (this.config.gesture_up)
                                  			else if (payload === "left"){
                                  				console.log("test - left");
                                  			else if (payload === "down") {
                                  				if (this.config.gesture_up == 1){
                                  							Log.log(module.name + ' is hidden by gesture.');
                                  				//	setTimeout(function() {
                                  				//	}, 1000);
                                  					this.config.gesture_up = this.config.gesture_up-1;
                                  					console.log("test - down");
                                  				else if (this.config.gesture_up == 2){
                                  					console.log("gesture up is terug 1");
                                  		if (notification === 'DOM_OBJECTS_CREATED') {
                                  			MM.getModules().exceptWithClass("default").enumerate(function(module) {
                                  					Log.log('Module is hidden.');
                                  	start: function() {
                                  		this.current_user = null;
                                  		this.sendSocketNotification('CONFIG', this.config);
                                  		Log.info('Starting module: ' + this.name);
                                  • K
                                    kclemen
                                    I found why it was not working:
                                    this.config.defaultClass does not work within the setTimeout. When I change it to "default" which is what is configured in the config.js, then it works perfectly.
                                    However, I need to use the this.config.defaultClass. So, what would be a solution for this?
                                    • K
                                      kclemen
                                      Anyone??
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @kclemen
                                        @kclemen
                                        to keep your scope you need to use a fat arrow (es6) function
                                        setTimeout(() => {
                                        }, 1000);
