    jumping of modules
    23 Posts 3 Posters 18.5k Views 3 Watching
    • T
      tidus5 @kclemen
      @kclemen not sure im right
      but are you using the hide() show() ?
      from your own module ?
      • K
        kclemen
        The code I’m using is in my “skywriter” module:
        Module.register("MMM-skywriter",{
        	// Default module config.
        	defaults: {
        		gesture_up: 0,
        		gesture_right: 0,
        	// Override socket notification handler.
        		if (notification === "gesture_observed"){
        			console.log ("socketnotificationreceived.");
        			//self.sendNotification(notification, payload);
        			if (payload === "up"){
        				if (this.config.gesture_up == 0) {
        						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
        							module.hide(1000, function() {
        								Log.log(module.name + ' is hidden.');
        						MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
        							module.show(1000, function() {
        								Log.log(module.name + ' is shown.');
        						this.config.gesture_up = this.config.gesture_up+1;
        						console.log (this.config.gesture_up);
        						console.log("gesture_up is nu 1");
        				else if (this.config.gesture_up == 1) {
        						console.log("gesture_up is nu 2");
        			else if (payload === "left"){
        				console.log("test - left");
        			else if (payload === "down") {
        				console.log("test - down");
        				if (this.config.gesture_up == 1){
        					this.config.gesture_up = this.config.gesture_up-1;
        							Log.log(module.name + ' is hidden by gesture.');
        				else if (this.config.gesture_up == 2){
        					console.log("gesture up is terug 1");
        		if (notification === 'DOM_OBJECTS_CREATED') {
        			MM.getModules().exceptWithClass("default").enumerate(function(module) {
        					Log.log('Module is hidden.');
        	start: function() {
        		this.current_user = null;
        		this.sendSocketNotification('CONFIG', this.config);
        		Log.info('Starting module: ' + this.name);
        • T
          tidus5
          @kclemen
          what’s the position of your module in the config?
          2 différents zone ?
          K 1 Reply Last reply
          • K
            kclemen @tidus5
            @tidus5, No they have the same zone: position: ‘top_right’,
            T 1 Reply Last reply
            • T
              tidus5 @kclemen
              @kclemen so if i understand correctly the problem is because the second module move when you hide the first one ?
              as far as i understand the module - if you have 2 module in the same zone and you hide one the other take the free space
              maybe if you change the second one from “top_right” to an other zone ?
              • T
                tidus5 @tidus5
                @kclemen or is it the small latency when your module is hide ?
                • K
                  kclemen
                  The problem is that the second module comes in the screen before the first one is completely hided I geuss? Or what do you mean with the latency of the module?
                  T 2 Replies Last reply
                  • T
                    tidus5 @kclemen
                    @kclemen ok ok i understand now
                    • T
                      tidus5 @kclemen
                      @kclemen
                      if you try
                      module.hide(500, instead of 1000?
                      • K
                        kclemen
                        Needed to change it to the following:
                        hide: 100
                        show: 7000
                        This works for the first gesture “up”. If I repeat the same for going back to the first “page” the module flips for a second back to the lower position, before it fades away. Because the time is set to 7000 the fade becomes slow.
                        Should I put a wait between hide and show? How?
                        • T
                          tidus5 @kclemen
                          @kclemen
                          http://api.jquery.com/delay/
                          delay()?
                          • K
                            kclemen
                            I thought that version 2 of the mirror did not use jquery anymore?
                            • T
                              tidus5 @kclemen
                              @kclemen i didnt know -_-
                              with css ?
                              • K
                                kclemen @tidus5
                                @tidus5, how do you mean with css?
                                • T
                                  tidus5
                                  i know you can play with CSS and hide/show but not a pro :s
                                  http://www.w3schools.com/js/js_timing.asp ?
                                  • K
                                    kclemen @tidus5
                                    @tidus5 Will check it tomorrow. Thanks for all of your input so far!
                                    • T
                                      tidus5 @kclemen
                                      @kclemen you are welcome :-)
                                      let me know if that works
                                      • K
                                        kclemen
                                        @MichMich, Could it be that this is a “fault” in the system?
                                        • K
                                          kclemen
                                          Adding setTimeout works for the gesture up, so hiding the defaultclass. But it does not work to show the defaultclass again with gesture down. Then the screen stays black. Removal of the 2nd setTimeout results back in showing the fefaultclass again. Is it possible that it is not possible to use 2 times setTimeout in the same file or so???
                                          	defaults: {
                                          		gesture_up: 0,
                                          		gesture_right: 0,
                                          						setTimeout(function() {
                                          						}, 1000);
                                          				//	setTimeout(function() {
                                          				//	}, 1000);
                                          	start: function() {
                                          • K
                                            kclemen
                                            I found why it was not working:
                                            this.config.defaultClass does not work within the setTimeout. When I change it to "default" which is what is configured in the config.js, then it works perfectly.
                                            However, I need to use the this.config.defaultClass. So, what would be a solution for this?
