    jumping of modules
    23 Posts 3 Posters 16.1k Views 3 Watching
    • tidus5T Offline
      tidus5 @kclemen
      @kclemen
      if you try
      module.hide(500, instead of 1000?
      • K Offline
        kclemen
        Needed to change it to the following:
        hide: 100
        show: 7000
        This works for the first gesture “up”. If I repeat the same for going back to the first “page” the module flips for a second back to the lower position, before it fades away. Because the time is set to 7000 the fade becomes slow.
        Should I put a wait between hide and show? How?
        tidus5T 1 Reply Last reply Reply Quote 0
        • tidus5T Offline
          tidus5 @kclemen
          @kclemen
          http://api.jquery.com/delay/
          delay()?
          • K Offline
            kclemen
            I thought that version 2 of the mirror did not use jquery anymore?
            • tidus5T Offline
              tidus5 @kclemen
              @kclemen i didnt know -_-
              with css ?
              • K Offline
                kclemen @tidus5
                @tidus5, how do you mean with css?
                • tidus5T Offline
                  tidus5
                  i know you can play with CSS and hide/show but not a pro :s
                  http://www.w3schools.com/js/js_timing.asp ?
                  • K Offline
                    kclemen @tidus5
                    @tidus5 Will check it tomorrow. Thanks for all of your input so far!
                    • tidus5T Offline
                      tidus5 @kclemen
                      @kclemen you are welcome :-)
                      let me know if that works
                      • K Offline
                        kclemen
                        @MichMich, Could it be that this is a “fault” in the system?
                        • 2 / 3
