jumping of modules
23 Posts 3 Posters 14.5k Views 3 Watching
  • K Offline
    kclemen
    When using the hide/show function the new function jumps from the bottom to the top.
    Rather difficult to explain, but I made a movie about it. Sorry for the moving around…
    Youtube, jumping of modules.
    What would be a solution to immediately show the new module on the top?
    T 1 Reply Last reply Dec 13, 2016, 8:15 PM Reply Quote 0
    • T Offline
      tidus5 @kclemen
      @kclemen not sure im right
      but are you using the hide() show() ?
      from your own module ?
      • K Offline
        kclemen
        The code I’m using is in my “skywriter” module:
        Module.register("MMM-skywriter",{
        	// Default module config.
        	defaults: {
        		gesture_up: 0,
        		gesture_right: 0,
        	// Override socket notification handler.
        		if (notification === "gesture_observed"){
        			console.log ("socketnotificationreceived.");
        			//self.sendNotification(notification, payload);
        			if (payload === "up"){
        				if (this.config.gesture_up == 0) {
        						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
        							module.hide(1000, function() {
        								Log.log(module.name + ' is hidden.');
        						MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
        							module.show(1000, function() {
        								Log.log(module.name + ' is shown.');
        						this.config.gesture_up = this.config.gesture_up+1;
        						console.log (this.config.gesture_up);
        						console.log("gesture_up is nu 1");
        				else if (this.config.gesture_up == 1) {
        						console.log("gesture_up is nu 2");
        			else if (payload === "left"){
        				console.log("test - left");
        			else if (payload === "down") {
        				console.log("test - down");
        				if (this.config.gesture_up == 1){
        					this.config.gesture_up = this.config.gesture_up-1;
        							Log.log(module.name + ' is hidden by gesture.');
        				else if (this.config.gesture_up == 2){
        					console.log("gesture up is terug 1");
        		if (notification === 'DOM_OBJECTS_CREATED') {
        			MM.getModules().exceptWithClass("default").enumerate(function(module) {
        					Log.log('Module is hidden.');
        	start: function() {
        		this.current_user = null;
        		this.sendSocketNotification('CONFIG', this.config);
        		Log.info('Starting module: ' + this.name);
        • T Offline
          tidus5
          @kclemen
          what’s the position of your module in the config?
          2 différents zone ?
          K 1 Reply Last reply Dec 13, 2016, 8:31 PM Reply Quote 0
          • K Offline
            kclemen @tidus5
            @tidus5, No they have the same zone: position: ‘top_right’,
            T 1 Reply Last reply Dec 13, 2016, 8:34 PM Reply Quote 0
            • T Offline
              tidus5 @kclemen
              @kclemen so if i understand correctly the problem is because the second module move when you hide the first one ?
              as far as i understand the module - if you have 2 module in the same zone and you hide one the other take the free space
              maybe if you change the second one from “top_right” to an other zone ?
              T 1 Reply Last reply Dec 13, 2016, 8:43 PM Reply Quote 0
              • T Offline
                tidus5 @tidus5
                @kclemen or is it the small latency when your module is hide ?
                • K Offline
                  kclemen
                  The problem is that the second module comes in the screen before the first one is completely hided I geuss? Or what do you mean with the latency of the module?
                  T 2 Replies Last reply Dec 13, 2016, 8:48 PM Reply Quote 0
                  • T Offline
                    tidus5 @kclemen
                    @kclemen ok ok i understand now
                    • T Offline
                      tidus5 @kclemen
                      @kclemen
                      if you try
                      module.hide(500, instead of 1000?
                      1 / 3
