    jumping of modules
    23 Posts 3 Posters 18.5k Views 3 Watching
    • K
      kclemen
      I thought that version 2 of the mirror did not use jquery anymore?
      T 1 Reply Last reply
      • T
        tidus5 @kclemen
        @kclemen i didnt know -_-
        with css ?
        K 1 Reply Last reply
        • K
          kclemen @tidus5
          @tidus5, how do you mean with css?
          • T
            tidus5
            i know you can play with CSS and hide/show but not a pro :s
            http://www.w3schools.com/js/js_timing.asp ?
            • K
              kclemen @tidus5
              @tidus5 Will check it tomorrow. Thanks for all of your input so far!
              • T
                tidus5 @kclemen
                @kclemen you are welcome :-)
                let me know if that works
                • K
                  kclemen
                  @MichMich, Could it be that this is a “fault” in the system?
                  • K
                    kclemen
                    Adding setTimeout works for the gesture up, so hiding the defaultclass. But it does not work to show the defaultclass again with gesture down. Then the screen stays black. Removal of the 2nd setTimeout results back in showing the fefaultclass again. Is it possible that it is not possible to use 2 times setTimeout in the same file or so???
                    Module.register("MMM-skywriter",{
                    	// Default module config.
                    	defaults: {
                    		gesture_up: 0,
                    		gesture_right: 0,
                    	// Override socket notification handler.
                    		if (notification === "gesture_observed"){
                    			console.log ("socketnotificationreceived.");
                    			//self.sendNotification(notification, payload);
                    			if (payload === "up"){
                    				if (this.config.gesture_up == 0) {
                    						MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
                    							module.hide(1000, function() {
                    								Log.log(module.name + ' is hidden.');
                    						setTimeout(function() {
                    								MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
                    									module.show(1000, function() {
                    										Log.log(module.name + ' is shown.');
                    						}, 1000);
                    								this.config.gesture_up = this.config.gesture_up+1;
                    								console.log("gesture_up is nu 1");
                    				else if (this.config.gesture_up == 1) {
                    						console.log (this.config.gesture_up)
                    			else if (payload === "left"){
                    				console.log("test - left");
                    			else if (payload === "down") {
                    				if (this.config.gesture_up == 1){
                    							Log.log(module.name + ' is hidden by gesture.');
                    				//	setTimeout(function() {
                    				//	}, 1000);
                    					this.config.gesture_up = this.config.gesture_up-1;
                    					console.log("test - down");
                    				else if (this.config.gesture_up == 2){
                    					console.log("gesture up is terug 1");
                    		if (notification === 'DOM_OBJECTS_CREATED') {
                    			MM.getModules().exceptWithClass("default").enumerate(function(module) {
                    					Log.log('Module is hidden.');
                    	start: function() {
                    		this.current_user = null;
                    		this.sendSocketNotification('CONFIG', this.config);
                    		Log.info('Starting module: ' + this.name);
                    • K
                      kclemen
                      I found why it was not working:
                      this.config.defaultClass does not work within the setTimeout. When I change it to "default" which is what is configured in the config.js, then it works perfectly.
                      However, I need to use the this.config.defaultClass. So, what would be a solution for this?
                      • K
                        kclemen
                        Anyone??
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @kclemen
                          @kclemen
                          to keep your scope you need to use a fat arrow (es6) function
                          setTimeout(() => {
                          }, 1000);
