    jumping of modules
    23 Posts 3 Posters 17.6k Views 3 Watching
    • K Offline
      kclemen
      I found why it was not working:
      this.config.defaultClass does not work within the setTimeout. When I change it to "default" which is what is configured in the config.js, then it works perfectly.
      However, I need to use the this.config.defaultClass. So, what would be a solution for this?
      • K Offline
        kclemen
        Anyone??
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @kclemen
          @kclemen
          to keep your scope you need to use a fat arrow (es6) function
          setTimeout(() => {
              MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
                  module.show(1000, function() {
                      Log.log(module.name + ' is hidden.');
          }, 1000);
