    Doesn't contain package.json file
    8 Posts 2 Posters 2.6k Views 2 Watching
    • A
      allancherianbiju
      Re: include npm module like firebase module into our own MM module
      I’ve been trying for a while and I got the same error every single time.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
      Expected directory: electron-v3.0-linux-arm-glibc
      Found: [node-v59-linux-arm-glibc]
      cd ~/MagicMirror/modules/MMM-hellotsuhan
      npm install --save-dev electron-rebuild
      ./node_modules/.bin/electron-rebuild
      Tried executing this and I got this
      How do I get that file?
      I’m very new to this.
        sdetweil @allancherianbiju
        @allancherianbiju said in Doesn't contain package.json file:
        got what?
        • A
          allancherianbiju
          Formatting mistake. The error I posted isn’t showing up due to some reason.
          npm ERR! Could not install from “node_modules/ .bin/electron-rebuild” as it does not contain a package.json file.
            sdetweil
            many components in a javascript application need to have their versions match the surrounding runtime. grpc is one of those… it will run in and outside the electron browser…
            the electron-rebuild module is loaded as part of the base,
            so you would do
            cd ~/MagicMirror
            node_modules/.bin/electron_rebuild
            • A
              allancherianbiju
              Just closing notes. I was able to fix this!
              @sdetweil provided extra commands.
              cd ~/MagicMirror
              npm install electron-rebuild
              That worked for me, but I was faced with a new error.
              Error: Cannot find module 'node_helper_.
              Fixed that by running
              cd -/MagicMirror
              git checkout modules/node_modules/node_helper/index.js
              Thanks for the help guys!
              • A
                allancherianbiju
                I had to reinstall MM and had to go through all of this again. Rebuilding electron fixed the issue and I found out that the git command I used doesn’t work anymore. Zzz… Updating should help.
                cd -/MagicMirror
                  @allancherianbiju in version 2.10 we fixed this problem, by moving the file to a different location.
                  A 1 Reply Last reply
                  • A
                    allancherianbiju @sdetweil
                    @sdetweil Oh! That’s great! Onward, then :D
