    magic mirror 2 config.js file
    38 Posts 5 Posters 17.1k Views 5 Watching
      sdetweil @elaineezhu
      @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
      • E Offline
        elaineezhu
        @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
          @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
          release)
          see the instruction here
          https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          rename the current MagicMirror folder out of the way
          • E Offline
            elaineezhu @sdetweil
            @sdetweil this is what happens when i try to use your code 0_1577456565197_Screen Shot 2019-12-27 at 9.22.35 PM.png
              @elaineezhu ok, I think i fixed the greadlink problem…
              but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
              later there will be a new update script (to move to next version)
              just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
              • E Offline
                @sdetweil do i rename the folder to anything i want?
                  @elaineezhu yes, as long as it is not MagicMirror
                  MagicMirror.save, .old, .previous, junk… whatever
                  • E Offline
                    @sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
                      @elaineezhu please post the screen shot like before
                      should look like this after the big magicmirror logo
                      + echo -e '\e[0m'
                      \e[0m
                      + doInstall=1
                      + true=1
                      + false=0
                      + NODE_TESTED=v10.1.0
                      + NPM_TESTED=V6.0.0
                      ++ whoami
                      + USER=sam
                      + PM2_FILE=pm2_MagicMirror.json
                      + force_arch=
                      + pm2setup=0
                      ++ uname -s
                      + mac=Darwin
                      + '[' Darwin == Darwin ']'
                      + echo this is a mac
                      + tee -a
                      this is a mac
                      ++ which greadlink
                      ++ wc -l
                      + '[' 1 -eq 0 ']'
                      + cmd=greadlink
                      +++ greadlink -f bash
                      ++ dirname /Users/sam/MagicMirror/config/bash
                      + logdir=/Users/sam/MagicMirror/config
                      + [[ /Users/sam/MagicMirror/config != *\M\a\g\i\c\M\i\r\r\o\r\/\i\n\s\t\a\l\l\e\r\s* ]]
                      + '[' -d MagicMirror ']'
                      + logdir=/Users/sam
                      + logfile=/Users/sam/install.log
                      • E Offline
                        • 3 / 4
