    magic mirror 2 config.js file
    38 Posts 5 Posters 20.6k Views 5 Watching
      sdetweil @elaineezhu
      @elaineezhu can u do a pm2 status ?
      even after editing the code.
      what does that mean? config/config.js or modules/default/compliments/compliments.js?
      E 1 Reply Last reply
        is MM running ON the mac?
        • E
          elaineezhu @sdetweil
          @sdetweil editing the code as in editing the config.js file. 0_1577455393378_Screen Shot 2019-12-27 at 9.02.57 PM.png
          that’s what happens when i do pm2 restart 0 and pm2 status
            @elaineezhu ok, no pm2 setup for this machine
            so you would do the other approach
            cd ~/MagicMIrror
            npm start
            • E
              @sdetweil i think so? it’ll open in electron
              S 2 Replies Last reply
                @elaineezhu how did you do the install? manually or one of the scripts?
                  @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
                  • E
                    elaineezhu
                    @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
                      @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
                      release)
                      see the instruction here
                      https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                      rename the current MagicMirror folder out of the way
                      • E
                        @sdetweil this is what happens when i try to use your code 0_1577456565197_Screen Shot 2019-12-27 at 9.22.35 PM.png
                          @elaineezhu ok, I think i fixed the greadlink problem…
                          but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
                          later there will be a new update script (to move to next version)
                          just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
                          • E
                            @sdetweil do i rename the folder to anything i want?
                              @elaineezhu yes, as long as it is not MagicMirror
                              MagicMirror.save, .old, .previous, junk… whatever
                              • E
                                @sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
                                  @elaineezhu please post the screen shot like before
                                  should look like this after the big magicmirror logo
                                  + echo -e '\e[0m'
                                  \e[0m
                                  + doInstall=1
                                  + true=1
                                  + false=0
                                  + NODE_TESTED=v10.1.0
                                  + NPM_TESTED=V6.0.0
                                  ++ whoami
                                  + USER=sam
                                  + PM2_FILE=pm2_MagicMirror.json
                                  + force_arch=
                                  + pm2setup=0
                                  ++ uname -s
                                  + mac=Darwin
                                  + '[' Darwin == Darwin ']'
                                  + echo this is a mac
                                  + tee -a
                                  this is a mac
                                  ++ which greadlink
                                  ++ wc -l
                                  + '[' 1 -eq 0 ']'
                                  + cmd=greadlink
                                  +++ greadlink -f bash
                                  ++ dirname /Users/sam/MagicMirror/config/bash
                                  + logdir=/Users/sam/MagicMirror/config
                                  + [[ /Users/sam/MagicMirror/config != *\M\a\g\i\c\M\i\r\r\o\r\/\i\n\s\t\a\l\l\e\r\s* ]]
                                  + '[' -d MagicMirror ']'
                                  + logdir=/Users/sam
                                  + logfile=/Users/sam/install.log
                                  • E
                                      @elaineezhu fun
                                      do this
                                      ls "$HOME/MagicMirror"
                                      • E
                                        @sdetweil this is what shows up
                                          @elaineezhu but you were supposed to rename it…
                                          • E
                                            @sdetweil this is the magic mirror folder that i renamed?
