    magic mirror 2 config.js file
    38 Posts 5 Posters 20.7k Views 5 Watching
      is MM running ON the mac?
      E 1 Reply Last reply
      • E
        elaineezhu @sdetweil
        @sdetweil editing the code as in editing the config.js file. 0_1577455393378_Screen Shot 2019-12-27 at 9.02.57 PM.png
        that’s what happens when i do pm2 restart 0 and pm2 status
          sdetweil @elaineezhu
          @elaineezhu ok, no pm2 setup for this machine
          so you would do the other approach
          cd ~/MagicMIrror
          npm start
          • E
            @sdetweil i think so? it’ll open in electron
            S 2 Replies Last reply
              @elaineezhu how did you do the install? manually or one of the scripts?
                @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
                • E
                  elaineezhu
                  @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
                    @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
                    release)
                    see the instruction here
                    https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                    rename the current MagicMirror folder out of the way
                    • E
                      @sdetweil this is what happens when i try to use your code 0_1577456565197_Screen Shot 2019-12-27 at 9.22.35 PM.png
                        @elaineezhu ok, I think i fixed the greadlink problem…
                        but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
                        later there will be a new update script (to move to next version)
                        just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
                        • E
                          @sdetweil do i rename the folder to anything i want?
                            @elaineezhu yes, as long as it is not MagicMirror
                            MagicMirror.save, .old, .previous, junk… whatever
                            • E
                              @sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
                                @elaineezhu please post the screen shot like before
                                should look like this after the big magicmirror logo
                                + echo -e '\e[0m'
                                \e[0m
                                + doInstall=1
                                + true=1
                                + false=0
                                + NODE_TESTED=v10.1.0
                                + NPM_TESTED=V6.0.0
                                ++ whoami
                                + USER=sam
                                + PM2_FILE=pm2_MagicMirror.json
                                + force_arch=
                                + pm2setup=0
                                ++ uname -s
                                + mac=Darwin
                                + '[' Darwin == Darwin ']'
                                + echo this is a mac
                                + tee -a
                                this is a mac
                                ++ which greadlink
                                ++ wc -l
                                + '[' 1 -eq 0 ']'
                                + cmd=greadlink
                                +++ greadlink -f bash
                                ++ dirname /Users/sam/MagicMirror/config/bash
                                + logdir=/Users/sam/MagicMirror/config
                                + [[ /Users/sam/MagicMirror/config != *\M\a\g\i\c\M\i\r\r\o\r\/\i\n\s\t\a\l\l\e\r\s* ]]
                                + '[' -d MagicMirror ']'
                                + logdir=/Users/sam
                                + logfile=/Users/sam/install.log
                                • E
                                    @elaineezhu fun
                                    do this
                                    ls "$HOME/MagicMirror"
                                    • E
                                      @sdetweil this is what shows up
                                        @elaineezhu but you were supposed to rename it…
                                        • E
                                          @sdetweil this is the magic mirror folder that i renamed?
                                            @elaineezhu well then , this explains the original problem…
                                            the config in the ACTUAL ~/MagicMirror is not being changed, u were editing some OTHER magicmirror folder.
                                            cause the $HOME/MagicMirror folder still exists
