    magic mirror 2 config.js file
    38 Posts 5 Posters 20.7k Views 5 Watching
    • E
      elaineezhu
      @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
        sdetweil @elaineezhu
        @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
        release)
        see the instruction here
        https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        rename the current MagicMirror folder out of the way
        E 1 Reply Last reply
        • E
          elaineezhu @sdetweil
          @sdetweil this is what happens when i try to use your code 0_1577456565197_Screen Shot 2019-12-27 at 9.22.35 PM.png
            @elaineezhu ok, I think i fixed the greadlink problem…
            but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
            later there will be a new update script (to move to next version)
            just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
            • E
              @sdetweil do i rename the folder to anything i want?
                @elaineezhu yes, as long as it is not MagicMirror
                MagicMirror.save, .old, .previous, junk… whatever
                • E
                  @sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
                    @elaineezhu please post the screen shot like before
                    should look like this after the big magicmirror logo
                    + echo -e '\e[0m'
                    \e[0m
                    + doInstall=1
                    + true=1
                    + false=0
                    + NODE_TESTED=v10.1.0
                    + NPM_TESTED=V6.0.0
                    ++ whoami
                    + USER=sam
                    + PM2_FILE=pm2_MagicMirror.json
                    + force_arch=
                    + pm2setup=0
                    ++ uname -s
                    + mac=Darwin
                    + '[' Darwin == Darwin ']'
                    + echo this is a mac
                    + tee -a
                    this is a mac
                    ++ which greadlink
                    ++ wc -l
                    + '[' 1 -eq 0 ']'
                    + cmd=greadlink
                    +++ greadlink -f bash
                    ++ dirname /Users/sam/MagicMirror/config/bash
                    + logdir=/Users/sam/MagicMirror/config
                    + [[ /Users/sam/MagicMirror/config != *\M\a\g\i\c\M\i\r\r\o\r\/\i\n\s\t\a\l\l\e\r\s* ]]
                    + '[' -d MagicMirror ']'
                    + logdir=/Users/sam
                    + logfile=/Users/sam/install.log
                    • E
                        @elaineezhu fun
                        do this
                        ls "$HOME/MagicMirror"
                        • E
                          @sdetweil this is what shows up
                            @elaineezhu but you were supposed to rename it…
                            • E
                              @sdetweil this is the magic mirror folder that i renamed?
                                @elaineezhu well then , this explains the original problem…
                                the config in the ACTUAL ~/MagicMirror is not being changed, u were editing some OTHER magicmirror folder.
                                cause the $HOME/MagicMirror folder still exists
                                • E
                                  @sdetweil ohhhhh okay i get it. i’ve tried to edit the actual magicmirror folder (i think i might’ve had 2 or 3) and now it works! thank you so much for all your help :) i appreciate it!
                                  • V
                                    videogame95
                                    All have to is copy the config.is.samples to your so you clear copy.
                                    Just rename the file config.js and it will. Work if you muck it up you have a copy in you document to start over
                                    Again just remember to make a copy again.
                                    • V
                                      videogame95
                                      @videogame95 said in [magic mirror 2 config.js file](/post/8157
                                      All you have to do is copy the config.is.samples to your documents folder so you clear copy.
                                      Just rename the file config.js and it will work . If you muck it up you have a copy in you documents
