    magic mirror 2 config.js file
    38 Posts 5 Posters 19.7k Views 5 Watching
      cskenney @sdetweil
      @sdetweil good to know. Thanks!
      • E Offline
        elaineezhu @sdetweil
        @sdetweil yeah it’s in the config folder, but it still won’t run, as shown in the pictures attached 0_1577454252486_Screen Shot 2019-12-27 at 8.36.00 PM.png 0_1577454295032_Screen Shot 2019-12-27 at 8.44.41 PM.png 0_1577454310352_Screen Shot 2019-12-27 at 8.43.34 PM.png
        perhaps i’m rerunning magic mirror wrongly? if so, what’s the correct command line to run it?
          sdetweil @elaineezhu
          @elaineezhu i built a matching config and it works fine…
          if using pm2, then pm2 restart 0
          if not using pm2 then
          npm start
          • E Offline
            @sdetweil hm, i’ve done that but the compliments displayed are still the default one, even after editing the code.
              @elaineezhu can u do a pm2 status ?
              what does that mean? config/config.js or modules/default/compliments/compliments.js?
                is MM running ON the mac?
                • E Offline
                  @sdetweil editing the code as in editing the config.js file. 0_1577455393378_Screen Shot 2019-12-27 at 9.02.57 PM.png
                  that’s what happens when i do pm2 restart 0 and pm2 status
                    @elaineezhu ok, no pm2 setup for this machine
                    so you would do the other approach
                    cd ~/MagicMIrror
                    npm start
                    • E Offline
                      @sdetweil i think so? it’ll open in electron
                        @elaineezhu how did you do the install? manually or one of the scripts?
                          @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
                          • E Offline
                            elaineezhu
                            @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
                              @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
                              release)
                              see the instruction here
                              https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                              rename the current MagicMirror folder out of the way
                              • E Offline
                                @sdetweil this is what happens when i try to use your code 0_1577456565197_Screen Shot 2019-12-27 at 9.22.35 PM.png
                                  @elaineezhu ok, I think i fixed the greadlink problem…
                                  but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
                                  later there will be a new update script (to move to next version)
                                  just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
                                  • E Offline
                                    @sdetweil do i rename the folder to anything i want?
                                      @elaineezhu yes, as long as it is not MagicMirror
                                      MagicMirror.save, .old, .previous, junk… whatever
                                      • E Offline
                                        @sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
                                          @elaineezhu please post the screen shot like before
                                          should look like this after the big magicmirror logo
                                          + echo -e '\e[0m'
                                          \e[0m
                                          + doInstall=1
                                          + true=1
                                          + false=0
                                          + NODE_TESTED=v10.1.0
                                          + NPM_TESTED=V6.0.0
                                          ++ whoami
                                          + USER=sam
                                          + PM2_FILE=pm2_MagicMirror.json
                                          + force_arch=
                                          + pm2setup=0
                                          ++ uname -s
                                          + mac=Darwin
                                          + '[' Darwin == Darwin ']'
                                          + echo this is a mac
                                          + tee -a
                                          this is a mac
                                          ++ which greadlink
                                          ++ wc -l
                                          + '[' 1 -eq 0 ']'
                                          + cmd=greadlink
                                          +++ greadlink -f bash
                                          ++ dirname /Users/sam/MagicMirror/config/bash
                                          + logdir=/Users/sam/MagicMirror/config
                                          + [[ /Users/sam/MagicMirror/config != *\M\a\g\i\c\M\i\r\r\o\r\/\i\n\s\t\a\l\l\e\r\s* ]]
                                          + '[' -d MagicMirror ']'
                                          + logdir=/Users/sam
                                          + logfile=/Users/sam/install.log
                                          • E Offline
