    magic mirror 2 config.js file
    38 Posts 5 Posters 20.3k Views 5 Watching
    • E
      elaineezhu @cskenney
      @cskenney i’ve done that, but i can’t seem to change the compliments displayed. i’ve also customized the compliments from the compliments folder, but magicmirror2 shows the default compliments?
      FoziF 1 Reply Last reply
      • E
        @cskenney do you think it has anything to do with the fact that i’m using a macbook terminal and not a monitor and keyboard?
        • FoziF
          Fozi Project Sponsor @elaineezhu
          @elaineezhu maybe a superficious question from my side, but have you checked the module description for compliments?
          This gives you all options how to configure the module. You don’t need to customize the module itself. All configurations are done in config.js.
          And no, using the Mac terminal and connect to MM via ssh is just good! This is how I configure my MM all the time.:smiling_face_with_smiling_eyes:
          Maybe you can post us, what you want to achieve (or how you want to adjust the compliments) and provide your current config or compliments looks. That would lever the chance to provide you concise help.
          Edit: I forgot to mention…when you make changes to config.js the MM has to be restarted. Either this is done automatically when you installed MM via @sdetweil script (what I highly recommend!) or you enter in terminal
          pm2 restart all
          (given that MM is controlled by pm2)
          E 1 Reply Last reply
          • E
            elaineezhu @Fozi
            @Fozi i’ve tried editing the compliments in the config.js file, but MM won’t run those compliments, even after restarting it. attached is what is displayed and the config.js code i edited. 1_1577452392569_Screen Shot 2019-12-27 at 8.11.26 PM.png 0_1577452392568_Screen Shot 2019-12-27 at 8.10.41 PM.png
            S C 2 Replies Last reply
              sdetweil @elaineezhu
              @elaineezhu that all looks good… where is that config.js file located? it MUST be in the
              ~/MagicMirror/config folder
                cskenney @elaineezhu
                @elaineezhu it looks to me like you may need to use quotes (“) around module name and position instead of apostrophe (‘). I can’t verify this makes a difference because I am not able to test it.
                  sdetweil @cskenney
                  @cskenney single or double quote is ok, long as they are the same
                  C 1 Reply Last reply
                    cskenney @sdetweil
                    @sdetweil good to know. Thanks!
                    • E
                      elaineezhu @sdetweil
                      @sdetweil yeah it’s in the config folder, but it still won’t run, as shown in the pictures attached 0_1577454252486_Screen Shot 2019-12-27 at 8.36.00 PM.png 0_1577454295032_Screen Shot 2019-12-27 at 8.44.41 PM.png 0_1577454310352_Screen Shot 2019-12-27 at 8.43.34 PM.png
                      perhaps i’m rerunning magic mirror wrongly? if so, what’s the correct command line to run it?
                        @elaineezhu i built a matching config and it works fine…
                        if using pm2, then pm2 restart 0
                        if not using pm2 then
                        npm start
                        • E
                          @sdetweil hm, i’ve done that but the compliments displayed are still the default one, even after editing the code.
                            @elaineezhu can u do a pm2 status ?
                            what does that mean? config/config.js or modules/default/compliments/compliments.js?
                              is MM running ON the mac?
                              • E
                                @sdetweil editing the code as in editing the config.js file. 0_1577455393378_Screen Shot 2019-12-27 at 9.02.57 PM.png
                                that’s what happens when i do pm2 restart 0 and pm2 status
                                  @elaineezhu ok, no pm2 setup for this machine
                                  so you would do the other approach
                                  cd ~/MagicMIrror
                                  npm start
                                  • E
                                    @sdetweil i think so? it’ll open in electron
                                    S 2 Replies Last reply
                                      @elaineezhu how did you do the install? manually or one of the scripts?
                                        @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
                                        • E
                                          elaineezhu
                                          @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
                                            @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
                                            release)
                                            see the instruction here
                                            https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                            rename the current MagicMirror folder out of the way
