    magic mirror 2 config.js file
    38 Posts 5 Posters 18.8k Views 5 Watching
      cskenney @elaineezhu
      @elaineezhu Make a copy of the config.js.sample file and name the copy config.js. Then you can edit the config.js file as needed.
      E 2 Replies Last reply Reply Quote 0
        sdetweil @elaineezhu
        @elaineezhu the instructions for manual install say to copy the sample
        In the config folder do
        cp config.js.sample  config.js
        • E Offline
          elaineezhu @cskenney
          @cskenney i’ve done that, but i can’t seem to change the compliments displayed. i’ve also customized the compliments from the compliments folder, but magicmirror2 shows the default compliments?
          • E Offline
            @cskenney do you think it has anything to do with the fact that i’m using a macbook terminal and not a monitor and keyboard?
            • FoziF Offline
              Fozi Project Sponsor @elaineezhu
              @elaineezhu maybe a superficious question from my side, but have you checked the module description for compliments?
              This gives you all options how to configure the module. You don’t need to customize the module itself. All configurations are done in config.js.
              And no, using the Mac terminal and connect to MM via ssh is just good! This is how I configure my MM all the time.:smiling_face_with_smiling_eyes:
              Maybe you can post us, what you want to achieve (or how you want to adjust the compliments) and provide your current config or compliments looks. That would lever the chance to provide you concise help.
              Edit: I forgot to mention…when you make changes to config.js the MM has to be restarted. Either this is done automatically when you installed MM via @sdetweil script (what I highly recommend!) or you enter in terminal
              pm2 restart all
              (given that MM is controlled by pm2)
              • E Offline
                elaineezhu @Fozi
                @Fozi i’ve tried editing the compliments in the config.js file, but MM won’t run those compliments, even after restarting it. attached is what is displayed and the config.js code i edited. 1_1577452392569_Screen Shot 2019-12-27 at 8.11.26 PM.png 0_1577452392568_Screen Shot 2019-12-27 at 8.10.41 PM.png
                S C 2 Replies Last reply Reply Quote 0
                  @elaineezhu that all looks good… where is that config.js file located? it MUST be in the
                  ~/MagicMirror/config folder
                    @elaineezhu it looks to me like you may need to use quotes (“) around module name and position instead of apostrophe (‘). I can’t verify this makes a difference because I am not able to test it.
                      sdetweil @cskenney
                      @cskenney single or double quote is ok, long as they are the same
                        cskenney @sdetweil
                        @sdetweil good to know. Thanks!
                        • E Offline
                          elaineezhu @sdetweil
                          @sdetweil yeah it’s in the config folder, but it still won’t run, as shown in the pictures attached 0_1577454252486_Screen Shot 2019-12-27 at 8.36.00 PM.png 0_1577454295032_Screen Shot 2019-12-27 at 8.44.41 PM.png 0_1577454310352_Screen Shot 2019-12-27 at 8.43.34 PM.png
                          perhaps i’m rerunning magic mirror wrongly? if so, what’s the correct command line to run it?
                            @elaineezhu i built a matching config and it works fine…
                            if using pm2, then pm2 restart 0
                            if not using pm2 then
                            npm start
                            • E Offline
                              @sdetweil hm, i’ve done that but the compliments displayed are still the default one, even after editing the code.
                                @elaineezhu can u do a pm2 status ?
                                what does that mean? config/config.js or modules/default/compliments/compliments.js?
                                  is MM running ON the mac?
                                  • E Offline
                                    @sdetweil editing the code as in editing the config.js file. 0_1577455393378_Screen Shot 2019-12-27 at 9.02.57 PM.png
                                    that’s what happens when i do pm2 restart 0 and pm2 status
                                      @elaineezhu ok, no pm2 setup for this machine
                                      so you would do the other approach
                                      cd ~/MagicMIrror
                                      npm start
                                      • E Offline
                                        @sdetweil i think so? it’ll open in electron
                                          @elaineezhu how did you do the install? manually or one of the scripts?
                                            @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
