    magic mirror 2 config.js file
    38 Posts 5 Posters 16.4k Views 5 Watching
    • FoziF Offline
      Fozi Project Sponsor @elaineezhu
      @elaineezhu maybe a superficious question from my side, but have you checked the module description for compliments?
      This gives you all options how to configure the module. You don’t need to customize the module itself. All configurations are done in config.js.
      And no, using the Mac terminal and connect to MM via ssh is just good! This is how I configure my MM all the time.:smiling_face_with_smiling_eyes:
      Maybe you can post us, what you want to achieve (or how you want to adjust the compliments) and provide your current config or compliments looks. That would lever the chance to provide you concise help.
      Edit: I forgot to mention…when you make changes to config.js the MM has to be restarted. Either this is done automatically when you installed MM via @sdetweil script (what I highly recommend!) or you enter in terminal
      pm2 restart all
      (given that MM is controlled by pm2)
      • E Offline
        elaineezhu @Fozi
        @Fozi i’ve tried editing the compliments in the config.js file, but MM won’t run those compliments, even after restarting it. attached is what is displayed and the config.js code i edited. 1_1577452392569_Screen Shot 2019-12-27 at 8.11.26 PM.png 0_1577452392568_Screen Shot 2019-12-27 at 8.10.41 PM.png
        S C 2 Replies Last reply Reply Quote 0
          sdetweil @elaineezhu
          @elaineezhu that all looks good… where is that config.js file located? it MUST be in the
          ~/MagicMirror/config folder
            cskenney @elaineezhu
            @elaineezhu it looks to me like you may need to use quotes (“) around module name and position instead of apostrophe (‘). I can’t verify this makes a difference because I am not able to test it.
              sdetweil @cskenney
              @cskenney single or double quote is ok, long as they are the same
                cskenney @sdetweil
                @sdetweil good to know. Thanks!
                • E Offline
                  elaineezhu @sdetweil
                  @sdetweil yeah it’s in the config folder, but it still won’t run, as shown in the pictures attached 0_1577454252486_Screen Shot 2019-12-27 at 8.36.00 PM.png 0_1577454295032_Screen Shot 2019-12-27 at 8.44.41 PM.png 0_1577454310352_Screen Shot 2019-12-27 at 8.43.34 PM.png
                  perhaps i’m rerunning magic mirror wrongly? if so, what’s the correct command line to run it?
                    @elaineezhu i built a matching config and it works fine…
                    if using pm2, then pm2 restart 0
                    if not using pm2 then
                    npm start
                    • E Offline
                      @sdetweil hm, i’ve done that but the compliments displayed are still the default one, even after editing the code.
                        @elaineezhu can u do a pm2 status ?
                        what does that mean? config/config.js or modules/default/compliments/compliments.js?
                        • 1 / 4
