    magic mirror 2 config.js file
    38 Posts 5 Posters 19.5k Views 5 Watching
      cskenney @elaineezhu
      @elaineezhu it looks to me like you may need to use quotes (“) around module name and position instead of apostrophe (‘). I can’t verify this makes a difference because I am not able to test it.
        sdetweil @cskenney
        @cskenney single or double quote is ok, long as they are the same
          cskenney @sdetweil
          @sdetweil good to know. Thanks!
          • E Offline
            elaineezhu @sdetweil
            @sdetweil yeah it’s in the config folder, but it still won’t run, as shown in the pictures attached 0_1577454252486_Screen Shot 2019-12-27 at 8.36.00 PM.png 0_1577454295032_Screen Shot 2019-12-27 at 8.44.41 PM.png 0_1577454310352_Screen Shot 2019-12-27 at 8.43.34 PM.png
            perhaps i’m rerunning magic mirror wrongly? if so, what’s the correct command line to run it?
              sdetweil @elaineezhu
              @elaineezhu i built a matching config and it works fine…
              if using pm2, then pm2 restart 0
              if not using pm2 then
              npm start
              • E Offline
                @sdetweil hm, i’ve done that but the compliments displayed are still the default one, even after editing the code.
                  @elaineezhu can u do a pm2 status ?
                  what does that mean? config/config.js or modules/default/compliments/compliments.js?
                    is MM running ON the mac?
                    • E Offline
                      @sdetweil editing the code as in editing the config.js file. 0_1577455393378_Screen Shot 2019-12-27 at 9.02.57 PM.png
                      that’s what happens when i do pm2 restart 0 and pm2 status
                        @elaineezhu ok, no pm2 setup for this machine
                        so you would do the other approach
                        cd ~/MagicMIrror
                        npm start
                        • E Offline
                          @sdetweil i think so? it’ll open in electron
                            @elaineezhu how did you do the install? manually or one of the scripts?
                              @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
                              • E Offline
                                elaineezhu
                                @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
                                  @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
                                  release)
                                  see the instruction here
                                  https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                  rename the current MagicMirror folder out of the way
                                  • E Offline
                                    @sdetweil this is what happens when i try to use your code 0_1577456565197_Screen Shot 2019-12-27 at 9.22.35 PM.png
                                      @elaineezhu ok, I think i fixed the greadlink problem…
                                      but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
                                      later there will be a new update script (to move to next version)
                                      just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
                                      • E Offline
                                        @sdetweil do i rename the folder to anything i want?
                                          @elaineezhu yes, as long as it is not MagicMirror
                                          MagicMirror.save, .old, .previous, junk… whatever
                                          • E Offline
                                            @sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
