    magic mirror 2 config.js file
    38 Posts 5 Posters 17.5k Views 5 Watching
      sdetweil @elaineezhu
      @elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
      • E Offline
        elaineezhu
        @sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
          @elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
          release)
          see the instruction here
          https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          rename the current MagicMirror folder out of the way
          • E Offline
            elaineezhu @sdetweil
            @sdetweil this is what happens when i try to use your code 0_1577456565197_Screen Shot 2019-12-27 at 9.22.35 PM.png
              @elaineezhu ok, I think i fixed the greadlink problem…
              but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
              later there will be a new update script (to move to next version)
              just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
              • E Offline
                @sdetweil do i rename the folder to anything i want?
                  @elaineezhu yes, as long as it is not MagicMirror
                  MagicMirror.save, .old, .previous, junk… whatever
                  • E Offline
                    @sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
                      @elaineezhu please post the screen shot like before
                      should look like this after the big magicmirror logo
                      + echo -e '\e[0m'
                      \e[0m
                      + doInstall=1
                      + true=1
                      + false=0
                      + NODE_TESTED=v10.1.0
                      + NPM_TESTED=V6.0.0
                      ++ whoami
                      + USER=sam
                      + PM2_FILE=pm2_MagicMirror.json
                      + force_arch=
                      + pm2setup=0
                      ++ uname -s
                      + mac=Darwin
                      + '[' Darwin == Darwin ']'
                      + echo this is a mac
                      + tee -a
                      this is a mac
                      ++ which greadlink
                      ++ wc -l
                      + '[' 1 -eq 0 ']'
                      + cmd=greadlink
                      +++ greadlink -f bash
                      ++ dirname /Users/sam/MagicMirror/config/bash
                      + logdir=/Users/sam/MagicMirror/config
                      + [[ /Users/sam/MagicMirror/config != *\M\a\g\i\c\M\i\r\r\o\r\/\i\n\s\t\a\l\l\e\r\s* ]]
                      + '[' -d MagicMirror ']'
                      + logdir=/Users/sam
                      + logfile=/Users/sam/install.log
                      • E Offline
                          @elaineezhu fun
                          do this
                          ls "$HOME/MagicMirror"
                          • E Offline
                            @sdetweil this is what shows up
                              @elaineezhu but you were supposed to rename it…
                              • E Offline
                                @sdetweil this is the magic mirror folder that i renamed?
                                  @elaineezhu well then , this explains the original problem…
                                  the config in the ACTUAL ~/MagicMirror is not being changed, u were editing some OTHER magicmirror folder.
                                  cause the $HOME/MagicMirror folder still exists
                                  • E Offline
                                    @sdetweil ohhhhh okay i get it. i’ve tried to edit the actual magicmirror folder (i think i might’ve had 2 or 3) and now it works! thank you so much for all your help :) i appreciate it!
                                    • V Offline
                                      videogame95
                                      All have to is copy the config.is.samples to your so you clear copy.
                                      Just rename the file config.js and it will. Work if you muck it up you have a copy in you document to start over
                                      Again just remember to make a copy again.
                                      • V Offline
                                        videogame95
                                        @videogame95 said in [magic mirror 2 config.js file](/post/8157
                                        All you have to do is copy the config.is.samples to your documents folder so you clear copy.
                                        Just rename the file config.js and it will work . If you muck it up you have a copy in you documents
