    Reusing Node Web Server
    4 Posts 2 Posters 1.3k Views 2 Watching
    • C
      cweinhofer
      Anyone know how I can put a file in the MagicMirror directory to allow it to be accessed (internally) via HTTP? It works if I put my file in the Modules folder, but I’d prefer not to do that to keep things cleaner. I tried putting the file in the MagicMirror folder directly and also a sub-folder I created, but both give me an error of “Cannot GET test.html”?
        sdetweil @cweinhofer
        @cweinhofer the mirror code sets up links for the sub folders, but not the root MagicMirror folder
        	app.use("/js", express.static(__dirname));
        	var directories = ["/config", "/css", "/fonts", "/modules", "/vendor", "/translations", "/tests/configs"];
        	var directory;
        	for (var i in directories) {
        		directory = directories[i];
        		app.use(directory, express.static(path.resolve(global.root_path + directory)));
        • C
          cweinhofer
          Thanks @sdetweil
          I added my directory to the list, restarted MagicMirror, and I can now see the file.
          For other’s reference, the code above is located in MagicMirror/js/server.js
            @cweinhofer remember, when the update comes out to watch for the update error…
