Automatic Installation doesn't work.
with the default config.js the installation ran fine. but with just these two modules, no output
@krishnaanivilla looking at the code for aiclient.js, it is waiting for a command from the AI front end,
and if there is none
this.current_selection=undefined
then nothing is displayed.aiclient looks to be part of this
https://github.com/raghavpatnecha/smartmirrorwhich proposes to add some AI (process notifications) on top of MagicMirror
Following up with my error message when attempting the upgrade.sh
pi@Jon-MM:~/MagicMirror $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)" the log will be /home/pi/MagicMirror/installers/upgrade.log No LSB modules are available. doing test run = true update log will be in /home/pi/MagicMirror/installers/upgrade.log saving custom.css cp: cannot stat 'custom.css': No such file or directory upgrading from version 2.10.0 to 2.10.0 fetching latest revisions there are 1 local files that are different than the master repo package-lock.json any *-lock.json files do not need to be saved do you want to save these files for later (Y/n)?n skipping restore for package-lock.json, doing test run no modules found needing npm refresh restoring custom.css cp: cannot stat 'save_custom.css': No such file or directory rm: cannot remove 'save_custom.css': No such file or directory -
@jonspraggins please use the upgrade script here
https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
