    Automatic Installation doesn't work.
    installationmagicmirror2raspberry pi 3
    25 Posts 5 Posters 10.4k Views 5 Watching
    • K Offline
      krishnaanivilla @Mykle1
      @Mykle1 Hello bro the same problem im facing but i stuck with first step unable to move forward please help me
        sdetweil @krishnaanivilla
        @krishnaanivilla what have you done so far?
        did u use the update script from the MM readme page?
        have u tried the updated version?
        see here
        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
        • K Offline
          krishnaanivilla
          i have run this
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
          after this
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
          but still it is showing updating packages and not moving forward
            @krishnaanivilla send me the ~/MagicMirror/installers/upgrade.log file… same userid as here, at gmail
            • K Offline
              krishnaanivilla @sdetweil
              @sdetweil pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              the log will be /home/pi/MagicMirror/installers/upgrade.log
              No LSB modules are available.
              doing test run = true
              saving custom.css
              cp: cannot stat ‘custom.css’: No such file or directory
              upgrading from version 2.10.0 to 2.10.0
              fetching latest revisions
              there are 1 local files that are different than the master repo
              package-lock.json
              any *-lock.json files do not need to be saved
              do you want to save these files for later (Y/n)?y
              *** Please tell me who you are.
              Run
              git config --global user.email “you@example.com”
              git config --global user.name “Your Name”
              to set your account’s default identity.
              Omit --global to set the identity only in this repository.
              fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
              Cannot save the current index state
              no modules found needing npm refresh
              restoring custom.css
              cp: cannot stat ‘save_custom.css’: No such file or directory
              rm: cannot remove ‘save_custom.css’: No such file or directory
              bash: line 339: unalias: git: not found
              test run, restoring files stashed
              No stash entries found.
              saving custom.css
              package-lock.json
              do you want to save these files for later (Y/n)?n
              skipping restore for package-lock.json, doing test run
              saving custom.css
              package-lock.json
              Run
              pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
              $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
              $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
              $$$$$$ $$ | _
              $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
              $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
              $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
              _
              | _
              | _
              | _
              $$ |_| _
              |_| _|_|_| __| _
              / _| _______|
              _
              ____/
              install log being saved to /home/pi/install.log
              Updating packages …
                working on this in chat
                • K Offline
                  krishnaanivilla
                  • K Offline
                    @sdetweil Initializing MagicMirror.
                    translator.js:202 Loading core translation file: translations/en.json
                    translator.js:225 Loading core translation fallback file: translations/en.json
                    loader.js:179 Load script: modules/aiclient//aiclient.js
                    module.js:476 Module registered: aiclient
                    loader.js:150 Bootstrapping module: aiclient
                    loader.js:155 Scripts loaded for: aiclient
                    loader.js:194 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                    loader.js:194 Load stylesheet: modules/aiclient/currentweather.css
                    loader.js:157 Styles loaded for: aiclient
                    loader.js:159 Translations loaded for: aiclient
                    loader.js:179 Load script: modules/aiclientdebugger//aiclientdebugger.js
                    module.js:476 Module registered: aiclientdebugger
                    loader.js:150 Bootstrapping module: aiclientdebugger
                    loader.js:155 Scripts loaded for: aiclientdebugger
                    loader.js:157 Styles loaded for: aiclientdebugger
                    loader.js:159 Translations loaded for: aiclientdebugger
                    loader.js:194 Load stylesheet: css/custom.css
                    :8080/modules/aiclient//aiclient.js:39 Starting module: aiclient
                    aiclientdebugger.js:20 Starting module: aiclientdebugger
                    main.js:473 All modules started!
                    module.js:156 aiclient received a system notification: ALL_MODULES_STARTED
                    module.js:156 aiclientdebugger received a system notification: ALL_MODULES_STARTED
                    module.js:156 aiclient received a system notification: MODULE_DOM_CREATED
                    module.js:156 aiclientdebugger received a system notification: MODULE_DOM_CREATED
                    module.js:156 aiclient received a system notification: DOM_OBJECTS_CREATED
                    module.js:156 aiclientdebugger received a system notification: DOM_OBJECTS_CREATED
                    • K Offline
                      krishnaanivilla
                        with the default config.js the installation ran fine. but with just these two modules, no output
                          @krishnaanivilla looking at the code for aiclient.js, it is waiting for a command from the AI front end,
                          and if there is none
                          this.current_selection=undefined
                          then nothing is displayed.
                          aiclient looks to be part of this
                          https://github.com/raghavpatnecha/smartmirror
                          which proposes to add some AI (process notifications) on top of MagicMirror
                          • jonspragginsJ Offline
                            jonspraggins
                            Following up with my error message when attempting the upgrade.sh
                            pi@Jon-MM:~/MagicMirror $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)"
                            saving custom.css
                            cp: cannot stat 'custom.css': No such file or directory
                               package-lock.json
                            cp: cannot stat 'save_custom.css': No such file or directory
                            rm: cannot remove 'save_custom.css': No such file or directory
                              sdetweil @jonspraggins
                              @jonspraggins please use the upgrade script here
