    Automatic Installation doesn't work.
    installationmagicmirror2raspberry pi 3
    25 Posts 5 Posters 7.8k Views 5 Watching
    • K Offline
      krishnaanivilla
        sdetweil
        with the default config.js the installation ran fine. but with just these two modules, no output
          @krishnaanivilla looking at the code for aiclient.js, it is waiting for a command from the AI front end,
          and if there is none
          this.current_selection=undefined
          then nothing is displayed.
          aiclient looks to be part of this
          https://github.com/raghavpatnecha/smartmirror
          which proposes to add some AI (process notifications) on top of MagicMirror
          • jonspragginsJ Offline
            jonspraggins
            Following up with my error message when attempting the upgrade.sh
            pi@Jon-MM:~/MagicMirror $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)"
            the log will be /home/pi/MagicMirror/installers/upgrade.log
            No LSB modules are available.
            doing test run = true
            update log will be in /home/pi/MagicMirror/installers/upgrade.log
            saving custom.css
            cp: cannot stat 'custom.css': No such file or directory
            upgrading from version 2.10.0 to 2.10.0
            fetching latest revisions
            there are 1 local files that are different than the master repo
               package-lock.json
            any *-lock.json files do not need to be saved
            do you want to save these files for later   (Y/n)?n
            skipping restore for package-lock.json, doing test run
            no modules found needing npm refresh
            restoring custom.css
            cp: cannot stat 'save_custom.css': No such file or directory
            rm: cannot remove 'save_custom.css': No such file or directory
              sdetweil @jonspraggins
              @jonspraggins please use the upgrade script here
              https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
              • 3 / 3
