    Installing MagicMirror² on your Raspberry Pi Zero W
    6 Posts 3 Posters 3.5k Views 4 Watching
    • ? Offline
      [[global:former-user]]
      Hi All,
      I have made a install script to install the latest MagicMirror² on your Raspberry Pi Zero W with the latest release of Raspbian (This is tested on Raspbian Buster with desktop | Version: September 2019 | Release date: 2019-09-26 | Kernel version: 4.19).
      I would invite you all to try my installation script. you can find it on my GitHub here: https://github.com/AchimPieters/MagicZeroMirror
      Installation is done by one line:
      bash -c “$(curl -sL https://raw.githubusercontent.com/AchimPieters/MagicZeroMirror/master/MMZeroInstallScript.sh)”
      Now everything should be installed automatically! I have tries it now several time, and every time with 100% success.
      Let me know what you think of it!
      Best regards.
        sdetweil @Guest
        @AchimPieters cool… how is this different than the updated install script we have created
        which also supports the release last week (2.10.0)
        https://forum.magicmirror.builders/topic/10171/updated-installer-script-available-for-testing
        • ? Offline
          @sdetweil Thank you for your reply! The way it’s different that it works for me. I searched the internet for installation on a raspberry Pi zero W. There are a few different approaches but they didn’t work for me ( e.g only could be uses with a older version of the MagicMirror project or an older version of Raspbian).
          If you want to test it you are welcome!
            sdetweil @Guest
            @AchimPieters said in Installing MagicMirror² on your Raspberry Pi Zero W:
            thanks… i have my hands full at the moment
            • E Offline
              eyebee
              hi @AchimPieters, I know this is quite an old thread but I tried your install. It seems to boot up the magic mirror logo etc. then will just load back to desktop. I used the same desktop version and Kernel as you. New to this so any help appreciated.
              Thanks!
                sdetweil @eyebee
                @eyebee did u reply yes to use pm2 for auto start?
                and if you did, do
                pm2 start 0
                does mm start?
                if u did not, then run the fixuppm2 script from here
