    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 11.2k Views 2 Watching
      sdetweil @bachoo786
      @bachoo786 said in Magic Mirror updated now doesnt work:
      The thing that stopped working was when I updated MM I cannot access it anymore remotely.
      i don’t understand that. update app has nothing to do with ssh type access…
      if u mean MMM-remotecontrol type access, correct, the mirror app is down for some reason… that is what we are debugging
        sdetweil
        from the prior message, the backend is happy (node_helpers, web server)
          bachoo786 @sdetweil
          @sdetweil I mean when I updated my to 2.10 that’s when all the problem started. Before updating my I installed mmm remote control now I don’t know if that module has caused this issue of me not being able to access magic mirror remotely.
            sdetweil @bachoo786
            @bachoo786 ok. we need to see the front end console log thru the dev window
            B 2 Replies Last reply Reply Quote 0
              bachoo786 @sdetweil
              @sdetweil ok I can conclude one thing is that I cannot access my mirror from another device at home. My mirror is working but it’s not accessible from a different device. Something is blocking it or stopping it within the mirror.
              My config hasn’t changed and its after the update that I cannot access it from another device.
                bachoo786 @sdetweil
                @sdetweil any idea?
                  sdetweil @bachoo786
                  i’m not sure I understand what you said…
                  access is a vague term
                  ssh is part of access
                  load mirror on browser is part of access
                  ftp files is part of access
                  I THINK what you meant was
                  the mirror app is running, and u can see it.
                  but you cannot use a browser on another machine to pull up the the same view…
                  so, can we see your config.js.
                  I ‘think’ this is the change to address: “”,
                  which is supposed to default to “localhost”,
                  but DID default to 0.0.0.0
                    bachoo786 @sdetweil
                    @sdetweil there you go:
                    var config = {
                            address: "", // Address to listen on, can be:
                            port: 8181,
                            ipWhitelist: [], // Set [] to allow all IP addresses
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"$
        // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format$
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/$
                            language: "en",
                            timeFormat: 24,
                            units: "metric",
                    //        customCss: 'css/custom.css',
                    //                      module: "alert",
                      sdetweil @bachoo786
                      address: “”, < — means ONLY the local system can connect
                      change to
                      address: “0.0.0.0”,
                      means whitelist controls who can connect
                        bachoo786 @sdetweil
                        @sdetweil omg that worked !!! I remember before there was no need to put any thing. How come its changed?
                        Anyway I have another problem, my home assistant module keeps on turning on and off like rapidly. It never used to do that before.
                        • 3 / 4
