    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 15.5k Views 2 Watching
      sdetweil @bachoo786
      @bachoo786 ok, so the node_helper side is working ok…
      now open the developers window, ctrl-shift-i, select the console tab, and scroll up to see any errors
        bachoo786 @sdetweil
        @sdetweil I dont have access to the mirror now as I am not home. The thing that stopped working was when I updated MM I cannot access it anymore remotely. Before updating mm I could as my ports are also forwarded.
          sdetweil @bachoo786
          @bachoo786 said in Magic Mirror updated now doesnt work:
          i don’t understand that. update app has nothing to do with ssh type access…
          if u mean MMM-remotecontrol type access, correct, the mirror app is down for some reason… that is what we are debugging
            from the prior message, the backend is happy (node_helpers, web server)
              bachoo786 @sdetweil
              @sdetweil I mean when I updated my to 2.10 that’s when all the problem started. Before updating my I installed mmm remote control now I don’t know if that module has caused this issue of me not being able to access magic mirror remotely.
                sdetweil @bachoo786
                @bachoo786 ok. we need to see the front end console log thru the dev window
                  bachoo786 @sdetweil
                  @sdetweil ok I can conclude one thing is that I cannot access my mirror from another device at home. My mirror is working but it’s not accessible from a different device. Something is blocking it or stopping it within the mirror.
                  My config hasn’t changed and its after the update that I cannot access it from another device.
                    bachoo786 @sdetweil
                    @sdetweil any idea?
                      sdetweil @bachoo786
                      i’m not sure I understand what you said…
                      access is a vague term
                      ssh is part of access
                      load mirror on browser is part of access
                      ftp files is part of access
                      I THINK what you meant was
                      the mirror app is running, and u can see it.
                      but you cannot use a browser on another machine to pull up the the same view…
                      so, can we see your config.js.
                      I ‘think’ this is the change to address: “”,
                      which is supposed to default to “localhost”,
                      but DID default to 0.0.0.0
                        bachoo786 @sdetweil
                        @sdetweil there you go:
                        var config = {
                                address: "", // Address to listen on, can be:
                                port: 8181,
                                ipWhitelist: [], // Set [] to allow all IP addresses
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"$
        // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format$
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/$
                                language: "en",
                                timeFormat: 24,
                                units: "metric",
                        //        customCss: 'css/custom.css',
                        //                      module: "alert",
                          sdetweil @bachoo786
                          address: “”, < — means ONLY the local system can connect
                          change to
                          address: “0.0.0.0”,
                          means whitelist controls who can connect
                            bachoo786 @sdetweil
                            @sdetweil omg that worked !!! I remember before there was no need to put any thing. How come its changed?
                            Anyway I have another problem, my home assistant module keeps on turning on and off like rapidly. It never used to do that before.
                              sdetweil @bachoo786
                              @bachoo786 we found a security gap. The doc says, if not specified, it is localhost. But we allowed anyone.
                              Home assistant on/off what does that mean? Show me the two logs.
                              I will be away for a few hours
                                bachoo786 @sdetweil
                                @sdetweil sorry which 2 logs?
                                  bachoo786 @sdetweil
                                  @sdetweil here is a link of a little video in gif format showing you what I mean by homeassistant module turning on and off.
                                  https://ibb.co/hLx6KJr
                                    sdetweil @bachoo786
                                    @bachoo786 which Home Assistant module are u using?
                                      bachoo786 @sdetweil
                                      @sdetweil it seems to be working fine now after few reboots to the pi.
                                        sdetweil @bachoo786
                                        @bachoo786 cool. Thx for the update!
