    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 16.1k Views 2 Watching
      sdetweil @bachoo786
      @bachoo786
      please read my posts
      do
      pm2 status
      if anything is running, not stopped then do
      pm2 stop ??
      where xx is the name or number of the item running
      once u have nothing running, then redo the npm start from the MagicMirror folder so we can diagnose the rest of the problem
        bachoo786 @sdetweil
        @sdetweil ok I have done that and here is the result:
        > magicmirror@2.10.0 start /home/pi/MagicMirror
        > ./run-start.sh
        + ./untrack-css.sh
        + '[' -z '' ']'
        + export DISPLAY=:0
        + DISPLAY=:0
        ++ uname -m
        + arch=armv7l
        + false=false
        ++ grep -v '^\s//' config/config.js
        ++ grep -i serveronly:
        ++ awk '{print tolower($2)}'
        ++ tr -d ',"'\'''
        + serveronly=
        + serveronly=false
        ++ pgrep Xorg
        + xorg=519
        ++ uname
        + mac=Linux
        + '[' false. '!=' false. -o armv7l == armv6l ']'
        + '[' 519. == . -a Linux '!=' Darwin ']'
        + electron js/electron.js
        [15:51:26.871] [LOG]    Starting MagicMirror: v2.10.0
        [15:51:26.879] [LOG]    Loading config ...
        [15:51:26.884] [LOG]    Loading module helpers ...
        [15:51:26.924] [LOG]    Initializing new module helper ...
        [15:51:26.925] [LOG]    Module helper loaded: updatenotification
        [15:51:26.926] [LOG]    No helper found for module: clock.
        [15:51:27.306] [LOG]    Initializing new module helper ...
        [15:51:27.306] [LOG]    Module helper loaded: MMM-SystemStats
        [15:51:27.307] [LOG]    No helper found for module: currentweather.
        [15:51:27.308] [LOG]    No helper found for module: weatherforecast.
        [15:51:27.308] [LOG]    No helper found for module: random_quotes.
        [15:51:27.310] [LOG]    Initializing new module helper ...
        [15:51:27.311] [LOG]    Module helper loaded: MMM-homeassistant-sensors
        [15:51:27.697] [LOG]    Initializing new module helper ...
        [15:51:27.698] [LOG]    Module helper loaded: MMM-UKNationalRail
        [15:51:27.699] [LOG]    No helper found for module: MMM-TFL.
        [15:51:27.735] [LOG]    Initializing new module helper ...
        [15:51:27.735] [LOG]    Module helper loaded: newsfeed
        [15:51:27.736] [LOG]    All module helpers loaded.
        [15:51:27.737] [LOG]    Starting server on port 8181 ...
        [15:51:27.744] [INFO]   You're using a full whitelist configuration to allow for all IPs
        [15:51:27.750] [LOG]    Server started ...
        [15:51:27.751] [LOG]    Connecting socket for: updatenotification
        [15:51:27.752] [LOG]    Connecting socket for: MMM-SystemStats
        [15:51:27.753] [LOG]    Connecting socket for: MMM-homeassistant-sensors
        [15:51:27.754] [LOG]    Connecting socket for: MMM-UKNationalRail
        [15:51:27.754] [LOG]    MMM-UKNationalRail helper started ...
        [15:51:27.755] [LOG]    Connecting socket for: newsfeed
        [15:51:27.756] [LOG]    Starting module: newsfeed
        [15:51:27.756] [LOG]    Sockets connected & modules started ...
        [15:51:27.943] [LOG]    Launching application.
        [15:51:29.943] [LOG]    Create new news fetcher for url: http://feeds.bbci.co.uk/news/england/rss.xml - Interval: 300000
        [15:51:29.984] [LOG]    Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 300000
          sdetweil @bachoo786
          @bachoo786 ok, so the node_helper side is working ok…
          now open the developers window, ctrl-shift-i, select the console tab, and scroll up to see any errors
            bachoo786 @sdetweil
            @sdetweil I dont have access to the mirror now as I am not home. The thing that stopped working was when I updated MM I cannot access it anymore remotely. Before updating mm I could as my ports are also forwarded.
              sdetweil @bachoo786
              @bachoo786 said in Magic Mirror updated now doesnt work:
              i don’t understand that. update app has nothing to do with ssh type access…
              if u mean MMM-remotecontrol type access, correct, the mirror app is down for some reason… that is what we are debugging
                from the prior message, the backend is happy (node_helpers, web server)
                  bachoo786 @sdetweil
                  @sdetweil I mean when I updated my to 2.10 that’s when all the problem started. Before updating my I installed mmm remote control now I don’t know if that module has caused this issue of me not being able to access magic mirror remotely.
                    sdetweil @bachoo786
                    @bachoo786 ok. we need to see the front end console log thru the dev window
                      bachoo786 @sdetweil
                      @sdetweil ok I can conclude one thing is that I cannot access my mirror from another device at home. My mirror is working but it’s not accessible from a different device. Something is blocking it or stopping it within the mirror.
                      My config hasn’t changed and its after the update that I cannot access it from another device.
                        bachoo786 @sdetweil
                        @sdetweil any idea?
                          sdetweil @bachoo786
                          i’m not sure I understand what you said…
                          access is a vague term
                          ssh is part of access
                          load mirror on browser is part of access
                          ftp files is part of access
                          I THINK what you meant was
                          the mirror app is running, and u can see it.
                          but you cannot use a browser on another machine to pull up the the same view…
                          so, can we see your config.js.
                          I ‘think’ this is the change to address: “”,
                          which is supposed to default to “localhost”,
                          but DID default to 0.0.0.0
                            bachoo786 @sdetweil
                            @sdetweil there you go:
                            var config = {
                                    address: "", // Address to listen on, can be:
                                    port: 8181,
                                    ipWhitelist: [], // Set [] to allow all IP addresses
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"$
        // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format$
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/$
                                    language: "en",
                                    timeFormat: 24,
                                    units: "metric",
                            //        customCss: 'css/custom.css',
                            //                      module: "alert",
                              sdetweil @bachoo786
                              address: “”, < — means ONLY the local system can connect
                              change to
                              address: “0.0.0.0”,
                              means whitelist controls who can connect
                                bachoo786 @sdetweil
                                @sdetweil omg that worked !!! I remember before there was no need to put any thing. How come its changed?
                                Anyway I have another problem, my home assistant module keeps on turning on and off like rapidly. It never used to do that before.
                                  sdetweil @bachoo786
                                  @bachoo786 we found a security gap. The doc says, if not specified, it is localhost. But we allowed anyone.
                                  Home assistant on/off what does that mean? Show me the two logs.
                                  I will be away for a few hours
                                    bachoo786 @sdetweil
                                    @sdetweil sorry which 2 logs?
                                      bachoo786 @sdetweil
                                      @sdetweil here is a link of a little video in gif format showing you what I mean by homeassistant module turning on and off.
                                      https://ibb.co/hLx6KJr
                                        sdetweil @bachoo786
                                        @bachoo786 which Home Assistant module are u using?
                                          bachoo786 @sdetweil
                                          @sdetweil it seems to be working fine now after few reboots to the pi.
                                            sdetweil @bachoo786
                                            @bachoo786 cool. Thx for the update!
