    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 7.1k Views 3 Watching
      sdetweil @lpt2007
      @lpt2007 said in Does magicmirror need minimal X11 to run?:
      Any idea what error I posted means?
      yes, u need more libraries loaded into the container…
      /lib/arm-linux-gnueabihf/libdbus-1.so.3
        sdetweil @lpt2007
        @lpt2007 use the other docker image I posted a link to… it ‘supposedly’ works… but depends on a security breach in my opinion,
        letting a container write directly to the docker host XWIndows
          sdetweil @lpt2007
          Thanks, but this is not an option, because I try to use mm as addon for Home Assistant and I use hassos image
          i don’t really understand, as BOTH approaches will require some browser to be running ON the HASSOS image ALL THE TIME… (somewhere)
          • L Offline
            lpt2007 @sdetweil
            @sdetweil said in Does magicmirror need minimal X11 to run?:
            This library is already installed.
              sdetweil @lpt2007
              no version information available
              https://github.com/electron/electron/issues/16364
              • L Offline
                lpt2007 @sdetweil
                not the right one
                I installed this one:
                root@local-mm:/# apt install libdbus-1-3
                Reading package lists... Done
                Building dependency tree
                Reading state information... Done
                libdbus-1-3 is already the newest version (1.10.28-0+deb9u1).
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  sdetweil @lpt2007
                  @lpt2007 i don’t know… the error says its not right.
                  I don’t know how to solve it…
                  again, I would go look at that other docker container which does what you want (maybe)
                  • L Offline
                    lpt2007 @sdetweil
                    Container with mm must connect to host display. I made something simmilar with kodi media center in docker container.
                      sdetweil @lpt2007
                      @lpt2007 ok, and why does chrome on the hassos not work?
                      • L Offline
                        lpt2007 @sdetweil
                        Maybe I can try to made ha addon with chrome in kiosk mode to see where the problem is?
                        • 2 / 3
