    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 9.2k Views 3 Watching
    • L Offline
      lpt2007 @sdetweil
      @sdetweil said in Does magicmirror need minimal X11 to run?:
      yes, u need more libraries loaded into the container…
      /lib/arm-linux-gnueabihf/libdbus-1.so.3
      This library is already installed.
        sdetweil @lpt2007
        @lpt2007 said in Does magicmirror need minimal X11 to run?:
        no version information available
        https://github.com/electron/electron/issues/16364
        • L Offline
          lpt2007 @sdetweil
          not the right one
          I installed this one:
          root@local-mm:/# apt install libdbus-1-3
          Reading package lists... Done
          Building dependency tree
          libdbus-1-3 is already the newest version (1.10.28-0+deb9u1).
            sdetweil @lpt2007
            @lpt2007 i don’t know… the error says its not right.
            I don’t know how to solve it…
            again, I would go look at that other docker container which does what you want (maybe)
            • L Offline
              lpt2007 @sdetweil
              i don’t really understand, as BOTH approaches will require some browser to be running ON the HASSOS image ALL THE TIME… (somewhere)
              Container with mm must connect to host display. I made something simmilar with kodi media center in docker container.
                sdetweil @lpt2007
                @lpt2007 ok, and why does chrome on the hassos not work?
                • L Offline
                  lpt2007 @sdetweil
                  Maybe I can try to made ha addon with chrome in kiosk mode to see where the problem is?
                  • L Offline
                    lpt2007
                    Thanks for your time @sdetweil :)
                    I will first try docker container from link you posted before. One of scenario is about:
                    Scenario 2: Using docker on the raspberry pi and starting the magicmirror on the screen of the pi.
                    I will post results back.
                    • L Offline
                      lpt2007 @lpt2007
                      Again without success :(
                      Error:
                      (electron:41): Gtk-WARNING **: cannot open display: unix:0.0
                        sdetweil @lpt2007
                        @lpt2007 yeh, its a tricky, not really supported approach
                        I personally wouldn’t even try it
                        • L Offline
                          lpt2007
                          Maybe the problem is host os, not a container?
                          • L Offline
                            lpt2007
                            Problem is host os. I downloaded latest raspbian buster image and followed guide from the link. Works like charm in docker container and display picture to host hdmi.
                              sdetweil @lpt2007
                              @lpt2007 now, if you go back to the 1st docker image, and then open a browser on the host connecting to
                              http://docker_container_ip:exposed_port
                              you will get the same results…
